TinMan's magnets doing the impossible [useful work]
Dear All.
My " tangential " approach !!
Look before you leap !!
https://www.youtube.com/watch?v=XK3vYAIjd7s
https://www.youtube.com/watch?v=D_zbggaXR7k
https://www.youtube.com/watch?v=LMGcFtH18hE
https://www.youtube.com/watch?v=Bp8_iVQIYwE
https://www.youtube.com/watch?v=Hn17OKYr_SU
https://www.youtube.com/watch?v=BIpCVLvieq0
https://www.youtube.com/watch?v=w-vrwzcZmBw
Cheers Grum.
Hi grum
Fantastic work bravo
just 2 questions
first
It seems that when the plate enters in attraction with the outer fixed magnet, the acceleration is very low.
Is it perhaps because your plate is too massive to be accelerated by your small magnet and does not get the necessary momentum ?
second
In Brad configuration , when the plate leave the Dead center, the 2 magnets are organized to be in repulsion before the axle of the crank passes its dead center . And i think this moment is the most important timing point on this machine.
And on your design (video 5) it seems on the contrary , that the crank axle passes the dead center before the repulsion of the 2 magnets?
Just my 2 cents by observing the videos, i don't know if it is important but just a consideration.
Good luck to you
Laurent
Hi Chet Grum and Shylo
some time ago Stefan Hartman (Hartiberlin at OU) has made an english traduction of a video of Lueling permanent magnet motor from 1960.
It seems that the video is very relevant concerning Brad's design.
Lueling uses 2 quarter of a drum (plate ) and Brad uses 1/2 drum
https://youtu.be/Lks8N-_dQLs
What do you think ?
Laurent
just 2 questions
first
second
Good luck to you
Laurent
Many thanks for your compliments and observations .
Brad did mention via PM that I had deviated a little from his concept, hence the use of the word " tangential " !
It is a work in progress, domesticity has had to come first. I agree that there's probably more mass to the rotor than is necessary, so for starters I'm going to remove the unused portion of the G.O.E.S. above the centreline.
The next job will be to create a linear action of the moving magnet against the con rod. Brad used a very long swing arm that reduced the ellipse to a minimum. I was looking for a neater approach with all the " gubbins " under the bonnet, so to speak. This approach, however, created a greater arc of the moving magnet.
I have now thought of a way to get the con rod moving in a linear manner borrowed from the early steam engines, a half trunk guide but using a ball race to reduce friction.
Spare time is rather scarce ATM, I will try to improve the device as and when.
Kind regards, Grum.
Thank you
Laurent
Thanks for sharing Stefan's translation of the Lueling.
it certainly needs more eyes on it.
started a Topic here also
Stefan translates the Lueling magnet motor Video
respectfully
Chet KIf you want to Change the world
BE that change !!
Hi Woopy,
Did you notice the spring loaded piece of steel at 5.08 and again at the end.
That is how I've been trying to neutralize the sticky spot.
Thanks for this video ,I believe it is authentic and reaffirms that I'm on the right track.
artv
Hi Shylo
yes i have notice the spring which IMHO should probably help the steel shielding to move around the magnet the more freely as possible, so almost no energy is taken from the shaft to activate the shielding.
I am trying now some systems to get this free movement, but it is not so easy at all.
Any ideas ?
I am also trying to study Brad's device. I wonder if Brad design would spin with the electric prime mover disconnected ? (I mean self running as Grum is trying to do).
And if not , is the prime mover acting as a helper for the shield to pass the sticky point ? And in this case , what mixture organizes the decrease of current ?
Good luck to all
Laurent
