Originally posted by RAMSET
Don't worry about stepping on any of my biggest toes, I forgive
and forget fast especially after a good ole fashion brawl, it's a man
thing.
Good to see you hanging out.
Yes that is correct according to the video not for 100 feet though.
In THE OLD SCIENTIST video and in the picture the amount of wire
used was 680 turns of 22 awg wire and the spools looked to be around
a 2" diameter and with this we might guess the length.
But I think the awg of the wire is actual less because the feet are
less than 680 feet. My mistake. I will correct this thought, however
according to the video measurements THAT spool that looks to be
about 15" long and approx. 2" diameter holds 680 turns and this is
what we have to work with.
Yes that is right Ramset when using the same number of turned
split up like a bifilar and series connecting the winding, the resistance
value is not quite half but close enough.
You really need to see the video. He has been around for years and
has a lot of nice test equipment. Nice everything, scopes you name it.
The lower resistance value may be due to the assisted flow as the
reconnect in series is in the same direction as the first wire flowing.
Then when watching the video he double verifies everything with
two other forms of measuring instruments such as the LCR regular
and then he switched to a precision LCR metering device, then he
looks at the scope as he runs a generator on the coils to find RES.
