Radiant spike puts out more than current
  • #61
    Hi folks, there seems to be several different methods for collecting the spike.
    I would like to know what is considered the best and why.
    In my testing I've found that using just diodes and caps causes no drag and can store many times what a coil can provide with just the conventional bridge and cap.
    I think it all ties in together ,Figurea, what Luc is doing, what Tinman is showing and what Chris Sykes is showing with the partnered output coils.
    I think people should put aside their differences and discuss what is at hand.
    Every time it seems were getting close , a whole bunch of arguing shows up and throws everything off track.
    Learn to get along people, just because we don't agree with each other doesn't mean we have to be *******s towards each other.
    Try seeing things from the other persons perspective.
    A self runner is just a matter of time
    Collecting the spike is the first step. IMHO
    artv
    • #62
      Not worth the bad feeling I get.
      People that treat other people badly don't change anyway.
      Last edited by OrionLightShip; 12-17-2015, 07:12 PM. Reason: Not worth the time or breath
      • #63
        artv
        You're right shylo.
        If someone has something real they want to show..... that would be great.
        • #64
          Mikey
          your Vid above is part of a measurement analysis series for a "magnets can do useful work" claim by TinMan.
          here is a link to the thread.
          Rotating Magnetic Field's and Inductors.
          respectfully
          Chet
          Thanks Chet
          I missed some of this stuff pertaining to Pat's board discussion since
          Pat gives credit to where credit is due, others honesty which remains
          to be seen and TinMan also credits Bedini for his work on the subject.
          Just because the Bedini patents are running out it looks like the cut
          throat hoodlums are copying and pasting their names onto this great
          man's work.
          A bunch came over on the boat can copy and paste better than me.
          No matter, I won't let them get away with that.
          Yes I see the divisions on the scope and it has been pointed out
          by Tinman that he is getting the extra at such and such location
          on the dial. TinMan is an honorable man and like Pat
          freely gives the answer when they find something.
          Bedini predicted that the rats would come out of the woodwork
          to re-tag his work different names.
          As for the rest the honorable tendencies coming from the next
          generation remains to be seen. Bedini pioneered this spiking
          motor/generator back before these whipper snappers came out.
          Thanks Chet, you are a blessing. Whatever happened to Keshe?
          No, don't answer that question.
          Where have you been? I haven't seen you in a "COONS AGE" as the ole
          saying goes.
          • #65
            Diac in place of 1N4007 collector diode.
            @Minoly,
            Consider replacing the 1N4007 diode from the collector to the auxilliary coil LC tank with an "Alternating Current Diode". The original diode is probably blocking half the oscillating sine wave, and a "Diac" might double the power and pulse frequency of the auxilliary coil.
            Replacing the TIP3055 transistor with an SCR may help improve performance even more:
            • #66
              Magnet core.
              @Minoly,
              On top of the SCR and Diac, you could try and wrap the auxilliary coil "Series Connected Bifilar" and try packing the bore hole with a diametric tube magnet core. Naturally, it would still need the capacitor in parallel. This is the "Synchro Coil"! This magnet core LC bifilar coil will generate it's own power spontaneously from the tank oscillation.
              • #67
                Electromagnetic launcher.
                @Minoly,
                Here's a pulse application of an SCR driver. The driver's visible inside the box. Your D.C. input power is in the same range:
                Power source 3 volts D.C.; Capacitor charge 480uF; SCR driver:
                https://www.youtube.com/watch?v=6nowIn-QdbE
                • #68
                  Crystal hammer
                  @Minoly,
                  Look at this "Piezo-electric" generator from "Rapadura" at OU forum: Your pendulum magnet could strike a "Piezo-electric transducer", and send a charge back to the auxilliary capacitor.
                  • #69
                    Magnetic Resonant Amplifier.
                    @Minoly,
                    Joel McClain & Norman Wootan determined the fundamental Ferromagnetic Resonant Frequency as being around 174.9 KHz.
                    Wraping a Ferromagnet in a wire coil and coupling a capacitor to achieve a self resonating LC tank frequency of 174.9 KHz can generate overunity power! This would require your primary oscillation to match this same frequency of your auxilliary LC tank! Not a problem with your setup.
                    • #70
                      @Minoly,
                      The "Magnetic Resonant Amplifier" is a very simple circuit: Your SS SSG is already a tunable low power oscillator!
                      "In the MRA schematic below, there is a tunable low-power oscillator which supplies a signal to one side of a barium titanate transducer. The opposite side of the transducer is connected to a primary coil which is wrapped around a barium ferrite magnet core. The opposite end of the primary goes back to the oscillator.
                      A secondary is wrapped around the primary and is connected to an ordinary bridge rectifier, and the output of the bridge is applied to a DC load".
                      • #71
                        Capacitor for Piezo element. SS SSG MRA.
                        Tinselkoala demonstrates how the Piezo element turns the primary of the "MRA" into an LC tank by replacing it with capacitance: An important feature of the "MRA" is matching the self resonating frequency of the LC tank to the frequency of the tunable oscillator. The primary of the LC tank is wrapped around a magnet core. This setup amplifies magnetic resonance when tuned to the ferromagnetic resonant frequency of around 174.9 KHz. Minoly dosen't need the Piezo transducer because he already has a capacitor in place to form the LC tank. All Minoly needs to do is wrap a ferrite magnet with his auxilliary coil and tune the oscillation to the ring frequency of the magnet. The diametric neo's have a "Ring Frequency" in the 180 KHz range too. Capturing the "Backspike" boosts voltage by hundreds of times in Minoly's circuit, and should amply substitute for the barium titanate piezo transducer in the MRA.
                        https://www.youtube.com/watch?v=8wLCoQoFCjE
                        • #72
                          I thought the pendulum as an instrument is good idea.
                          The work performed by an impulse wave
                          can be measured if you slow down the rate.
                          • #73
                            [TIP3055] and Diac.
                            The Bipolar Junction Transistor [TIP3055] does a fine job generating an A.C. signal from a D.C. source. It was my mistake to advise replacing it; However the 1N4007 diode off the collector is a rectifier diode and only passes one half of the power wave. The MRA needs a full sine wave to function and would require an A.C. diode or (Diac) in place there to work! This step should double the power of Minoly's current configuration too.
                            So, all it would take to convert the (SS-SSG) to a (SS-SSG-MRA) would be to replace that diode, then fill the auxilliary coil core with magnets and adjust the frequencies for magnetic resonance. At that point, it would be possible simply to wrap the auxilliary coil with a secondary winding and power a D.C. load through a full wave bridge rectifier.
                            • #74
                              Originally posted by THEminoly View Post
                              Erfinder, by this might you be suggesting something similar in nature to John Bedini is doing with his Ferris Wheel – if so, now I might have some direction as to what you are talking about…
                              You better know where this is going Patrick! What you are doing has been done. What you are showing, was perfected and presented to the world in 2010. I was there, I touched the machine. It took me a while to figure out a few things. Immediately after that conference I rewired my 12 coil machine so that it was configured like the hub motor in the Ferris Wheel. The potential induced by the collapsing magnetic field was processed and routed for reguaging, finally the processed energy was sent to a second set of coils, those coils had a positive influenced on the rotor. That being said, that which you are now asking folks to consider, I began considering in 2010, and have spent the last 5 years perfecting my skills and comprehension of that very specific concept.
                              Even though my retrofit was successful, not yet yielding a self runner, I consider myself successful in the sense that I was comprehending the mechanism. In the course of my studies, questions came up which demanded answers. There were instances when I tried asking these questions publicly, but that got me nowhere. So I took responsibility for my ignorance and answered them myself.
                              What is the "Self Reguaging Idling Magneto"?
                              It would be cool if you were prepping folk, trying to get them to think about the real practical applications of redirecting the spike, preparing them to come face to face with the best example the community has seen but didn't comprehend. Word of advice, stick to spike, don't use radiant in your presentation. Reguaging is a neat way of saying hey stupid, current in equals current out. The current coming back "can" be sent to a battery, capacitor or whatever. It can also be sent to a second set of coils. This second set of coils are energized by the current you already paid for during the circuit on time, the same amount of work being accomplished when the system was storing magnetic energy can be accomplished when the circuit discharges the stored magnetic energy. Effectively this turns a pulse motor into a two phase machine, when properly configured so as to take advantage of the second phase, the discharge phase.
                              Almost 6 years ago, we were given a self running machine people.
                              Unicorn poop you say......F****ing idiots!
                              • #75
                                2010 released SELF RUNNER by John Bedini snippet PART22
                                Unless people understand the magnetic gating action on this new
                                rig of John's, they don't have what John has. Ceramic, rubber and neo
                                is what John states here. Howard Johnson's work engineered into
                                the Ferris wheel monopole with a HIGHLY MODIFIED "BEDINI/COLE"
                                circuit to top things off.
                                Yes you have 'Unicorn Poop" until I see the magnetic gates John talks
                                about here. The secret given away that day was based on
                                how the specially made magnet stacks will flip polarity when hit with
                                a spike and then ANOTHER spike is sent to return the gate to it's
                                original position waiting for the next pole to trigger.
                                This is where John directs the group to watch the wheel violently
                                shake when it flips the magnetic gates over and back again. He
                                points out that this is where the huge COP increases come from.
                                Let's see it. If the people want the full answer let them buy PART22
                                I'm not going to violate John's copyrights.
                                People you are not going to fool anyone but yourselves and
                                especially not Pat, sorry. Cat got yer tongue? What is your
                                answer? What?
                                Hey, we are to smart for that here so maybe you want to try again.
                                No I'm not trying to be witting, funny, cool or anything of the sort
                                and proceed to lie in your face. The smooth talker is over there but
                                he ain't fooled no one.
                                And watch your dirty mouth.
                                John goes on to say at around the 50 minutes mark that the center
                                cole motor with the pie shaped magnets was an experiment of his
                                and Peter. This small motor in the center was keeping the electronics
                                pumping and the wheel idling and getting a decent 1:1 COP you guys
                                know that who are hard core experimenters, you don't need me to tell
                                you that a spike SSG gives you extra in the form of mechanical.
                                Come on.
                                then
                                goes on to ask if anyone bought the HOWARD JOHNSON dvd series?
                                John takes the big wheel out of idling mode and asked the people
                                where is the power coming from?? Points to the large angled magnets
                                at the end of the big wheel. Then tells you that the power comes
                                from the angled magnet stack that is a non linear magnetic switch
                                that flips when hit with a spike. Just like Howard Johnson's train
                                that went down the track.
                                Ceramic, rubber, neo and he said something about a steel plate, I
                                think was a sort of adjustable shielding directing plate to tune the
                                gates more evenly thru out the entire rig. Got to keep balance.
                                You are going to work to get this one.
                                Now that is what he said and I will stand on that, not that lie we been
                                hearing. Buy the whole set and see the answer, you won't get the truth
                                any other way. Just lies and more lies, that's it.
                                I'm not going to put up with it guys, sorry. And I'm not going to
                                post all of John's material for free, so suit your selves.
                                MAGNETIC GATES
                                This is no game to me. I don't play, I win.
                                [VIDEO]https://www.youtube.com/watch?v=NHNyRhnVhjc[/VIDEO]
