ENLIGHTENED MAGNETISM (The Full Proof of Ken Wheeler's Theories)
    This shows a lovely uniform field which crosses over.
    • Magnetic field lines
      Except magnetic field lines never cross.
      • Exactly Bi, that was the reason I showed it.
        John.
        • Interpreting 2D Images which are 3D.
          Hello,
          Ferrocells show a 2D Image which is from a 3D Field, this results that all different depth levels of lines seems like they "cross over" with each others.
          Like Markoul wrote SEVERAL TIMES HERE before, 3D Field Layers OVERLAP in 2D.
          Any WIRE FRAME IMAGE of any volume, when reflected in a mirror, shows like all wires are "overlapping".
          And like I wrote before...it takes a BRAIN to understand this fact...then build the full model in your mind...
          Only thing is...some "minds" can not do this Operations because they will overheat...and may blow main fuses...
          • The ferro shines nicely like a convex mirror in low flux density areas and cone texture found along edges first, in water the smoothness different.
            https://youtu.be/kL8R8SfuXp8
            If the evaluation of ferro cell images are responsible for brain meltdown in person's having less visual comprehension this can reflect on the explanation.
            The implication is that such a person requires enlightenment to open visual brain channels as a prerequisite to the secret of enlightened magnetism.
            If the written book turns into a verbal academic debate and the effort to help an individual to acquire the visual ability is ridicule then the strategy of presentation style should adjust toward less visual persons.
            • You're not able to grasp the problem.
              When you look at the microscope the tiny magnets are FLAT.
              IE. parallel with the glass.
              The effect you see is the same as if you had a flat sheet perpendicular
              and plotted what a tiny compass would see.
                • Do you agree that really the tiny particles would line up with the field
                  if they could.
                    • Only thing is...some "minds" can not do this Operations because they will overheat...and may blow main fuses...
                      ahahahahahahahaha...hahahahahahahaha...hahahahhehe heheahahahah! aaaahh
                      MSc. Electronic and Computer Engineering, TUC, Greece
                      • Right, how can you make a magnetic polariser if your lines twist.
                        Perhaps a bit of fuzz round a rod aerial might help?
                        Hahaha!
                        • You can see how well it works at polarisation if you look at Timms video
                          using a laser, beams shoot out from either side.
                          • Hello! Anybody Here?...
                            That's not fair!
                            Where are you?
                            I came for my daily debate!...
                            kou kou!!
                            You must have run out of arguments!!? he!...
                            bye
                            EM
                            • 2d 3d
                              Hello,
                              Hi Ufo,
                              Big difference on that wire frame analogy. The wires are visible. The magnetic field is not. So how do the invisible magnetic field layers or levels not in contact with the ferrolens become visible?
                              It is like a book where the ferrocell is page one. It has information (words, diagrams, etc) printed on it and that information is visible to the reader. Page two is hidden (assume single sided printing) since the paper is opaque. Now make the pages from transparent film. So the information on page two can be seen through page one, or page one appears overlaid on page two. Now do the same with pages 3, 4, and the rest; print the information of each page on transparent film. So when the reader opens the book cover, he sees all the information, layer on layer, all at once.
                              This is how I perceive your explanation. Like the book printed on transparent film pages. But the big problem is that with the ferrocell, only page one has visible printing. Pages 2, 3, 4 and the rest use invisible ink. With the ferrocell, the only layer of the invisible magnetic field which imparts any information to the ferrocell is the layer in contact with the ferrocell. All other layers or levels of the magnetic field are invisible and cannot possibly be represented by images on or projected by the ferrocell.
                              The story you and EM give about layers and levels of the 3-D magnetic field bring projected in, or on, or by the 2-D ferrocell is false. It is your imagination or optical illusion.
                              • Originally posted by Markoul View Post
                                That's not fear!
                                Where are you?
                                kou kou!!
                                bye
                                EM
                                Markoul,
                                Why did you do that!!!???
                                I was having a very quiet Sunday evening!!....till now...
                                See, now you waked up Bistander!!
                                hahahahahahaha
                                But is ok...am going there, now
