Motor Generators
  • [VIDEO]watch?v=Sb_51A2UMaU[/VIDEO]
    Free Energy Generator 220V - Generating 2300 Watts using 740W
    True autonomy is not demonstrated.
    Installation as a power amplifier works.
    • Big Big difference, not just keeping a battery charged while running
      all kinds of drive motor power but getting a practical amount of
      usable output, making it affordable for all.
      So the right RPM for the weight. Looks like a auto clutch plate and
      ring gear flywheel. I can not tell if anything might be special inside.
      Good video, best regards
      • I do not think there are mobile balancers. The design is clearly constructed in accordance with the algorithm of the Campbell system. Most likely, they did not know exactly what the flywheel speed should be. The speed of the flywheel is close to the required speed.
          Here is why I think they used the automobile clutch and ring gear
          with flywheel. Because they are already produced to stand up to very
          high RPM'S without exploding into a million pieces.
          Running speeds of 6000-9000 rpm's is dangerous for a random chunk
          of unprocessed iron. An automobile clutch assembly with the standard
          package of clutch plate and ring gear are all well balanced being designed
          for these red line speeds.
          Cast iron bar bell disks for weight lifting are out of the question, it must
          be good steel and well balanced. I am certain many trial disks have
          flown apart during test runs of such speeds. Large iron flywheels rotating
          at these speeds are frightening without some form insurance that they
          have already certified safe.
          I think people should be very careful about which material they choose.
          During my racing years in Detroit it was common to hear about a motor
          being built up special that was operating at 10,000 rpms, they were all
          standard shift using these clutch plates.
          A clutch plate is a good choice.
          • For our installation, the external diameter of the Flywheel is important.
            Flywheels from ICE, used in the installations shown in these rollers, most likely from large diesel engines of the last century.
            The frequency of rotation of the shaft does not exceed 3-4 thousand rpm.
            The maximum reserve of this flywheel is not more than 5 thousand rpm.
            With a flywheel with an outer diameter of 400 mm, and good weight, you can already try to make a design.
            But first you need to know the limiting capabilities of the flywheel by the speed of rotation, and check the balancing after attaching it to the shaft.
              Agreed
              I think he uses air pumps to keep his weights rolling.
              https://www.youtube.com/watch?v=P4ZUAW5p3cc
              • Mechanical Amplifiers?
                Short talk
                https://www.youtube.com/watch?v=eizJQGzMO5Q
                • You say mechanical amplifier? This is my country, the result is the same as everywhere else. "Obstacles" of invention
                  http://ermola.com.ua/ - The site does not work anymore
                  https://youtu.be/PC-PRrz5S30
                  https://youtu.be/0g0FcY-7Fw0
                  • https://www.youtube.com/watch?v=0g0FcY-7Fw0&feature=youtu.be
                    What is this? Hydraulic pressure on crystals then to coils?
                    I don't know.
                    • It is a mechanical converter of mechanical pressure in the torque.
                      According to the author the simplest construction.
                      • [VIDEO]watch?v=7TSYs8HJfMg&t=283s[/VIDEO]
                        ForAs we see the system from ICE, it is likely that two weights are used based on the flywheel.ce multiplier without speed reduction
                        Buenas Oscar Núñez, the montage you see in the video consumes more than it delivers, we have modified an engine to make it a magnetic generator, obtaining poor results, compared to the engine that you plan to build. I am a friend of the flywheels, it costs more start it but then it helps to overcome any brake that occurs in the cycle of rotation, you can also try to unbalance the v - gate so that the point where the cycle starts will help gravity, they are only ideas, the important thing is to try them and not you stay in the head, good luck with your work and you will tell us
                        • Free Energy Generator 100% Self Runing At home, Green Electricity at home, 230 volt 3KW | Flywheel Free Energy Generator 2017
                          [VIDEO]watch?v=geTve2mTerk[/VIDEO]
                          Flywheel Free Energy Generator for Free Electricity
                          [VIDEO]watch?v=02hb6ss1xW4&t=102s[/VIDEO]
                            I guess people can say anything, post anything, call it free but I see
                            ac cords running everywhere. Not saying it is not free, but he has no
                            name and those are not his video's, probably afraid? Of being X out?
                            Anyway the previous ones with the truck flywheels are cool but no
                            English, no way to understand how they are getting the free stuff into
                            their grinders.
                            And you have one also? But are afraid to show it? Or did you show
                            yours already?
                            I do not see anything that helps me see how to get the extra, just
                            motors and modified generators? I think modified? Yes?
                            It is possible to modify a generator to run as a motor and generator
                            at the same time without any flywheels, so this leaves me to wonder.
                            I should read a book first because my understanding on flywheel
                            energy is so small.
                            Thx 4 the vid's
                            • https://www.freeenergyplanet.biz/free-energy-devices/info-czm.html
                              Just skimming thru the claims with no validation whatsoever on how
                              someone can explain where and how this special setup bring in the
                              magic.
                              Another book giving an overview? All you need are loose belts, JOKE!!
                              https://www.onlinejournal.in/IJIRV3I4/150.pdf
                              https://www.youtube.com/watch?v=7sz67RqIl0g
                              [VIDEO]https://www.youtube.com/watch?v=um-yaVK9wlk[/VIDEO]
                              • Free energy wheel charges cell phone, hum...............
                                [VIDEO]https://www.youtube.com/watch?v=OvlBNYONmDo[/VIDEO]
