Motor Generators
This is what Dave was doing (Turion) spending huge sums of money that others took advantage of and since have turned against him as foolish as that is.
Dave is not mentally ill anymore than Thane is crazy. Thanks for sharing what you feel because now I know what kind of creatures lurk here. Thane teaches and the rest steal when they should be buying.
14 years of instructional video's showing an open hand to people who live in darkness. Dave the same. Going out of their way day after day, years on end, thousands of hours of free instruction only to be met with people who bite and back stab. Ya know the one liner guys who see a demo that represents 200 hours of a persons time and energy, their only response is equivalent to a worthless grunt while they feel is a qualifying counter. Then there are the yuppies and suck ups who tag along like the lapdogs do.
.................................................. ................Last edited by BroMikey; 07-30-2021, 03:10 AM.
On a serious note, I have no evidence that Dave was lacking in his ways. I have had a great interest in the build he was doing. I, in fact, used one of his techniques in the build that I am now finishing. It dropped all the drag on the rotor which was daunting. Nick's build at ESTC did have serious rotor lock to deal with. I did ask to witness it and he agreed. It did take a healthy spin to get it going from stop state. I will have either one more or one less magnets than coils in this build. Thanks to Nick, I found a great source for core/bobbin pairs in a bypass choke for audio. I will strip and rewind with #24 wire for better voltage output.
I can only hope he is well and ok. We just had a person out of work for over a month with the new crap. He is bad off. Sure hope he didn't get that crap too. I wouldn't want my enemies to have it. Dave, you are always open to chat with me private if you wish. I still want to see where that build goes.
thay
Originally posted by Quantum_well View PostBro', it's just all rubbish,..and that's just plain silly.
sincerely John.
See Thaelin, he verified some portion of the effect. Well John we look foreword to seeing your device. See bye-slammer and his weak attempt, at least he tried.even if it wasn't very hard or worth much making a show of it. How about it John? You gonna make a show?You will need a chaulk board, a pointer and have some hardware on hand that relates to the subject for starters.
Originally posted by thaelin View PostOn a serious note, I have no evidence that Dave was lacking in his ways.
thay
Stay frosty and don't take any wooden nickels.
Everyone who thinks that they have got something unique have got to present it in a proper way. It's the inability of them to use the correct tools and use them properly. Everyone is lead up the garden path by inaccurate measurement. They waste a fortune on lamps,switches, meters and what have you.Ask bistander if it's possible to do an accurate assessment of a generator using volts and amps of the prime mover, if he approves of this method I'll eat my hat!
All you need to know about the prime mover is rpm and torque period.
John.
Originally posted by BroMikey View Post... Where is your bullet point? ...
1000's of hours of teaching lies and falsehoods from Thane Heinz and Turion is all a sham. It does more harm than good. They need to prove their claims with straightforward power out / power in. That is so easy, but never happens.
You said "Dave is not mentally ill anymore than Thane is crazy."
Actually you're right. Both have serious mental issues. They can not see truth and fact which is right in front of them. They are consumed by fantasy of their own making.
Sure, you can wind a coil such that the actual load lessens as the apparent load increases due to internal reactance and signal frequency which results in a decrease in prime mover load (increased motor speed and decreased motor current). But that in no way contributes to extra power output. Same with other schemes. Yes, you can mitigate cogging. So what? Cogging is not a loss mechanism so is irrelevant at speed.
Thane Heinz has 14 years at it, you say. Certainly time enough to run his contraption for a few days continuously and prove it doesn't deplete the battery. Turion had at least a year and a half to prepare for Aaron's conference and prove his claim of OU/FE. His friend tells us that he can't handle the truth. Neither of these guys can face reality.
John.
Now you are almost there. Next take the head off of a state of the art conventional (MOT) transformer and you have an E-Core with some windings. Start up your rotor and run it at 3500rpm to 5000 rpm, some where in this range is fine. If you are able to do that without being struck by flying magnets (congrat's again) you probably spent enough money on it so it does not self destruct and take you with it.
Now you must record the voltage and amp draw of the little motor driving the rotor. Let's say it is a 36 volt motor that draws 3 amps to make the rotor go with no cores anywhere around it.
Next thing is to bring the transformer E-Core (This is what Thane did) up close to the rotor magnets say 60 thousandths of an inch spacing. Congrat's you put a feeler gauge between all of your magnets (not like slander did) and the rotor is so true that every magnet around the entire rotor has a 1/6th inch gap.
.060-.062" is nice. Just to bring the core up to the rotor magnets costs you some drag. Now your meter is reading 36 volts at 3.5amps. You are about to generate some power.
Next using the low voltage side (Not the 5000v winding) connect a 12v light bulb. It only will produce about 6v and the bulb will be dimly lit. Not a very good test but it works. You are going to need a better coil to raise up the voltage if you want 50-100 volts But for now let's use this one. The car headlight bulb can draw3-5 amps 12v or even 15volts but yours is dimly lit coming in at 6v at 1/2amp. Now you are generating 3 watts. Not very impressive is it?
Nope not very impressive like all the fancy torque machines and the latest fluke meters calibrated to high accuracy. While you are thinking about my measly 3 watts and how cool your dynamometer is I am winding a fresh coil of magnet-wire. Oh yeah my 3amp draw went to 3.5amps a 18watt increase just on core drag and the generated power is only a 3 watt drag.
So here is what we have. 36v X 3A = 108w for just the rotor no cores
Then an additional 1/2A core drag or 36V X 500ma = 18w
It is time to generate at 6v X 500ma = 3w
Now the blind people all laugh because they don't see where this is going.
We have 108w + 18w + 3w = 129w
Next do the same thing with a fresh wound RegenX coil. 108W + 18w (core drag) just like the conventionally wound E-Core. Now comes the 60watt Regenerative acceleration generator output. The cores were already the additional 18w as we said. But now we are getting 60watts from the new coil.
Before we would have had a number like this:
108w (rotor) + 18w (core drag) + 60watts = 186w regular coils
Same every but 1 sixty watt RegenX coil. Now the figures read like this:
108w + 18w - 40watts - 60watts = +26w
The 40watts came when the coil was engaged which means the coil has been wound in such a way that it offers electrical watts (60w) plus it also lowers the drive input by 40watts.
This is for 1 coil. Now add 1 more and you have the so called free energyLast edited by BroMikey; 07-30-2021, 11:58 PM.
So instead of make-believe numbers, why don't you run a real test with conventional coil against RegenX coil and use real data?
160 watts is the increase the debunker observed going from a conventional wound coil to bifilar coil.
Further you missed the whole point. Conventional calculations show a 3watt increase for a generated 3w output. All coils are able to generate conventionally and RegenX format all with the same core.
Not so with Regen Coils. One liner man strikes againDrowning man grasping at straws "DEBUNKER SAYS"
Hi John yes that is a good point. here let's look another way. Take a rotor out of the box and throw a set of bearings on it and then set 24 magnets into the rotor. Congratulations you just spent a bunch of money and time. Okay well we won't itemize the task but be sure you get the spacing 100% right on, no mickey mouse (like Bye-Slanders) rotor will replace a machined unit.
This is for 1 coil. Now add 1 more and you have the so called free energyLast edited by BroMikey; 07-31-2021, 12:08 AM.
Also looking at the true data not some debunker guy we find that once rotational equilibrium is reached (rotor +core drag) all generated power is close to a 1:1 ratio. This means that if 5000watts is produced from a regularly designed coil, 5100 watts must be added to the drive motor. If the rotor and core drag is 500 watts, EE call this a zero and is the same as rotational equilibrium. Once the system is up and running then efficiency calculations can be made based on the output VS what much input power is required.
In the case of an electrical utility supplying it's maximum output during air-conditioning season they will run at 60% efficient for short periods as systems reach overloaded conditions. Breakers blow and additional units must be engaged to supply the demand and your bill skyrockets.
With these RegenX type coils a 5000watts of produced output costs no increase to the drive motor turning the rotor. A 20,000 watt output does not raise the drive motor input.
So looking at this 200 year old mind set to get 6500watts you need to add 10,000watts to the drive motor and so on.Last edited by BroMikey; 07-31-2021, 12:27 AM.
False fake and fony. Cores drag rotors down with open circuit winding all very close to the same. Common sense. Stop depending on the debunker lies and run the tests like I have.
