The Moray valve
  • #31
    I did it today
    Ok first you should know i have string theory and black hole
    but i had been working on moray valve and have the fomulas from uvc to silicon but no lab but i did learn how to radiate rock using a basic antenna
    nuclear power so i reversed the grid but no power for me
    today i was installing granite had the router on a peice
    with the metal touching the granite from the tool andthe cord touching the granite when the water hose was connected the tool spun with no power conected and the water valve off on the tool so the water completed the loop
    moray did not have a third ground prong
    to earth i think thats the trick my power was going thru the dirt to all my neigbors but not me so i took it down due to large mass of radiation in my house and non desired results im prety tired
    broke and burned out but look black and white granite has all color and all frequencies thus can radiate as a battery for all frequency
    really magenta is the primary color but thats a long explination
    • #32
      I did it today
      • #33
        Yes im a genius
        Improve the moray valve antennas with fiberoptics
        so I can really take the fiber optic grid thru my
        uvc uva uvb lead to silicon plasma and charge the worlds
        biggest battery my reuseable plutonium grand canyon
        so im supersizing my mcdonalds frys lol
        i mean my moray valve to a power level this worlds never
        seen so cool take that ****ing bp and haliburtion
        your going bust all you ****ing oil and pge
        shut my power off when its 100 ****ing degrees
        cant wait to see them go broke after I crash the stock market
        by letting people get out oil before they manipulate the bankruptcy
        stick them in there ****ing oil before they short sell it
        • #34
          Valve
          I found some info about Moray' Device and past some excerpts from the website (The Moray Radiant Energy Device | 100777.com) in order to submit to your appreciation: "In his free energy detector tube Moray apparently used, inside the tube itself, a variation of this transistor idea, a small rounded pellet of a mixture of triboluminescent zinc, a semiconductor material, and a radioactive or fissile material His patent application (for which a patent has never been granted) was filed on July 13, 1931, long before the advent of the Bell Laboratories' transistor". His work was the predecessor of the transistor as we know it.
          (Probably the response for the tubes 'rare chemical substance' is: he utilized a low nuclear "radioactive material" used to excite the gas within the valve, according Bruce Perreautl of nuenergy.org).
          Also -the text said- "Moray explained that his device was based on the discovery of a mixture that would act as a one-way gate for the high frequency oscillations (vacuum aether, my quote) of space, so that the energy could go through the material more readily in one direction than another. Thus it was like a one-way gate valve to an ocean wave; the energy "water" could flow in in each valve, but was prevented from flowing back out". I think you should read it, specially the two last paragraphs. Great history.
          Last edited by Freemen; 08-03-2010, 02:29 AM. Reason: I forget to set subscription
          • #35
            (Cheif prince of me-she-ch) Could you better develop the idea of benefit from the crash of the market before they can manipulate the stocks in order to haverst the biggest amount of cash conceivable? I have an idea could apply to what you proposed...
            Last edited by Freemen; 09-29-2010, 04:37 PM. Reason: I forgot to mention the member name I refered to
