Motor Generators
  • hey all. here's an on board generator used in missiles. it's a flux switching machine. looks like it might have reduced lenz effect?
    • how do we delete posts?
      • how do i delete this post?
        • Voltan,
          I think you can go to the edit button and remove content, but I don't think you can delete the entire post.
          Wantomake,
          I tried the experiment with several different all north magnet rotors and generator coils. Because the coil cores are attracted to the rotor magnet, when you add a magnet to the BACK of the coil core, you are increasing or DECREASING the change in flux that takes place within the core material, which is what generates the energy. You have to be careful that your magnet on the back isn't too strong, or the passing rotor magnet cannot create enough of a change in flux to produce any power. In that case, put a spacer between the magnet you have on the end of the coil and the magnet you added to reduce its effect. It takes some playing around to get the most efficient combination. Think of it this way...as the rotor magnet passes the core material you take it from the 0 point to a +50. If you have biased the core material with a small charge of the correct polarity by putting a magnet on the back of the core, you might have it at a -10. Now your passing magnet, if it is STRONG enough, can still take it to +50, but you have moved it a total of 60, which reflects in the output of power. CHANGE in flux causes the generation of electrical energy, which is why you either need N/S magnets on your rotor, OR you can have an all N magnet rotor if you bias your coils with magnets on the back so they always return to lower than the 0 point when the magnets pass. I certainly wish I had figured some of these things out before I threw away my BIG all N magnet rotor machine. I probably COULD have gotten it to work if I had known then what I know now. Actually, I DID know all of this from experiments I did YEARS ago, but didn't realize how it would apply to my build.
          As for the magnet opposite the generator coil that I moved in and out by hand, there is an attraction of the rotor magnet to the core material that you can cancel out with thew magnet on the opposite side of the rotor, affecting the magnet on the rotor directly across from the one aligned with the generator coil (An even number of magnets is required on the rotor for this to work). I have SEEN this with several different sized rotors. bistander insists this goes away at speed, but it does not. It is the reason for the opposition magnets in my big machine, and I know it works. The proof is on the bench.
          As to adding magnets to the motor coil (both on the back, and across from it in opposition) it also works, although the polarities are the opposite. That's why I showed this SIMPLE experiment, so anyone with a few magnets, a reed switch and a couple coils can see that what I have been saying is true. Don't believe me. Don't believe bistander. Believe what you see on the bench. You can prove the concepts with this simple little setup. You don't need to build my machine to see the truth. This is what I started with years ago, and I had several folks replicate and tell me I wasn't seeing things BEFORE I invested money in building my first large prototype.
            No, you at at war with the world, I am not. If you want to come back you will have to do better than tricks about how bad I am. Try repaying your debt and apologize to those you have lied, cheated and stolen from. After that I won't seem so bad.
            You rambling about how I am no longer to be tolerated sounds like something a mental person would say. Are you planning to stop all free speech also? Mattie's krytonite, isn't that special. All I have done is put you in your place and that makes me whatever?
            Who did I lie cheat and steal from little Mikey who?
              Fess up mattie dont play innocent when you know you are guilty. Who mattie who?
              • Ya who Mikey, who did I lie, cheat and steal from? Tell me and while your at tell me how you know this to be fact.
                  the word has been out on you a long time. And you are worried about being censored? That is what happens when you are untrustworthy. Why are you so worried about it if it ain't so?
                  • What does that have to do with anything I asked you. Who did I lie cheat and steal from Little Mikey, who? It wasn't you so who was it. Who put the word out on me? Who Little Mikey?
                    • Thanks Turion,
                      Just came from the shop and this post.
                      The potentiometer on the boost converter will not adjust down. So I'll deal with that some other time.
                      I want to replicate a small machine like yours to try the opposing magnet setup. Now that my wife and I are both retired now there's more time in shop if it's not too hot.
                        Ask the people who pulled your funding on all your earth shattering inventions. BTW after all these years seems like those NDA's would have run out by now. 15 years? Show us anything. You claim you have 3 of them little mattie. How do you like them tomato's?
                        • See you refuse to answer me. No one has been under NDA for 15 years. Who told you I lie cheat and steal from them, who? Or are you coward. To cuck to answer. To inferior to hold legible conversation? Who Little Mikey, who?
                            You must update your perpetual NDA so you can continue to hide. If you are back here it must be that you ran out of money. No sucker fishing allowed here. The word has been out a long time. I told you that with your cunning that you would never have any real invention you could call your own. You are a zero with a bad mouth. Nobody here is going to give you more money so be gone.
                            • Gasoline vapor generator for your motor
                              • Ya, that's the same coward you have always been, The same incoherent nonsense you have always spewed. I don't think it hard for others to see. You know Mikey the first time I reached out to you all I wanted to do was help you with your cap dumper. You were too stupid to understand the purpose of it. All I wanted to do was help. But you rejected that help and made a point of insulting me.
                                There are just handful of people who ever been on this forums who actually contributed, your not one of them for sure. Er Finder a person I did not respect was. I wish he would post back here I have questions for him. About what he seen. Maybe about how much further he went. David seen it too, your beloved little master, but he doesn't remember those things that are important. He just babbles on about himself and what ever he make up in his little world. He can't help it he's ill.
                                You wonder why I am here, why I am watching but then a PDF I WROTE is getting distributed like an answer. But its not. It was early experiment into Boost motoring. Now that I have some basic electrical experience Those things could be made so much better. But if I started to talk about them and see if people would replicate, You little Mikey would interfere. You would clutter the thread with nonsense. You always have.
                                Bro Mikey is the agent that destroyed this place for a lot of us. And until Aaron realizes this and cans him, this place will stay dead.
                                I do not want or need anything from anybody. I have never had a better time in my life than now but I sure wish I could share some of the things I have learned. I want an army of people who are willing to look. I sure do miss what it used to be to be here.
                                Congratulation little Mikey you've ruined it all. I hope you got a bonus.
