  • Adding the verbage and source to the previous post:
    https://contest.techbriefs.com/2018/...e-acceleration
    All electric motors convert Electrical Input Power to Mechanical Output Power.
    The ReGen-X Stepper Motor is a unique patent pending new motor design which delivers Mechanical Output Power AND Electrical Output Power at the same time.
    The ReGen-X Stepper Motor also converts electrical input power to mechanical output power just like any electric motor but it also delivers electrical output power in a two stage approach..
    The ReGen-X Stepper Motor employs; 1) the ReGenX Generator Coil, which produces a Complementary-Electromagnetic-Torque when delivering electric power to a load in concert with 2) Magnetic Field Flyback Collection Motor Control Circuit such that the motor delivers mechanical drive shaft output power while also delivering more output current than the motor coils consume.
    When electric current is passed through a current bearing wire which makes up a motor coil an electromagnetic field is created around the coil which performs work and changes the kinetic energy of the motor's magnetic rotor (accelerating it).
    The rotor is usually made up of altering magnetic poles and the current direction in the motor coil is continually and rapidly altered so the electromagnetic fields produced around the coil interact correctly with the rotating rotor pole(s) and performs the desired motor action.
    The magnetic field created around the coil is dissipated into free space and lost when the current direction is reversed.
    The ReGen-X Stepper Motor has a unique motor control circuit which allows; 1) the magnetic field created around the motor coil to collapse back into the coil, 2) to be converted back into electric current in Magnetic Field Flyback Collection Mode and then 3) delivered to a battery before the next DC pulse occurs.
    Magnetic Field Flyback Collection and normal Generator Action in a Motor are caused work together in concert to deliver more electric current to the battery than was delivered to the motor coil initially.
    Generator Action in a Motor occurs when the motor's rotor pole moves away from the motor coil, causing undesired current to be produced in the motor coil. Now this current is harnessed in a novel way to produce a positive and desired result along with the recycled and reclaimed input current.
    Illustration #1 shows the ReGen-X Motor Circuit Diagram where the DC motor pulse is provided to the motor coil and then switched once the DC pulse has ceased to allow the collapsing magnetic field and Generator Action in a Motor to collectively recharge a battery.
    The ReGen-X Stepper Motor is designed to be employed in electric vehicles (EVs) to provide EV battery recharging during vehicle acceleration in Regenerative Acceleration Motor Mode, during coasting in Regenerative Acceleration Mode, and during breaking in Regenerative Braking Mode.
    "Electric Vehicle Regenerative Acceleration" Generator Operation is explained here: http://contest.techbriefs.com/2018/e...portation/8864
    The ReGen-X Motor is used an an EV Traction Motor to accelerate the EV up to cruising speed and then any number of coils can be converted to Regenerative Acceleration Generator Coils as dictated by the CPU to provide optimal EV battery recharging and vehicle performance.
    • This is paragraph 7 from the post above:
      It is false.
      Therefore the main premise of the argument is invalid and rest falls apart and is total garbage.
        It is false.
        so you are the one smarter than all of the patent office scientists. Next to you they are all
        flunkys? Yet Thane's engineering thesis has passed inspection. It must hurt BYEManufacturers are picking up the innovation. Unlimited range
          Show me one, please.
            3rd party proven by Michael Moore, more to follow, same as my video's
            • Nuts and bolts for the genX freaks
              • For those of you following the continual upgrade of this innovation please note Thanes new rotor designs which he has many. This one solves many problems. Not only is Thane an EE he is also good on the mechanical end. Liquid plastic rotors are out of the question for large power generation applications as heat would turn them into more like rubber. The gaps are also just a little wider between magnets to stop bleed over with CNC slots between magnet holders. The core only sees air in between poles on the rotor much like the silly rubber design (Sorry dave) but with super durability. Power plants need steel rotors as does any EV traveling down the road in 120-130 index heat plus heat from the coils to be of any practical use to the public. I pick on Dave but he got the job done, time for the rest of us to get off our azzez and carry the ball down line.
                Problem solved. hats off to you Mr Heins ole buddy ole pal. I count 24 magnets on an approx 14" rotor dia.
                • Strategically placed magnets on a 14" dia- placeholder at 12" X 3.14 = 38" space for 24 1" magnets leaving 38-24 = 14" of gap area left over to space between magnets 5/16" slots where metal is removed, think about it. Gaps slightly great than 1/2"
                  Place holder can be silver soldered into normal rigid material plus balancing can be achieved by the proper cutting of slots.Just bangin out a rough questimate.
                    Not going to happen bi. Not now. Not ever.
                    That series of videos, along with the output of the coils is what we started sending to Aaron before Greyland got sick, and will not be shared anywhere else until after the conference. And NEVER here. Just the links sent to people who are actually building.
                    Thanks Mr Dave.
                    We continue in the practice to have better yields, hopefully more people are encouraged to experiment and enjoy the challenges that are obtained
                    • corrections to lenz's law, newtons 3rd law
                      • Newton parrot
                        • Unsolved mysterious Lenz law, rubbish
                            https://medium.com/@deepbreadth/newt...y-a5ad4dedfe26
                            Unfortunately, his equations were wrong.
                            If we use Newton’s laws of motion to calculate positions on earth using our GPS satellites, it would start out alright…but by the end of a single day they would be off by miles. [1]
                            They also give very close, but still incorrect answers to how Mercury’s elliptical orbit changes over time. [2]
                            Using his equations to make predictions of objects around black holes or moving near the speed of light yields even more inaccurate results.
                            Essentially, if you’re trying to answer questions about objects moving at extremely high velocities or in extremely strong gravitational fields, Newton’s equations simply give you the wrong answers.
                            If only there were a super genius that could invent new interpretations of light, mass, space, and time, that fixes all of these problems…
                            Newton didn’t know about the speed of light or the fact that things like neutron stars and black holes exist. But he did know that “if [he had] seen further, it is by standing on the shoulders of giants”.
                            These insights triggered successive ontological reawakenings for humanity and uncovered new understanding which we set foot upon today in our endeavor to see further still.
                            Newton was wrong and so was Einstein, and that’s okay because their insights are fundamentally important steps towards a more fully accurate understanding of reality and our existence.
                            • Im not sure what would cause Newton to nearly give himself a frontal labotamy with a long spike inserted into the corner of his eye, but I tend to think that physics wasnt the only thing on his mind. If empty space were truley empty then what difference would mass make?
                              Thanks for the good work and the cool links.
                              • Originally posted by lotec View Post
                                Now that is funny. You are welcome. The empty space was between his ears.
