Oscillating Reed Switch Pulse Motor.
  • Wire Output Bundle.
    What would happen if we formed a bundle of 36 copper wires 1 foot in length, stripped of insulation, and wrapped it with a magnet wire output coil; Then wired the bundle neatly between the high voltage electrode of the ignition coil and the ground? Would that generate the same longitudinal radient magnet wave output as a high voltage electrode wire 36 feet in length, wrapped with the same amount of magnet wire?
    • Bifilar solinoid coil with welding rod core.
      After thinking about this over night, I realized that simply pulsing the core of a bifilar solenoid output coil with a tightly packed non-insulated welding rod core, with (HV-DC), would probably deliver an OU COP! I have a three or four of them back in my storage locker in Northern California.
      Anyone following this thread can understand why; Starting with Hob Nilre and his copper mass to magnetic field ratio, and ending with Tom Bearden's explanation of longitudinal ZPE influx following field collapse.
      I have to special order magnet wire to perform this experiment correctly, from down here in Costa Rica, that may take some time. I may wait untill I return home to California for a visit. I wonder if anyone else is setup to perform this experiment? All that's required is a 12 volt battery, Ignition coil and the welding rod bifilar output coil and some connecting wires. The output has to pass through a fast switching Schottky diode into an electrolytic capacitor. Very simple setup!
      Filling the solenoid coil core with tightly packed non-insulated copper wire would probably work better. One side of the core would need to be energized by the high voltage electrode, and the other side of the core connected to the ground. The electrodes of the output coil would simply connect to the diode and capacitor in series.
      I think the remnance from the welding rods would retard the output.
      • Series bifilar or parallel bifilar winding?
        • Pulse circuit.
          @Bob Smith,
          The series bifilar can handle the high voltage better. Have a look at this D.C. transformer video:
          https://www.youtube.com/watch?v=pULvpVS4FOQ
          Lidmotor's "Rubber Band Joule Thief":
          https://www.youtube.com/watch?v=1U5lXqkoMzE
          The 3-6 volt to 400kv D.C. transformer, hooked up in series between the battery source and a second "Reed Switch" triggered by Lidmoter's "Rubber Band Joule Thief" would deliver a clean sharp High Voltage D.C. square wave pulse to the copper wire output coil core. (Series Bifilar). These components are really inexpensive. What a wallop!
          The inclusion of a simple spark gap tube would allow us to spark safely between the negative end of the copper wire core and the transformer ground to help increase the "Collapse Shock"; Picture below:
          • HV converter.
            Look at the myriad componants this guy busted out of a $3.99 3-6v to 400KV D.C. converter off ebay:
            This converter supplies it's own pulse; However, two Reed switches, one "Normally Open" and the other "Normally Closed", placed in tandem behind Lidmotor's oscillating rubber band magnet would permit a reciprocating output capacitor dump to source, while the input pulse was at rest.
            • TPU Bruce copper wire core.
              TPU Bruce wrapped these copper wires very loosely with perpendicular output windings, but not enough. Also, Bruce was trying to generate power with A.C current, not the high voltage D.C. pulse that produces the longitudinal wave. Looks like he was partially on the right track though, based on things that were explained to him; Bruce admits he dosen't know that much about electronics.
              • Wesley explaining Akula.
                Wesley's schematic. Core pulsing:
                Dally thread Grumage: core pulsing
                Bifilar output coil in aiding mode.
                Take a look at the diagram below; Wesley uses it to explain Akula's TPU. There's a high voltage transformer on the left. The HV positive electrode's connected to one end of a very thick rod that is grounded through a "Spark Gap" on the other side. The Khz frequency's controlled by the spark gap. The thick rod is wrapped with a one layer output coil.
                This is identical to the ignition coil wire and spark gap circuit I used to get the longitudinal spin wave in my last few videos. Here we see Akula with the an output coil on the HV electrode wire as I proposed, but notice the end connected to the high voltage ground. One can see that this is exactly what I came up with independently from my particular angle of testing!
                The magnetic poles in Akula's core form end to end not side to side. The transverse wave travels sideways through the core as "Longitudinal". The sideways current is ZPE!
                • At 15:25 in this 1 watt dismanteling video, we see a closeup of the first layer of Akula's coil: It's definitly copper wire! The exterior output wrap is on the perpendicular as you can plainly see in the earlier part of the video.
                  https://www.youtube.com/watch?v=2cqk7fijGG8
                  The $3.99 3-6v to 400KV D.C. converter off ebay should do an even better job then his homemade input circuit.
                  • Earth Magnetic field.
                    Akula maintains his TPU is tapping power from Earth's magnetic field. This shows Akula really dosen't understand where the power's comming from. The "Earth Field" exerts an influence, but Tom Bearden explains the source with deeper understanding. Akula's "Earth Field" theory has cost him credibility.
                    • "Oersted Paradox".
                      The motion of the axial magnets over the wires in these two videos, coupled with Tom Bearden's illustration and discription below explains the secret behind the power of the TPU:
                      First we see the magnets "Spinning" from the magnet field in the Oersted video:
                      https://www.youtube.com/watch?v=r8wBt9Q8H5I
                      Then we see the magnets "Rocking" from the radient energy wave in the high voltage wire:
                      https://www.youtube.com/watch?v=Zubp7Woxt8Y
                      The "Radient Waves" are actually traveling sideways through the high voltage wire!
                      Quote from Tom Bearden:
                      "The wave radiates out horizontally from the vertical wire"! We have the concentric "Magnet Field" in the wire of the first Oersted test video and the "Radient Energy Wave" on the perpendicular in the high voltage wire test video.
                      I'm calling this the "Oersted Paradox" and a verifiable proof of ZPE. Our TPU replicators really fail to understand this basic operating principle!
                      • Radient wave and electron lattice.
                        Why does the magnetic vector shift 90 degrees from radial to axial in the high voltage electrode wire?
                        Ohm's law describes the lowered resistance caused by increased voltage. The high voltage D.C. creates a pathway for the "Radient Wave" wake that floods into the wire from the electron lattice following the implosive evacuating collapse. The collapse scours the wire of electrons, and the more highly charged electron surroundings flow into the negative zone to restore the balance. The copper wire dielectric has already been instantly neutralized by the high voltage and a viaduct for the resurgence established.
                        The new current originates from the "Quantum Plane"; from the sub atomic outward to the "Macro-Dimension". This new "Longitudinal Wave" current is traveling sideways through the wire, forming magnetic poles to either side, which turns out to be end to end. A longitudinal wave is merely a transverse wave traveling sideways. The Hob Nilre proportion of copper mass to magnetic field strength probably has a close corollary in the generation of this kind of "Zero Point Energy".
                        The radient longitudinal wave can be collected from the HV wire with a perpendicular winding as output. Wrapping the low voltage concentric field wire would yield nothing from a pulse, because the windings would run parallel to the current generated magnet field.
                        A series bifilar solenoid coil with a wide core filled with thick uninsulated copper wire would probably work best. I plan to build and test one as soon as my HV D.C converter arrives.
                        • Uninsulated copper wire.
                          Here's 500 feet of uninsulated #8 gauge copper wire from "Home Depot". We could saw through this, and solder copper disks to the cut ends to act as electrodes. Wrapped with electrical tape, then wound with 2 strand speaker wire for output; This would deliver kilowatts of power!
                          • Magnetic force and Radient output.
                            Hob Nilre's magnetic force to unit of copper mass for fixed input ratio should be mirrored by the same proportion in the TPU. Radient power, and the accompanying magnetic field should increase with additional copper mass per fixed unit of pulsed high voltage spark gap power; To the same degree that increased copper mass adds to the attraction force of an electro-magnet.
                            • Pulse interuption.
                              This message was deleted.
                              • Hi Allen
                                So if I understand correctly, you're saying that the wire that goes along the toroid's outer rim is basically litz wire (individual strands joined at both ends) that is pulsed, and the perpendicular winding over it is what is picking up the radiant/scalar/longitudinal impulses? This is how I understand what you've been presenting (noting that with more or heavier gauge litz windings, you're getting larger magnetic response and radiant impulses to pick up with the perpendicular windings). Am I correct in this understanding?
                                Bob
                                Edit: If this is indeed the case, then we have orthogonal windings. Typing [orthogonal windings Tesla] into a search engine will produce interesting results.
