The reason for the 36 strand coil is simple. You should know exactly the length if each strand if they are the same. Put all 36 strands in series. Will the motor speed up under load? Probably. Now put 18 strands in series and a second group of 18 strands in series. Will the motor speed up under load? If it DOES, put 12 strands in series and then two more groups of 12 strands in series. Will the motor speed up under load? If it DOES, put 9 strands in series, and three more groups of 9 strands. Will it speed up still? If so, put 6 strands in series. Then five more groups of six. If it speeds up, try 3 strands. If it speeds up, try 2. At SOME point it will NOT speed up under load. This gives you the minimum number of strands of the length you are using to achieve what you want. Or start with two strands and work your way UP instead of down. Once you know the minimum number of strands, you can figure out the combination that will give you what you want. As many strands as possible in parallel gives you lower voltage but more amps. Adding to the LENGTH of a working minimum gives you more voltage but lower amps.
if I have a100 strand coil and all the strands are in series so it speeds up under load, my voltage output will be high, but my amperage output so LOW that it won’t run anything, and the voltage will probably be too high to run anything anyway. Understanding how to control the output of your coil is the only way to get its output in a range where it can be manipulated EASILY to run the motor that is turning the generator.
As for my house remodel. I am shooting a video today to show my sons the progress and what still has to be done. I will post the YouTube link here and you can watch it if you are interested.
