Video footage of my multifilar winding machine.
https://www.youtube.com/watch?v=eZ_RZf7_Z8g
Published on Jun 18, 2017
Here is my progress on building a winding machine for making coils with many strands. I could have started out with just 2 strands and this would be called a bifilar wound coil. This is 2 strands of wind wound around the same spool at the same time in the same direction. After a 2 strand coil is finished you can connect the ends together ways. One way is to put the ends together on each end and this would be considered a parallel connected bifilar coil. The other way to connect a double strand coil up is to take the end of one strand and hook it to the beginning of the adjacent winding.
The connections determine the self capacitance and resistance in ohms of the coil.
In my winding video you see 4 strands and these four will be wound onto the same spool in the same direction at the same length. They will all be connected in succession or what is called "SERIES CONNECTED" where the end of each strand in brought around to the beginning of the next wire til all 4 make up one continuous wire.
This is called a "MULTIFILAR" wound coil. The winding is done this way instead of a single strand to alter the impedance, resistance, capacitance, capacitive reactance and inductive reactance.
Multifilar coils were promoted by N. Tesla, as well as bifilar.
Coils can be wound so that each layer gets a cap to match tune the next winding that gets a cap and so on. Each coil layer can be also separated with clothe. The spacing changes the capacitance of the coil. I am talking about SELF CAPACITANCE.
Coils wound with many strands can use copper magnet wire that has either a silver coating or tinning before the enamel is applied.
Coated wire or tinned wire carries special currents and uses what is called the "SKIN EFFECT" to capture other types of energy.
Nano coated magnet wire has taken the place of expensive silver coatings. 2G HTS wire
http://www.superpower-inc.com/content/2g-hts-wire
Also core material other than the regular iron laminates can improve coil collection efficiencies thereby making it possible to reduce the size per unit output.
A coil winder is needed to do these kinds of experiments.
