Increasing Electromagnet Force
  • Increasing Electromagnet Force
    We have a new paper out, its the 5th and its called "Increasing Electromagnet Force".
    It focus on the force per power ratio in coils.
    Since the concept of an electromagnet is present in both motors and generators we find it interesting to study the relationship between the parameters describing the electrical power the coil consumes and the mechanical force with which the coil attracts a piece of ferromagnetic material or a magnet.
    The amount of copper in an electromagnet determines the force per power ratio, not the number of turns or the wire thickness in the coil, the more copper the greater force.
    To get the best performance in an electromagnet it should be as big as possible, which leads us to believe that motors should have as few and big coils as possible (think Joseph Newman) to increase torque per power. We also believe that the reverse is true, that generators should have as many and small coils as possible to decrease torque per power.
    You can find all papers here:
    https://sites.google.com/site/nilreh...entary-physics
    /Hob
    Hob Nilre
    I also did a short video on the subject:
    https://www.youtube.com/watch?v=IIeRR6NjMPQ
    /Hob
    Hob Nilre
      Originally posted by nilrehob View Post
      ... that motors .... to increase torque per power.
      Simply means to decrease frequency.
      .... that generators ..... decrease torque per power.
      Simply means to increase frequency.
      What works for one, works for other; motor or generator. And frequency relates to pole count and RPM.
        I don’t understand how that relates to my paper, can you elaborate?
        /Hob
        Hob Nilre
          Valid conclusions ???
          Look at the last paragraph.
          A valid conclusion. Some might say obvious, but I appreciate the treatment. And this would apply to a motor in a stall condition (zero RPM). A generator at zero RPM doesn't make any sense.
          However, for dynamos operating as converters of energy (motors or generators actually rotating), that part of the paragraph is invalid, in my opinion.
            I would be very interested in any evidence or logic behind your opinion. Can you elaborate?
            /Hob
            Hob Nilre
              /Hob
              Hi Hob,
              You can't argue with Power = Torque * Rotational Velocity (frequency or RPM), can you? Then my post #3 stands. I disagree with how you relate your paper to dynamos. If you were correct, then motors would tend to be very slow machines and generators be very fast machines which is clearly not the case in practice.
              You are the one putting forth the hypothesis; the burden of proof is yours. My experience tells me that your second quote in my post #5 is an invalid conclusion drawn from what may be a completely valid paper. I am not arguing the paper.* edit: I just rechecked your paper and see that the paragraph to which I object is in fact included as 5. Conclusion. So I guess I do take issue with your paper.
                Hi Hob,
                Have you noticed that the torque to power ratio differ between different motors?
                That the ratio gets higher as the motor gets bigger?
                Do you agree that its beneficial to have a motor with high torque to power ratio?
                Do you agree that its beneficial to have a generator with low torque to power ratio?
                /Hob
                Hob Nilre
                  Motor questions
                  Sure, it varies with the speed of the motor.
                  It is actually the other way round. The higher torque motors need to be larger as they require more flux and/or current density at the air gap.
                  Often times the higher speed motor with a gear reducer makes more sense for a high torque application. Ever notice the EV motors? Small for output power and high RPM while being very efficient.
                  No.
                  No.
                    No.
                    No.
                    OK, but I'm glad you liked the paper.
                    /Hob
                    Hob Nilre
                      Minor changes to paper 1-4,
                      paper 5 had the experiment redone with more coils.
                      /Hob
                      Hob Nilre
                        I like your utube NILREHOB , i could not track the experiment with the bifilar winding..
                        But i have posted an idea that will increase the magnetic field..Let me know if it will work.. i will test it myself using the clear plastic tube, that was simply brilliant..
                          You should absolutely do your own tests
                          Otherwise, please look at our tests with coil d and g in the paper.
                          /Hob
                          Hob Nilre
                          • #14
                            Parameters
                            /Hob
                            Hello nilrehob,
                            Interesting, however, I am mindful of the need to hold a parameter constant so as to test other conditions, etc. You make the assumption of increased copper. As you might know silver is a better conductor than copper. I am attaching an old study into electromagnetics by Klopsteg. Perhaps you have heard of him. His study uses a few tricks for the purpose of novelty. However, there is no mistaking Klopsteg has a scientific mind. He has kept the Iron mass constant. which you do not seem to do in your experiments. I could be wrong there.
                            Another area you might want to investigate where I am looking for time to explore is the use of Heusler Alloys as core material for electromagnetic fields. Iron has the 2 tesla limitation. Whereas one of the heusler alloys with manganese does not have this constraint.
                            Enjoy! Klopsteg is fun especially as a teaching aid!
                            https://books.google.com/books?id=wN...hanics&f=false
                            Dwane
                            • #15
                              There is a new version of paper 5 out with added sections.
                              Paper 1-4 have only minor changes.
                              You find them at:
                              If anyone would like to help with spelling, grammar, wording, content, whatever,
                              please go to github and contribute:
                              https://github.com/boherlin/elementary-physics
                              We have also made a bitcoin-account for donations.
                              But we're not sure its working, no donations yet..
                              If anyone could send a tiny-weeny satoshi we would be thrilled.
                              Account number at the end of the papers.
                              /Hob
                              Hob Nilre
