Motor Generators
  • BroMikey
    Alum battery construction, Mikey strikes again
  • BroMikey
    Nice book. Do you have any detailed data showing your results? Or is the book all theory?
    Did you get it to work, is my question. There are many a essay of higher learning all around the web. I need more than words to understand. Who should I believe?
    All I see is a pretty picture.
  • Rakarskiy
    Here's the link, I gave a detailed answer:
    https://overunity.com/19069/holcomb-...674/#msg566674
    https://overunity.com/19069/holcomb-...658/#msg566658
    This is so obvious that there is no need to prove it. The method needs to be sorted out. I'm trying to make a simple design.
    Well, the evolution of the formation of a delusion for public opinion about the design features of the Figuera generator.
  • BroMikey
    Originally posted by Rakarskiy View Post
    BroMikey, good analysis of events.
    https://figueragenerator.wordpress.com/history/
    Missed one part of Figer and his mechanic made a working model. Just a patent, without a working prayer, no one will buy it. In the material I am trying to show the essence of the invention, and the option of repetition in the USA.
    https://overunity.com/19069/holcomb-...186872/image//
    In the scheme of the patent "Fieger's Generator" - "y" denotes a phase or secondary winding. But nowhere is its design disclosed. In the variant of mutual induction, the coil wound on the core cannot work with the result of overunity.
    There are other applications, but not implemented.
    https://patentimages.storage.googlea...A2357550A1.pdf
    What is the difference between the secondary winding of the transformer and the phase of the generator? Why was the outer winding of the Gramme generator replaced with a generator winding in the stator slot? These are questions that have answers, and solutions used in these designs.
    https://figueragenerator.wordpress.c...iving-signals/
    https://figueragenerator.wordpress.c...267-year-1908/
    https://figueragenerator.files.wordpress.com/2016/01/patent-clemente-figuera-44267.pdf
  • Rakarskiy
  • BroMikey
    This guy gives some basics tho half the facts get reversed like any newspaper journalist does.
    In 1902 Mr. Figuera filed 4 patents ( 30375, 30376, 30377, 30378 ) which were sold in few days to a banking cartel as it may be derived in sight of a telegram published in the available press clippings of that year.
    In October of 1908, suddenly Clemente Figuera filed a new patent (no. 44267) . As far as we know Mr. Figuera died very few days after filing this patent. Was it his legacy?.
    After his death in 1908, his partner, Constantino de Buforn Jacas, filed 5 new patents (47706, 50216, 52968, 55411 and 57955) between the years 1910 and 1914.
    The important features of all those patents is that they are almost identical. And they are an exact copy of the design patented by Figuera in 1908.
    The very same design and in some cases the very same text to describe the machine. Buforn was clearly patenting as his own invention a machine created by Figuera
    Anybody caught on yet? People fight over patents and they never get used.
  • Rakarskiy
    https://rakatskiy.blogspot.com/2022/...nergy.html?m=1
  • BroMikey
    Engineer diy motor generator
  • BroMikey
    Need a great battery that charges and discharges hundreds of times without damage like acid does? Here is my mini alkaline. Put a few of these in series and you can run you motor/generator on them, run them down to 8vdc and never worry about ruining them.
    Update mini battery plates fully formed voltage
  • BroMikey
  • BroMikey
    Motor casting
  • BroMikey
  • BroMikey
    http://flyer.thenetteam.net/attraction83.gif
    Motor input 1000w recovery circuit = 85% or 850watts returned leaving you with 1.5hp to turn a generator with for only 150watts. This motor could turn 4 of Dave's generator heads at 1200w apiece = 4800w + 850watts recovery = 5650watts output @ 150watts input = COP 37
  • alexelectric
    Sr. Dave
    "By the way, Bob French has been running a dual rotor machine for three days now, using the circuit we have been working with. Battery number one, the primary source battery, is holding and the second battery in the circuit, which is the charge battery, has gone up above 14 volts. It also uses induction to capture energy in a secondary coil that is charging a third battery. We are so happy with the performance of the "toy" we built that we have invested in a large prototype that is currently in the machine shop. Its will be a 36 coil machine rather than a three coil machine."
    Here we have another important project, and it is clear in Mr. Dave's description, by using two magnets per core, the induction increases, and it is used to charge the battery.
  • alexelectric
    understood and understandable for what they know of electrical and electronic operation..
    Good demonstration of Lindeman, motor pulsed and recovering the collapse of the field to charge the battery, there is no back emf, the motor pulsed and commutated, the motor shutdown is operated when by means of the commutation, and when it is not conducting the transistor recovers the field that collapses and charges the battery, that is, there is no effect on the power supply input, with the output, two circuits that operate without affecting each other, when it is turned on and when it is turned off by means of the transistor.
    What I don't know is how much Leemmnan recovers, I don't know if he doesn't show them in one of his videos, or on the sales DVD of his project.
    Perhaps BroMikey, can guide me since I see that he follows several researchers and studies them, I consider that all contributions help us move forward.
    All projects give us something that can help us improve, continue studying, building, reevaluating, and correcting.
