Motor Generators
I talked to Bob French today and he put together a setup using a boost and 3 lithium iron phosphate batteries. He has a load running between the + out of the boost and the charge battery. He ALSO has a load across battery 3. In the old days I talked a LOT about balancing the load across battery 3 with the load between the positives, and Bob has managed to do that. He's old school 3 BGS like me. I believe he has a 10 watt load on the output of the boost, and not sure what the load is on battery 3. The system has remained balanced for about four hours now, where the primaries don't go down and battery 3 is at almost a full charge, but doesn't go up. The system just puts out energy, running both the loads, while the voltages in the batteries hold steady. He is going to run it all night and see what happens. He is also going to shoot a video where he walks through his setup. His load on battery 3 is one of those LED light strips you roll out under cars to light them up while working on them.
This seems to be MUCH easier than doing it with Lead Acid Batteries. Balancing a load could take me a whole DAY, and by that time my batteries were discharged and I had to recharge and start over.
However I thought about it ALL NIGHT and couldn’t sleep! I realized that since the GROUND on the boost module is a THROUGH connection. (- in is connected to - out) the positive out of the boost module is going through the load and to the - out of the boost module (which is coupled with the - in) and the - in is going to the + of the charge battery. So you are actually running the load between the output of the boost and the positive of the charge battery also, and it is working without the two diodes I recommended, or they exist inside the boost module.
I am not sure you could run it this way with other boost modules, but now that I understand what is going on, I see why it is possible to get the results you are getting. I thought the output to the load was being WASTED in this schematic, so I could NOT understand your positive results. It is NOT wasted. But be aware that it might not work this way with EVERY boost module. They are not all the same circuit, so a missing diode or one in the wrong place could prevent this from happening.
Okay I will make a note of this entry. The watt meters may have diodes
Originally posted by OrionLightShip View PostI have to apologize Bro Mikey; my focus is really narrowed on what I know works and I was never a fan of Bedini circuits but, if I get the gist of what your saying with a 9 year old video is that you pulse batteries?
Not a fan of that either.
I do admire your ability to build... to me it is tedious and painful to my body. I also like that you are learning Turion's methods.....
What we want is rare and not easy to capture without using the right methods.
Orion
I gotta stop somewhere fella's. Look at all of the WH recirculated and it still runs. I have torched 26WH and where did they come from? Not these batteries.
Orion
https://www.amazon.com/DEVMO-45-390V...356343486&th=1
At higher voltages small losses don't matter as much. Remember, hIgh voltage DC is DANGEROUS, DANGEROUS, DANGEROUS.
I treat it with the caution I use with large Neo Mags..... pay attention where it is.... isolate and insulate it where I can't touch it
I put big caps in a cardboard box with no exposed wires...etc
Originally posted by Turion View PostI had a setup for my dad's small solar system, where when the sun went down, and he needed to run through the night, I would cascade his system, pulsing through an inductor in parallel with an inverter that received constant current. 6 batteries going to 4 batteries, going to 2 batteries, going to one battery. I could run the 12 volt inverter between each stage and use the inductor to charge up the batteries left behind as you moved from one stage to the next. I added inductors in parallel. I'm not saying that is the BEST system, but I saw what could be done.
The primary of a transformer is an inductor, inductively coupled with the secondary. Recover and "generate."
At higher voltages small losses don't matter as much. Remember, hIgh voltage DC is DANGEROUS, DANGEROUS, DANGEROUS.Last edited by Turion; 08-02-2022, 04:17 AM.
I can see why you need a buck converter as the differential changes huge amounts go to battery 3 sometimes excessively draining the primaries and stressing the charging battery. Very important detail. 250ma going to battery 3 at the end while much less in the beginning. All batteries can stand that pounding the size I am using. Learning
