Motor Generators
  • An interesting experiment was carried out with a set of a single-phase generator with electromagnetic excitation ROTOR + STATOR:
    https://rakatskiy.blogspot.com/2022/...ransducer.html
    • 66657325-E69B-49AC-BC7C-C7516BC1E882.jpeg 6B8C1A6E-A0D7-4DC0-AC49-51D7D33D3824.jpeg B5A8CE27-0062-4BC7-B699-E16A00AE2B0F.jpeg BD1EEF6B-3135-4025-AD7E-2673FF363753.jpeg 225E2D98-9B09-45B2-8645-C1EA9CAF8A6D.jpeg 3B1F3CB3-9897-4EB8-A964-761C0BA634DC.jpeg
      Extra rotors stuck to my door.
      My Old machine, which I JUST got back together to do some testing with the 12 magnet rotor (3/4 x 3/4 magnets)
      My new machine
      My test setup for small rotors using a grinder motor
      The previous rotor from my Black machine
      Lots of test coils with different cores and different wiring configurations. This doesn't count the coils that are in the OLD mach one or the NEW one.
      • F7082697-33FD-423F-A9D6-7A65AC2BBFD2.jpeg F7100C43-E3C6-423A-A1BB-B3268CA51C57.jpeg
        Setup for testing how magnets affect both the motor coil and the power coil and setup for testing coil output with rotors on both ends of the coil.
        Extra motors for testing with various setups. This does not include probably 10 MY1016 motors I have but am no longer using.
        A lot of time and money has gone into all this stuff. I'm not just doing it for fun.
        • A lot of time and money has gone into all this stuff. I'm not just doing it for fun. [/QUOTE]
          Time to stop having fun and get down to business
          Engineers only, everybody thought of it first and their ideas were stolen? just joking of course
          • Here is a commutator pulsing the motor coils. These 3 motor coils are also generator coils because Thanes coils start with a shorter motor coil wound on the spool first and afterward the generator windings.
            • free energy generator
              • Last edited by BroMikey; 06-29-2022, 07:05 AM.
                • Comment
                  • BMW water generator for car motor online.
                    • Squirt bottle style water mist generator into a running motor.
                      • Acceleration under load
                        • 100% water running a small gasoline motor
                          24v x 30 amps hho generator to the motor
                          • OVERUNITY is here with MagnetGate pulse motor and the matrix
                            • 9E4690FB-180C-4C49-9911-2C995EF5EE46.jpeg D360C353-BE34-4B04-B13A-343005AAEE33.jpeg All glued in magnets removed from rotor. Soaking in acetone to remove glue. All the ones currently in the rotor are North, so will install five South to have a N/S ten magnet rotor with LOTS of space between the magnets. If this solves the problem, will look at having sleeves made for each magnet.
                              • Hello Dave
                                I see you are hard at it. This has been along time coming but hey you learn by trial an error. Let us know what the right answer to solve the problem asap if possible, this is got me on pins and needles. Either way you are going to get to the bottom of this.
                                I am setting up to do machining work. I need to cut non magnetic rotors with them.
                                edit
                                I see half the drag and half the opposition magnets. Should turn out good
                                edit
                                your opposition magnets are out of place, right?
