Motor Generators
Originally posted by Turion View Postrun it through a boost module that allows you to recover 80%, then 80 watts goes into your second bank. 80 watts is 80% of the 100 watt input.
But the secondary of the boost module provides you with an ADDITIONAL 80 watts that can hit the battery.
Do you even have what you need to measure whether or not you are successful? Nope.
okay so I need an isolated battery charger for that at 80%=60w not 80w
So you hit the battery with TWO sources of 80 watts, Without a source of generation, you do not break even here.
I never heard it like that before
Hence the Matt motor, Bro, you don't believe it will work,
I have never had an unmod mtr in the circuit so you are talking fantasy like running your house on one. This is earth. You are far to defensive. Yes you are correct I can't learn from you after 10 years, we are past that. I know you mean well.
evidentially not, I only follow your suggestions plus lead batteries are hard to charge and I have never found a 99% eff device such as a charger or booster. Maybe if I had lipo batteries I could try again. I know it will eventually break even after spending thousands. Then the next level another few thousand and i would be OU cop1.5? Who knows.Last edited by BroMikey; 07-23-2022, 01:16 AM.
You forgot one very amazing point about matties mtr. When it is timed and running at 1 to 2 amps 16v zapping batteries I can try to stop it with my hand putting a huge load on it and the amps don't climb. I know that means nothing to you but to me it means I can run a 20w generator minimu , for free. Why don't you ever talk a out that? Maybe you didn't do that test. Must be another galaxy? An extra scooter motor unmod. Should do the trick yet not even wanto did that test that I am aware of⁹
No I can't. The batteries run longer with each charge. My solar panels are connected to my lithium bank only. Nothing to do with the Carlos Benitez 4 battery setup shown in the YouTube video.
I said you started with TWO banks. EACH contained 100 watts to begin with if you read what I wrote
Originally posted by BroMikey View PostYes that does help. So 100w input to boost is 60w and that is 140w not 260w. I can't see how you got that number. But that 60w is not recovered because we need at least double that to charge battery 3 till the magic begins? The boost powers nothing like the mod.mtr neither just zapping batteries
Say it barely ran for ever which is theoretically impossible, where is the next level? Concept proof ruins the model? Nice
So you hit the battery with TWO sources of 80 watts, plus it had 100 watts in it already for a total of 260 watts. OR A PLUS 160 watts
But you still have to make up for the 100 watts you lost to begin with. And you will input 300-400 watts to get it back.
Without a source of generation, you do not break even here. Hence the Matt motor is needed. It actually generates a pulse because of the collapsing coil, and that makes it, at the correct frequency, able to provide the required pulse to go with the constant current provided by the boos module running between the positives.
Running a razor scooter motor as a generator is an absolute FAILURE. Tie a boat anchor around your neck.
Yes, I have built systems that did what I say they will do. So has wantomake. So has Matt. Learning is a process. Until you understand step one, there is no reason to explain step ten. I have videos of working systems on my YouTube page right now, but viewing is restricted. Until you understand the principles, you would never make them work. Bro, you don't believe it will work, so you are correct. It will never work for you.
Do you even have what you need to measure whether or not you are successful? Have you PROVED to yourself that input energy can be recovered when you run between the positives? Did you do enough experimenting and beat your head against the wall long enough to finally see it work? Nope. So how are you ready to make it work better if you don't have it working in the first place.
BroMikey, this sounds like a very informative experiment
You seem to have many questions so help us find the answers.
Then you might break even which is theoretically impossible. But Dave did it. All his video's were deleted in another galaxy on the subject to avoid controversy.
No video validation exists other that what is on my channel.Last edited by BroMikey; 07-22-2022, 10:34 PM.
1. Make a detailed video for YouTube and post results here.
2. Record every detail on paper or laptop spreadsheet.
3. Point out what and why you have come to your conclusions from the test.
You seem to have many questions so help us find the answers. Just a suggestion my friend.
Can you explain gains? Gained runtime to zap batteries or are you using power up running lights? I know solar keeps everything from going dead
Originally posted by Turion View PostBE CAREFUL
Let's say you put 100 watts from a 100 watt battery bank into something that runs on the potential difference and produces energy, like a boost module.
We took 100 watts out of it. According to what YOU just posted, it would take 300-400 watts of input to get the first battery bank back up to the 100 watts
This spike, along with constant current from the boost,Last edited by BroMikey; 07-22-2022, 07:49 PM.
Experiential knowledge is gained here. When one sees in front of them the results of a setup. That's the gain. I have seen on my shop table the gains with using boost converter and capacitors and using the knowledge I'm taught.
Maybe it's my
I did connect capacitors across batteries #1 and #4 to "catch" energy that would be wasted on the parallel charging batteries. The boost module in my setup is sure the 87% one. But still the charging does gain in charge time not voltage as Dave Turion pointed out.
Maybe it's my newer marine batteries? Maybe it's the Matt modified motor properly built? The converter correctly set? I don't know. But I'm enjoying and ready to do more and better things.
Yes that does help. So 100w input to boost and mod.mtr 80%conversion eff then collect 80% of that is 60w and that is 140w not 260w. I can't see how you got that number. But that 60w is not recovered because we need at least double that to charge battery 3 till the magic begins? The boost powers nothing like the mod.mtr neither just zapping batteries
Say it barely ran for ever which is theoretically impossible, where is the next level? Concept proof ruins the model? NiceLast edited by BroMikey; 07-22-2022, 07:25 AM.
BE CAREFUL WITH THAT BUCK/BOOST Not all boost modules will run between the positives. I have purchased several that will not.
Here is an example. None of these numbers are real, so let's not get crazy.
Let's say you put 100 watts from a 100 watt battery bank into something that runs on the potential difference and produces energy, like a boost module. You recover 80 watts, and produce 80 watts. Your input was 100 watts but you end up with 160 watts. WOW! The PROBLEM is, what do you do with that 160 watts? Since you HAD to have a battery bank to provide the potential difference, the 160 watts went INTO a battery bank. If that battery bank started at 100 watts and it accepted ALLLLLLLL the charge (you know it won't!!!!) you would end up with 260 watts in that battery bank. But our first 100 watt battery bank is at 0. We took 100 watts out of it. According to what YOU just posted, it would take 300-400 watts of input to get the first battery bank back up to the 100 watts you started with. So we ended up with 260, but need 300-400 to charge up the first battery bank. Now we are way in the hole 140 to 240 watts. See the problem? The impedance (to charge) of a battery will cause you fits. Does that make sense? There are things we can do, but resistance and impedance will destroy most setups before you even begin.
Now the Matt motor has a coil that collapses. So along with the constant current you get from the boost running between the positives, you get a high voltage spike pulse from the Matt motor. This spike, along with constant current from the boost, acts like a "battery charger" at the correct frequency, so it is MORE that just a potential based system where you run some lights between the positives. It can overcome the losses you would otherwise see. A cap across "battery three" or many "battery threes" in parallel helps makes sure nothing gets wasted.Last edited by Turion; 07-23-2022, 12:01 AM.
