Originally posted by OrionLightShip
That was just a prop for the photograph. The axle holes are drilled midway through the coupling on the perpendicular, and one hole should be a little undersized to squeeze fit the sanded axle. The other photo anomaly is the position of the Reed switch pins. The pins actually face in the opposite direction, away from the coil. Approching the stationary rotor magnet with power connected to the normally open Reed switch can cause the contacts to close and weld shut. This can happen when starting the motor. You need to spin the rotor first by hand, then connect the power and approach the magnet with the Reed switch and coil while the rotor's spinning only!
