Motor Generators
  • What I find to be quite interesting is that each inventor has a specific Tech they call their own. In this case (unlike Turion who uses a tonne of magnets) Thane uses some of his coil stations (or sacrifices some of the coil stations) to run at in excess of a 90 degree phase delay angle so as to counteract the drag still being produced on his other coils recharging the battery.
    In this expose combines switching with what he calls his quantum motor (which are coils to assist rotor action without any power being supplied to them) with regenX coils plus the braking circuits and more into his little black box (that is not that little)
    Working together this multilevel approach can cause a CAR to run down the road and never need charging.
      which are coils to assist rotor action without any power being supplied to them]
      • YEARS AGO THANE USE TO HAVE A DEMO OF WHAT LOOKED LIKE A LARGE MOTOR WITH A SHAFT ON TO SO YOU COULD INSTALL IT ON ANY ENGINE AND WITHOUT ANY POWER INPUT.
        HE HAD LONGER COILS THAT WHEN SHORTED OUT WOULD DELAY THE CURRENT IN THE TIME DOMAIN PAST THE NULL POINT QUITE A BIT
        SPECULATING i AM ASSUMING HE HAS A MOTOR COIL AND REGENX COIL ON ALL OF HIS CORES THAT THEY COULD BOTH BE ADDED IN SERIES (AND SHORTING THEM OUT NO LECTRIC) TO HAVE COILS DO ALL THREE MODES OF OPERATION. SINCE THANE NEVER GIVES AWAY HIS ENTIRE LIFES WORK ON COIL STRUCTURE OR LENTH OF WIRE I CAN ONLY QUESS.
        HERE IS ONE OF HIS OLD CHANNELS FROM 2016 TALKING ABOUT COILS THIS DOES NOT TELL US MUCH
        • here is me showing ( midway thru the video) a coil doing both speeding up wildly and running a load, yet in the shorted position it was in a runaway condition. in this video it is not important to listen to me blubbering. watch the meters, they tell the whole story
          • The Self-Excited ReGen-X Quantum Motor/Generator is the world's first motor coil that is capable of providing Mechanical Output Power, preforming Positive Work i.e. system acceleration without requiring any externally supplied electric input power. The Self-Excited ReGen-X Quantum Motor/Generator operates simultaneously as a self-excited generator and motor where the generator action supplies the electric power for the motor coil without requiring any external input power.Potential Difference Inc. has developed the ReGen-X Quantum Motor which performs mechanical work just like every other electric motor since Michael Faraday invented the first electric motor in 1820. The ReGen-X Quantum motor differentiates itself from all electric motors that have come before it in that it does not require any electric input energy to be supplied to it when it is performing mechanical work and accelerating itself. The energy required to perform this positive work (system acceleration, kinetic energy increase) is electromagnetic field energy that is created at the subatomic electron level. How this energy is created and manifested is explained in the attachment below. The Nature of Sub-Atomic Quantum Photon Energy Creation and Externalization Around a Current Carrying Conductor: https://www.slideshare.net/ThaneNEWEN... It turns out that this very same created electromagnetic field energy also performs negative work in all electric generators and is colloquially referred to as EV regenerative braking. So our innovation is new motor/generator coil design which has the ability to:- produce mechanical output power and to perform positive work (system acceleration) with zero externally supplied electric input energy, - and to generate electricity with zero externally supplied mechanical input energy while simultaneously producing mechanical output and positive work (system acceleration), - and to perform negative work like any conventional generator coil when operated below the coil's Critical Minimum Frequency. Thane C. Heins
            • I found an old video using the Hero Electric bike
              • Here is a recent video explaining the quantum motor. He says it can be made to give all of it's coil energy to the kinetic assist which in one case means that a coil wound this way would store energy while intentional releasing it well past the null point. I my experiments I can power tiny loads and get no acceleration or if I put a heavy load (almost a dead short) the coil will accelerate a huge amount which lowers drive input power or conventional motor prime mover power
                Obviously a conventionally wound motor is used and and systems can not always be as easily started without it. So all that we are doing is adding other forms of energy assisting coils and generator coils that operated in the null Region. Further a system can be upgraded as a motor coil while at the same time be collecting all of the joules back to the batteries without dragging down the prime drive mover
                Additionally either more coils can be used to counteract the drag of any setup much like Dave's extra magnets do. In the end no magnet may be needed for a rotor as electromagnets will take over to lower manufacturing costs. A slip ring with brushes like a car alternator uses could provide the tiny bit of energy for self excitation. This method as seen in a car alternator is much less expensive. Small coils of thin magnet wire to make electromagnets would keep companies from all of the irregular magnet waste that would be rejected and the world would run out of that material
                Hillcrest is shooting off it's mouth calling on Thane for proof of his extraordinary claims. They might offer buy him out and be paid to burial this innovation. In the past other option would be to quickly bury the inventor and begin media smear.
                In part 3 min 14 explains the difference between a regenX coil and a Quantum motor coil.
                These are Thane's happy new year video's made right after Xmas dinner 2021. 1-5 this guy works hard
                I heard Thane say thru playing around with different modes of operation such as half the number of coils being called upon to become motor coils at lower speeds the other 6 coils would be used in a shorted condition to counteract losses when motoring up to SPEED
                ww.youtube.com/watch?v=Zo-hKoZvExQ
                https://www.youtube.com/watch?v=hnEGw8QWAbY
                https://www.youtube.com/watch?v=dnCI6hhSyfc
                https://www.youtube.com/watch?v=Pw7761IqMcQ&t=99s
                https://www.youtube.com/watch?v=lf9BnAhWew4
                Hillcrest Petroleum Infinite ReGen-X Motor Demo
                • Any generator coil of any configuration can achieve neutral Lenz at the correct RPM. Any coil of any configuration can achieve neutral Lenz at a designated RPM with the addition of the proper capacitor in parallel with the coil.
                  You can run a coil both as a generator coil and a motor coil with the correct timing. Matt Jones designed a setup for one version of my generator that did exactly that. And then I threw the wrong switch at the wrong time and blew out the circuit.
                  But Lenz free coils are not enough to make a generator turn “freely” driven by a prime mover. Every coil (with a core) that you add is an additional mass of material you must pay to move magnets past. It has been argued by idiots on this forum that the attraction of the rotor magnet to the iron core as it approaches is equal to the attraction backwards as it moves away, so there is no effect. These people have never built anything and are idiots. I think calling them idiots three times is required. So let me restate that. They are idiots.
                  • For those who can not follow Thane this is what he said Dec 27th for his coil data. Thane is a stutterer
                    Quad-filar coil with each strand .1 ohms. With that we can do calculations for an 80v output on the .3 ohm side and the .1 ohm is the motoring coil ohmage
                    Then Thane says he adds the
                    .3 ohm coil in series with the .1 ohm coil to form a .4 ohm coil he now calls his Quantum motor as the cpu not only does the connections back and forth but also shorts out the .4 ohm coil
                    Matt has nothing to do with it, I don't want to hear his name and to inject that name into many conversations is an insult to Thanes work as he has not a single video on the inject or any data to offer over the past 10 years
                    • Is the 1 ohm coil added in series or in parallel?
                        not a 1 ohm coil I said a point one ohm coil, a vast difference, see picture
                        The
                        .3 ohm coil is 3 strands each.1 ohm each he calls his RegenX coil that runs at the null point. These coils that form a .3 ohm coil are the product of the 3 strands of .1ohm each connected in series, yes. The single .1 ohm coil used to motor with is then removed from the circuit temporarily and is added in series with the .3 ohm. This reaches well past the null.
                        Now he has a
                        .4 ohm coil that is then shorted across so at the lower speeds it can assist or offset the drag
                        Thane also stressed the importance of winding a coil tightly and uniformly, which he says he can not do so he uses a factory to do precision work, without that it won't work right. Thane has spent Boo Ku and these are just prototypes. His funding is small and no one has any money. However he has the same corporation make the cores as well.
                        • here is the ohms chart per foot for 1000ft of magnet wire
                          https://mwswire.com/wp-content/uploa...-Wire-Data.pdf
                          • Happy New Year guys everyone! .... Thanks for the answer Turion, but I didn't understand, ... does the magnet have to rotate with the copper disc?
                            • I got your message. Thane has already told us that when he started out he used iron cores. Then Thane had a series of video's on Permalloy that he was trying out in his transformers and his large coil regenX machines often dual rotor. Then metglass got big in around 2009 and now the new material is very nearly the same called amorphous nano-crystalline either 101 or you can use 107 for higher than 100hz. Then told us in an interview on radio that the correct proportion was around 50% nickel content at the time worked best.
                              Thanes new approach to deal with parasitic drag (first step) is the Quantum motor coil to counter appose this drag at lower speeds. We all know what has to be done but very few can give their whole life to this work like Thane has done. The rest of us are part time spectators. I remember how young and fresh Thane was when he started and look at him now, he is almost a 20 year man and still not funded for high output factory production. Your time runs out
                              This is a repeat message from the 70's, 80's, 90's, 2000's and up where inventors thought they would get noticed and make a fortune. Their time ran out because the big money is told to wait them out and can not help the little guy even if they wanted to.
                              Corporations fight other corporations with red tape stalling out any competition tying their hands for 10-20 years at a shot thru unlimited court proceedings. Dirty judges and dirty lawyers run everything as their back up team uses the muzzle of a gun to make the impossible, possible.
                              There are floods of young man who are hired by the big money to pull a trigger for huge sums of money. It is part of their family DNA.
                              This is the same ole. Like I always say keep ducking I grew up in Detroit and so I has seen it all from dirty officials to the street rats running dope to the showers of bullets peppering the trafficking houses, the street wkores (14-25years) drugged up wandering around zombies.
                              Some things will never change.
                              • Memphis,
                                In the video I sent you they are rotating the magnets but not the copper disk. The slots are cut into the copper disk in a specific pattern to reduce, as much as possible, the currents that cause the braking action you are experiencing. I believe you are rotating both the copper disk as well as the magnets, so I don't know if this will be of help, but I thought you might be interested in it.
