Walter Russel / Utron research
  • #31
    Some high speed tests
    [VIDEO]http://www.youtube.com/watch?v=x6VazksH0T4[/VIDEO]
    • #32
      Telemetrics testing
      [VIDEO]http://www.youtube.com/watch?v=lcHWNVpB3CM[/VIDEO]
      • #33
        Small update
        [VIDEO]http://www.youtube.com/watch?v=orNHhZZnTRY[/VIDEO]
        • #34
          Magnetic anomaly?
          [VIDEO]https://www.youtube.com/watch?v=QFFrh-FXE84[/VIDEO]
          • #35
            Would you check the resulting magnetic pattern for the combination of two magnets and iron screw with a magnetic film viewer ? Would you observe any symmetry ?
            nathan
            • #36
              nathan
              Hi nathan,
              Not sure if i understand your question correctly.
              But i'm not in possession of magnetic film.
              If i would take a guess, it will not be symmetrical.
              • #37
                Hi nathan,
                Maybe that alone is the justification for the change in velocity ?
                • #38
                  Ongoing tests
                  [VIDEO]http://www.youtube.com/watch?v=pTYHfqBDEKc[/VIDEO]
                  • #39
                    Will plasma conduct low voltage?
                    I was wondering if i could eliminate brushes by using a high voltage spark as the brushes for a low voltage current.
                    [VIDEO]http://www.youtube.com/watch?v=anlrrbpEujU[/VIDEO]
                    Warning: Boring Video!
                    • #40
                      I have seen relatively low voltages go through a plasma
                      a bit of a trick to set it up though,
                      you have to have a high voltage arc to start the plasma and then turn it down to low voltage at higher current.
                      or electric contact and then pull the arc out
                      a 50 ohm resistor, 120Vac, and gold plated connection on one side makes for some fun playing
                      just tap the connections and then pull them away, I get at least 1/4 inch gap before it breaks
                      • #41
                        Hi spacecase ( I keep thinking "spacecake" a local delicatesse : )
                        I tried it very simple, I set up the high voltage connection trough the axel and a magnet, with a spark gap. Then I tried to add a battery powered low voltage high amp over that arc to get a rotation from the magnet like a homopolar motor.
                        Unfortunately i did not work .
                        • #42
                          Melting a Utron
                          Now I decided on the design, its time to make some solid ones.
                          I decided on casting them in aluminium. As I have never done that before, i chewed up some youtubes and mocked up a proof of concept in the garden today.
                          I'm actually quit happy with the results.
                          Not a finished product, but a decent enough proof of concept for me! : )
                          Anyway, here is my first attempt in melting and casting molten aluminium:
                          [VIDEO]http://www.youtube.com/watch?v=qMut-4mFCxU[/VIDEO]
                          • #43
                            Another meltdown : )
                            [VIDEO]http://www.youtube.com/watch?v=sGi8Y95wsto[/VIDEO]
                            • #44
                              Utron small update
                              Some minor tests.
                              Testing the conductive properties of my Utron design. Half and whole.
                              [VIDEO]https://www.youtube.com/watch?v=cMm0y8JzGUo[/VIDEO]
                              • #45
                                More testing
                                Some more testing and learning.
