Oscillating Reed Switch Pulse Motor.
  • Infinite magnetic force.
    Magnetic locking force is a function of conductor mass, not input alone, so it follows that infinite magnetic force can be produced through an infinite conductor (Earth Ground). That's how our first wireless telegraphy worked; A spark of limited input has the power to magnetically lock a limitless number of coherers all over the entire planet.
    • "Earth Field Stator" Oersted motor magnet spinner
      The stack of axial polarized neo magnet discs is so powerful, it acts as a compass needle when freely suspended from above. The magnets can be nudged into spinning full circle, after orienting the current carrying wire towards magnetic north directly underneath the (magnetic north south) pointing magnets.
      "Earth's Magnetic Field" acts as a permanent motor stator for this kind of spinner! The magnetic field from the D.C. current in the wire that begins to deflect the magnet is as weak as the "Earth Field". The magnet rotor gets the powerful kick to spin it from the "Earth Field" pole repulsion at 180 degrees.
      A limitless number of "Oersted Earth Field Stator" motor rotors could be powered up to very high speed by oscillatory current between the "Earth Ground" and the antenna of "Magnet Power" reciever wires, acting like "Wireless Telegraphy" coherers. The limitless number of rapidly spinning "Oersted Earth Field Stator" motor rotors could be powered by the fixed input of a series of spark gap broadcast "Earth Ground" and antenna pulses.
      The frequency of the broadcast signal determines the exact length of the antenna wire to match the wave length. State of the art prismatic polygonal slot antennas can miniaturize this clumsy part of the reciever.
      • Joseph Henry type remote magnetization.
        I succeeded in remotely "Spark Locking" six 1/2 inch steel "Hex Nuts" with a loop of wire threaded through the center of the nuts and connected at both ends. This wire was the same length and gauge as the wire loop shorted between the 12 volt battery electrodes, and in close adjacency on the test bench.
        This was the kind of experiment Joseph Henry conducted at Princeton in the 1850's, where he managed to magnetize sewing needles at a distance of 220 yards between a primary and unconnected seconday antenna with an electrical spark from Leyden Jars.
        I'm betting right now that I can lock all 48 "Hex Nuts" at a few Hundred yards with an "Earth Ground" connected to the negative electrode of the battery, and an "Earth Ground" on the "Hex Nut" reciever antenna. The follow up experiment, after that, would involve multiple "Earth Grounded Receivers", each with sets of 48 "Hex Nuts".
        It should be no problem to fill an acre of land with grounded "Earth Field Stator" Oersted spinners, all running off the same series of relay oscillating battery sparks.
        • Great stuff! Following with interest.
          • "Earth Field Stator".
            @Bob Smith,
            Thanks Bob!
            The "Earth Field Stator" Oersted spinner runs at Overunity because the magnet rotor is propelled past it's North dwelling position by the momentum, and only needs sufficient power to push it from there to it's 180 repulsion position. Nearly all the power comes from the combined repulsion and attraction of the Earth's magnetic poles after the rotor's turned around. This force powers the spinner for two or three free rotations before additional pulse power needs to be applied. Lawerance Tsung calls this momentum "Lead out Energy" and has achieved OU results this way with his "Fung Wheel".
            I think the disproportion comes from "Shearing" into a "Perpendicular" propulsion.
            • Magnetic dip.
              The power of the magnetic force in the "Coherer" range is very low, on the leval of the "Earth Field". To fully maximize the combination, "Magnetic Dip" needs to be utilized. The spinner would get it's peak propulsion from a circle of wire positioned so the plane were tilted on the angle of magnet deflection: The spinner would move on an overhead throw. The pulse power for this kind of "Earth Stator Rotor" would be in the very low "Coherer Locking Range". It might take a series of pulses to get a full revoloution to start; However, very high speed would be attainable. We could bleed the torque off one while a coupled twin accelerated for constant output.
              • EZ spin motor.
                Lazersaber designed the EZ spin motor: Infernally simple and close to unity. All the coils are in series and it operates off a single Reed switch.
                Spinning axial neo magnets pointing to magnetic North, at declination within the air cores of toroid coils in series, also tilted to the "Earth Field Dip", could spin perpetually with one Reed switch, depending on the total copper mass in the power coils.
                This kind of motor could gather "flyback" and collect and loop output too. The "EZ spin motor's pictured below with it's solitary Reed switch and capacitor:
                • Lawrence Tseung's "Magnetic Pendulum".
                  The question here, as regards the value of the "Earth Field Stator", is; Does the pendulum in this video oscillate more with the repulsion magnet placed at the end of the arc, then without it, when dropped from the same height?
                  https://www.youtube.com/watch?v=NkBbjK7ED4A
                  • Monster rotor.
                    238 pound pulling force block magnet
                    BX8X8X8-N52
                    1 1/2" x 1 1/2" x 1 1/2" thick
                    Nickel Plated
                    Magnetized thru Thickness.
                    To the left below:
                    1 1/2" aluminum block bearing.
                    Ball Bearing ID : 1/2 in
                    Material : Aluminum
                    Height* : 1-1/2"
                    Width* : 1-1/2"
                    Thickness (Square) : .30 in
                    Thickness (w/boss) : 0.35 in
                    Boss Height : 0.05 in
                    Boss Diameter : 1-1/4 in
                    Finish : Tumbled
                    Mounting Holes : 8 Total - 10-32 thread
                    (2 top / 2 bottom and 4 face)
                    Eight of these powerfull block magnets, four on each side of two coupled block bearings (like below), would project nearly 2000 pounds of pulling force. This magnet rotor would be hard to deflect from the natural declination angle of the "Earth Field" when directed toward magnetic north. It would be over 1 foot in length; (13 1/2")
                    • OU argument.
                      At a very minimum, the "Earth Stator Rotor" will run at unity. Turning an axial polarized neo magnet stack 180 degrees off magnetic North by hand, and releasing it results in a spontaneous reorientation. This is free power.
                      The pulse from a tipped toroid power coil only needs to spin the rotor half way, and the "Earth Field" makes up the other half of the rotation for free. So, theoretically this rotor spins at unity!
                      Now, if we place a second one next to it and supply them both with "Earth Grounds" and "Antennas" we can spin them both for the same input pulse. That means together now we have COP of 2. Adding a second antenna would double the power to the pulse coil with no increase in input power.
                      The output from the first can power them both, so the output from the second is all gravy!
                      There's a legal limit to the size of the spark we can generate. This is the major limitation of the system.
                      • EMP generator.
                        Ludic Science demonstrates how to build an "Electro-Magnetic Pulse Generator" in this video:
                        https://www.youtube.com/watch?v=RZVGZ-6W05Y
                        Very primitive; To refine it, we would neeed to measure the inductance of the broadcast toroid coil, and calculate the frequency of the LC oscillation with the capacitance. The resulting frequency would allow us to construct a reciever antenna to the exact size of the wavelength.
                        Connecting the negative electrodes of both antennas to solid "Earth Grounds" would perfect the broadcast EMP reciever circuit. Ludic has one capacitor leg connected to the negative electrode of his high voltage generator. This would be identical to the early "Wireless Telegraphy" systems that locked the metallic coherers we're examining.
                        So the LC frequency and frequency to wavelength formulas, along with the "Earthgrounds" should power a set of "Earth Stator Rotors" with "Ludic Science's" simple design, like the early "Wireless Telegraphs" powered coherer recievers.
                        On the bottem:
                        "Wavelength (Lambda) is the wavelength
                        v is the velocity of the wave (default is velocity of light in vacuum: 300.000 Km/s)
                        f is the frequency"
                        Let's say you wanted a reciever antenna 3 meters in length. You would need to match a capacitor small enough to generate a resonant frequency of 100 Megahertz in a broadcast coil of any given inductance.
                        • Hall effect latching relay.
                          We need one last set of components to operate the utility. We need this kind of "Hall effect" transistor operated higher voltage relay circuit to interrupt the spark at magnet rotor TDC. This would require a nine volt battery to operate; The circuit's demonstrated in the video, and shown below in schematic form:
                          https://www.youtube.com/watch?v=Ys6u5fb8m-U
                          • High voltage Oersted effect causing a rocking at 90 degrees.
                            I suspended the axial polarized stack of neo magnet discs over the high voltage wire from an ignition coil, and pulsed the primary from a 12 volt battery. I didn't get any effect on the magnet stack from the high voltage A.C. arc, but this high voltage D.C. arc produced a powerful one.
                            The surprising thing was, the motion of the magnets, was back and forth along the length of the wire, not swiveling to the perpendicular like in the Oersted video. This switch in vector effect has me thoroughly stumped! I made a video of this "Rocking Effect". See what you think:
                            https://youtu.be/Zubp7Woxt8Y
                            • Originally posted by Allen Burgess View Post
                              Did the AC and DC sparks have different colours?
                              I wonder if transverse and/or longitudinal EM impulses come into play here.
                              Bob
                              • Longitudinal waves.
                                Bob
                                You're right Bob. Thanks. The D.C. pulse square wave is longitudinal. Good motion illustration below:
                                The sparks are a different color; The A.C. amber, the D.C. cobalt blue.
                                There's hardly any amperage in the high voltage wire. The longitudinal wave is a "Magnet wave". The rule that magnetic force is soley a function of current in a wire is erroneous.
