Dielectric Field Mapping...
Hello to All,
I could not forget about the main essence of this Thread Theory...
Therefore, I could not forget about analyzing the Dielectric Field on this set up...
If We all notice on the Image above...I have kind of "bleed" the Magnetic Polarities according to Rotation Sense (Green Arrows) by "over spraying" the colors on the following "stepping in" iron core elements movement...and this is the way it happens in reality, either we decide to picture it as "Flux" or whatever other name we choose.
But the Main issue here is NOT about Magnetic Field Flux leakage according to Rotation...but, about the Dielectric Field.
The curved Green Shadows on BOTH SIDES of the Static Armature, at the exact center of each set of Coils Groups... are The Two Dielectric Fields that we are Generating and Rotating.
Remember in this Theory, Dielectric Field is the Origin and the return of All Magnetic Field Spatial Polarizations.
The same way the Magnetic Polarizations shown at the Loose Centered Iron Rotor, is just a Result, AN INFLUENCE from the Two Main Fields generated at both ends of the Static Armature...The Dielectric Field at Rotor is also JUST A CONSEQUENCE, A REFLECTION As a RESULT from the Two Main Dielectric Fields Spinning.
Which means -in general speaking- that the Virtual Spinning Fields generated at the Static Armature are the "Masters" as the consequential "Image" seen at Rotor, is just a "Slave"...which in Computer Language means:
"The Slave always follows the Commands from its Master"...
Regards to All
Hello to All,
Regards to All
