Originally posted by BroMikey
Keshe Blueprint
Tao
Originally posted by DeLorean View PostIs that a quote to shutdown forums?
I think this can be interpreted in many ways. My interpretation would be:
"he who knows does not speak, but shows to convince (in his way of living; conduct and with doing proper measurements);
He who does not know has to speak to convince (because he doesn't know how to show).
this is IMHO the TAO, "the right way".
Originally posted by BroMikey View PostIn this video Doc Keshe talks about Plasma
No food needed to eat because our bodies can be nourished by
direct exposure to plasma. Sounds like what happens when you
are an angel.
Also space flight or anti-gravity effortlessly, again like angels.
This man is seeing into the time to come so that time must be
very near when world powers will be removed due to their
unfaithful or abuse of power.
Give me some of that yummy plasma, and I am not kidding.
Originally posted by DeLorean View PostBroMikey, why canīt you see that Keshe has no PhD and is no Doc at all?
Care to try that again? I am not saying Keshe is the free energy Messiah.
What I am in favor of is seeing folks try each mans ideas. Our biggest
problem is we listen to the Gov controlled Universities who say it isn't
possible to long.
Shame on us for not doing the experiment or becoming an observer
of the experiment. No we don't do that. Teacher told me this and teacher
told me that is what we have been programmed to gulp.
Originally posted by BroMikey View PostI don't know. I forgot that all great men needed a PHD. Sorry I forgot.
possible to long.
there are hundreds of replications running just now. If there are no positive results at the end of November it will show that itīs scam.
Letīs wait and see. This time there are more than enough replicators for the blueprints.
Why?
Itīs cheap, it doesnīt need expertise, it sounds too good to be true
... we shall see soon ...
labels
Originally posted by BroMikey View PostThat is not very gentlemanly. No scruples Hey? Do some experimenting.
I don't like labels. We are all unique humans, and "labels" are just meant to polarize, to create "us" versus "them". I believe in "we".
I am happy with different views, as long as nobody wants to force his/her views on me.
take care
Ben
A new truly altruistic act, disclosure of great knowledge for the masses:
Carolina De Roose
September 13 at 10:04pm ·
You have co2 washed
You put in small container
You add a little bit of water
Plus a bit of aluminum foil
You add the herb you want as a drop in it or a leaf what you want to add
You add dry coustic
You shake
You let it go over night the longer the more it grows
You can extract some of the mixture and let it dry like a paste
Not to dry
Your spring from copper you can make like you want but fine that is nano coated
Trough the classic coating process
You put the tip of your spring in the paste and let it dry
You take a normal writing pen you open it
Remove the pen you write with
And place the nano coated pen with the tip in the tube of the writing pen
that is white from the paste to words the direction you use a normal pen
You make sure it is not sticking out the pin
And seal it with some silicon
You
You point the this on the person where he has pain each pen is personally you can't pass it on to someone else this becomes your healing pen
In the back you can add a small plastic tube with washed gans liquid seal the small tube with silecon Boulder ends
You can place this in the back of the spring in the pen
That creates food for that person
Nobody needs to hungry anymore
There you go you have a perfect pen
Keep your toughs clean and clear when you make the pen and give from your soul
The blessing from the pain relief will create
The progress for your work
Be blessed with the gift
You put co2 gans paste and spreading it like on a bread in a plastic sealed bag you put a nanowire in it not to much tic
You seal it and use it together with the pain pad
It is on believable what results you get with this combination
This disclosure can be found at https://www.facebook.com/Keshe-Found...468892/?_rdr=p
Please, try before you buy!
Slick
Originally posted by SlickDick View PostA new truly altruistic act, disclosure of great knowledge for the masses:
for that so I can take away Ernie's excuse.
https://www.youtube.com/watch?v=bockRM5gn5kLast edited by BroMikey; 11-10-2015, 08:24 PM.
Mike,
I very much like not to take credit, and i will. It is not my research. I am just the messenger, by no means the message. Sharing is caring brother!
But i donīt think you appriciate the gravity of the disclosure made by the Keshe foundation today. This pen device will produce food!! How about that!?
All the best,
Slick
bodies, correct? I mean that is not so hard for me to grasp. We absorb
all kinds of energy into our being coming from the surroundings right now.
Such as the radionuclides coming from the Fukushima plant.
Maybe you could shed more light on a subject specifically applicable?Last edited by BroMikey; 11-10-2015, 08:39 PM.
clouds a-rolling in..........
Jason Verbelli, one of the key individuals attempting to replicate Searl's work has posted some disquieting information about Keshe on PESN here. Apparently, on-camera, Keshe first offered to fund the Searl research to the tune of $3,000,000 - but off-camera, admitted that he didn't have any money for Searl's work, or anyone else's for that matter, and then had the gall to suggest that Verbelli's and his team should switch to researching Keshe-tech instead, at their own expense, naturally!
Worse, an electrical engineer, Fernando Morris, was in Italy in June 2015, and volunteered to look at any of Keshe's 'plasma-reactors', but Keshe said that he didn't have any available! However, once Morris was safely ensconsed back in the US, Keshe suddenly conjured up KW's of plasma-reactors from somewhere, which happily, also operated independently of the grid - so, from zero to hero! Not looking good.
This guy already built a unit and testing in progress. Seems to be in a positive direction...regards
https://www.youtube.com/watch?v=MiYbrQUyhfo
