Originally posted by bistander
It "was" a good and quiet Sunday evening!!...
Just kidding...
![Smile](http://www.energeticforum.com/core/images/smilies/smile.png)
Magnetic Field is invisible to our eyes, BUT NOT to the Ferrocell.
Ferrocell "sees" the whole 3D Field Volume, and I mean the whole thing...even the further layers...then print its view into a 2D Image.
Ferrocell is sensitive to Magnetic Field, it reacts and realigns according to the magnetic Field positioning based on its Viewing Capturing Angle.
First off...a book is a reading object, always based on 2D Text and Images.
A 3D Wireframe is much closer to a 3D Field.
But I agree that the wireframe is not that good of an explanation to understand how Ferrocell works...so here is another analogy, which I have mentioned before...
PHOTOGRAPHY AND LIGHT SENSITIVE CAPTURING DEVICES
The sensitive film captures a 3D Image of reality through the camera lens and then takes it into a 3D Flat Print.
On a Photograph you can clearly see/define in depth images which are further away from first plane images.
If you set your lens adjustment to "infinite" capturing, then ALL objects will appear "in focus", no matter how far away from the camera they are.
However, if you adjust lens to Focus on first planes only...then all far away objects would appear blurred or "out of focus"...and there would be a point, where the furthest objects would just appear as "blemishes, or spots" which contour lines are not defined, but faded away.
Ferrocell does exactly this second adjustment, where only immediate second planes would be "in focus" while the furthest away would be blurred out and darker, because of the reach of light as well.
And so even a best analogy would be the "Imaging Sensor" from a Digital Camera...
![](https://imagizer.imageshack.com/v2/1024x768q90/924/9jQYZX.jpg)
Only thing...is that above sensor is only sensitive to light...and Ferrocell is only sensitive to Magnetic Fields.
What or Who gave you such info?
Your lack to interpret Magnetic Fields True 3D Imaging...simply relies in your very low knowledge about Spatial Geometry plus Imaging Perspective Basics and Fundamentals Interpretation...mixed up with a very low capacity to build in your mind 3D Models, before taking them into prints, 3D CAD's...or paintings.
And just because you have a very low perception about 3D Volumes Interpretation...does not grants you the right to deny others who can clearly do, plus show others how to understand it.
First Career I took when I was a kid...was Architecture...and it does helps a lot for this job.
