A Rough Sketch...
Hello Again,
This is the main idea about the second project...in the below rough sketch:
[IMG]
[/IMG]
However, this was one of the first designs I started working with...so, there have been several modifications to the inner armature structure.
But I think it will give you an idea of what I did...
I have just set the brushes and commutators from the power rotary switch on top for easy understanding of it...however, in reality I have it set remotely and transferred through wires into the windings for easier understanding of the whole device.
The winding inside the armature is NOT Asymmetrical, but Symmetrical with just one commutator. The reason why is very simple...we can NOT ALLOW that Field to Collapse as it will RESTART a New Magnetic Spin Cycle from zero...please refer to my previous Graphic-Post about Magnetic Cycloids.
The Symmetrical Winding do not allow the field to ever collapse. So, it is just a STATIC Symmetrical Armature wind, where we are spinning their brushes around a FIXED commutator.
By spinning just their connected and feeding brushes, we will be spinning JUST THE VIRTUAL FIELD within the STATIC Iron Core inside the STATIC Generating Coils from the Gen Head.
It is just the Reversed Engineering from our old knowledge about Symmetrical Motors...where Brushes kept the Main Virtual Field Static through their geometrical plane, while the Iron Mass Armature would spin... simple, we reverse the process in order to get the Virtual Field to spin along with the Brushes Geometrical Plane while the Laminated Iron Rotor Mass is static. These Motors were designed to Project their Field towards Stators, so I find them perfectly suitable for this primary development purpose.
I used continuous slip rings-brushes from an old car Alternator to constantly feed them, which is part of the Rotary Power Switch Assy.
Hope it is more clear now...
Hello Again,
[IMG]
