Originally posted by Sputins
Start by a simple fact...a North and South magnetic fields in one magnet are both spinning in the same direction, same axis...but this is not like a motor spinning...but, in space this curvilinear spectrum describes like a cork screw shape, not spinning, and what is moving are the magnetic particles within that spatial curvilinear spiral, basically the centrifugal which is the strongest end.
Now, when we face N-S from two different magnets, say same spec's, then both cork screws from N and S embrace within same particle spin, say you keep a gap...whether air, plastic or iron...the same spin prevails there no matter what you insert in between. This is exactly the same Interaction that takes place in the very center of every magnet.
When two magnets are attracted together they configure (add) into a newly formed magnet, stronger than the original two...double the strength.
Looking from the dielectric wall...once the two magnets are bound together, those two poles in the attraction gap literally disappear...(actually they bridge from one side to the other, meaning the South will enter the other magnet's South, as the North at gap will enter into the second magnet's North) this process that Ken calls "voidance" means just that...both poles at gap "disappear" strengthening outer extreme poles...and so, the new formed dielectric would be now at the gap where the two magnets were bound together.
Spatially, this new formed magnet will be stronger than just one...so the CRT captures exactly the right image...field increases spatially...
And this Expansion process works as soon as we start approaching two magnets by their alike poles. New, future Dielectric Wall would be exactly located at the very center of that gap between both opposed polarizations, no matter the distance between them...However, the closer (narrower gap) the wider the expansion would be.
In a Repulsion the completely different interaction takes place...first, both cork screw spins are Opposite, Counter Embracing each others...and the only difference between a North or South Spatial repulsion Interaction is the directions of their spins...and here I know this sound weird...what direction if both are counter-spinning right?...Ok, the way to figure this out is to imagine a "twisted body" right at center gap of repulsion will model kind of a threaded shape...well, North and South repulsions would create opposite threaded bodies...(like one Bolt...would be a right screw thread and the other a left screw thread) hope this example will be clear.
I am putting together a video about spatial interactions seen with all known methods...from iron particles (already familiar with) to ferrocell , view film and CRT...and it happens that all three modern methods are opposite in 180º to the iron old method...there Repulsion creates a "Sphere"...while Attract creates that four points star cross (a pattern I conceived to compare interactions) like iron particles reflect on repulsion.
So, the actual repulse pattern is a sphere of compression between like poles...just like iron shows on attract...
Could it be we all have been 180º wrong because using only the dogmatic iron particles?
What do you think?
Sorry, don't want you to have more sleepless nights...and hope this will enlighten somehow...
