Splitting The Positive
  • Inverter 2 Boosters
    David Bowling Setup
    Here is my first proper attempt with setting done correctly for the
    first run. It has been an hour and a half or 1.5 hrs charge battery
    voltage dropped a small amount from 12.61v to 12.58v
    https://youtu.be/qwMsj0Wy9WQ
    • First Run Measurements
      Here is the first set of figures recorded using an inverter in
      this split positive 3 battery generator system.
      Maybe someone could explain this.
      • @wantomake
        Thanks on the FWBR answer
        I lowered the power draw down to 13 watts.
        It seems like the battery life of 10% is unchanged either way. Even
        using up or shall I say wasting 10wh the usage is the same within
        a margin of error.
        I may go to a 40w load next or a 30watt, not sure what to do. Or use
        another inverter. Maybe an inverter module might work better.
        I burnt 2 small inverters already so I won't buy that kind until I build a
        soft-starter circuit. It doesn't make sense how all those wh are being
        recirculated with some burned up in the process and battery life is
        unaffected.
        If could get my booster efficiency up to 99% maybe I could get some
        radiant going to battery 3. Well I mean collect what is being burned up
        at the moment. Anyway I don't know what I mean yet, but I will.
        • Video
          Two 12watt bulbs and no need for a larger booster that is running
          a 5 amp draw on the new inverter. The other, even newer inverter
          makes the booster draw 10 amps to recharge batteries 1 and 2.
          What I think that says is that the inverter I am using now is somehow
          holding up the input while delivering the same power to the load which
          makes it easier to charge back up the run batteries.
          With twice the load and half the recirculation amps, the point count is
          almost the same as with 1 bulb, well 1 point less actually per half hour.
          It does look like I struck a vane.
          https://youtu.be/3jNEegIIxS8
          What if the thing that makes this work is NOT a potential difference between the higher voltage in the source batteries and the lower voltage in the bad batteries, but a potential difference between "positive charged batteries" and "negative charged batteries." Think about that for just a minute.
          After all, I know for a fact, and so do many of you, that the bad battery actually flips polarity. and WHILE IT IS FLIPPED, that is when the magic happens. Now, that means that perhaps if we could get a battery to STAY flipped, we could run this thing forever. And maybe a lower voltage bad battery has a greater potential difference than a higher voltage bad battery (when they flip polarity) in relation to the two fully charged good batteries
          So lets talk about that for a minute. OBVIOUSLY there is a source of reversed or negative energy hitting that bad battery that causes it to flip, but once it does there is also a source of energy that is great enough to get it to flip BACK to the original. What if those two sources of energy could be isolated from each other and/or isolated from the bad battery? If it is the motor that causes the battery to flip, then we need a different circuit when that happens. Maybe we run it off one bad battery until it flips negative and keep it running there, but the minute it flips positive again, we switch to a second bad battery. Something like that. Alternating between the two.
          I have had a battery hooked up to a motor as generator for four days now, trying to create a negative transducer. It reads just short of -12 volts, but as soon as I disconnect the motor, the negative voltage in the battery starts dropping. Why is that? What makes that battery WANT to go positive, and where does that energy go that is showing up as almost -12 volts in the battery right now? It seems to want to settle at about -7 volts, and I can't get it to go any higher than about -11.78 on the negative side.
          • If anyone has any experience putting these same to circuit together
            to form a ganged converter let me know. I wondered if a double pot
            might work or if they will burn up one another if I do that.
            Thanks in advance.
            • new figures are in.
              With the old inverter and the corn cob light bulb baseline
              test I am getting a .02 per hour drop straight to the battery.
              When hooked up to the split positive running 2 boosters i am getting
              a .04 volt drop per hour which is double the normal inverter to battery.
              This is what I would have expected in the very beginning using an
              inverter as a 3 battery generator.
              So here is what i have tested. I have used 4 different inverters, various
              sized battery packs and all kinds of loads and in a period of weeks
              conditioning batteries, at no time have I ever seen an extended runtime.
              My true deep cycle batteries are nothing like the capacitor type batteries
              suggested so these must be the obstacle.
              All we need do is to watch Wantomake as he has been following this
              thought for far longer than I have. At no time has he reported any extra
              and instead we see the way to getting the excess is to run a motor
              (modified) to a generator (modified) back to the batteries.
              This is the only way I can see recorded as a practical setup to run some
              lights in his shop.
              I will continue testing by staying around a 30 min to an hour test.
              My batteries will be flooded with alum on the charge battery first then
              the run battery next. I also have some new gel cells so there will be no
              excuse.
              Next we will explore the multiple inverter to multiple packs to see if I
              can reuse the same energy 3x. However i did consider the higher load
              tests to be better than the low powered tests.
              Special inverters or modified inverters and modified boosters are talked
              about concerning this subject, for instance removing the large internal
              capacitors or buying that special type. Although I have not seen one.
              What we learned with the battery charging technology is that each time
              energy is transferring from 1 battery thru a load to another battery is
              that there are plate resistance losses. To keep these losses to a minimum
              elevated voltage surges were found to be the best way.
              While this message does not show positive results for inverters does
              not mean that this process can not exceed my findings. For example it
              was shown that the wrong charge battery does not work. A bad battery
              was better.
              With the following tests using multiple packs to capture the same
              energy thru a load would obviously not be able to use bad batteries.
              With no clear path to relay on which battery or inverter to use the
              average person will not be able to make one work.
              Good Day
              • Next test 45 watt consumption
                12.08v drop to 11.94 = a 14 point drop in 90minutes.
                This required a 6amp booster with fan added if 10 amps is
                needed to run at 8.75amps off the charge battery over to the run
                battery bank. Efficiency probably 80%.
                Second booster well with in the C/20 rate at 3.25amps and this
                kept the inverter hot leg fed at 14.5v, while the run packs got the
                875ma at 12v transforming into 26.5v of course at a lower amperage.
                As was reported for these batteries 10% of battery life = 42watt hours
                So a 14 point drop = 14% battery life or 59 wh straight off the batteries
                to inverter and I ended up with the same figure. or 45w times 1.5hrs
                and this is a small amount more or within the margin of error is equal.
                Which seems impossible.
                Any Brushed DC permanent magnet motor will work, HOWEVER, as some folks have seen, you can burn out a 12 volt DC motor if you are not careful, because some of the time you are running it off 24 volts or higher. I have been using a 110 volt DC motor and it has taken everything I have thrown at it, so I would recommend a higher voltage DC motor if you can find one. The higher the better.
                Just to see if we're telling the truth and see it work? ANY PM DC motor. To build something that will eventually produce some power for you? The bigger (higher voltage) the better.
                All,
                I'll look at adding the diodes Ufopolitics suggested to the circuit already containing the diodes Matt suggested.
                But I KNOW what Matt suggested made a change in the voltages on batteries one and two.
                So, if Matt's change gets it to charge and Ufopolitics gets the radiant out of the motor so it doesn't heat up, without messing up the current flow that is causing the charging.........????
                I don't have access to my computer ..........
                Matt talked about using diodes, and I just wanted to see what would happen.
                I would love to hear what Matt has to say. He may say I have the diodes in the wrong place,
                Matt and Carroll,
                I know I am not the sharpest guy when it comes to electronics
                I'm sure you can expect something from Matt the first chance he gets.
                We shouldn't be waiting around for Matt, we should be trying things
                All,
                I haven't gotten Matt's new schematic built yet,
                Develop what Matt has given us which we KNOW works,
                especially Matt for sharing what he came up with.
                Doesn't seem to be any difference between that patent and todays Aluminum Electrolyte capacitor.
                I would first suggest learning how to properly destroy the battery you have availible.
                The battery I am running the system off of is a 1100 CCA battery for a catepiller tractor. It was used for 8 years and died one winter after no activity for about 6 months.
                The PH is Normal the Hydrometer does not give a reading, the battery holds about 3.5 volt standing and droips to nothing with 1 ohm resistor for a load.
                The primary batts are 1500 cca Interstates tractor batteries
                I'll also tell ya I am using a Razor Scooter Motor for both the motor and generator (Coming soon).
                This is the 1 ohm 100 watt resistor but ceramic, but this is the equavalent
                I have 1/0 wire with copper connectors to everything and real short leads to the motor/generator, and all copper connectors.
                The motor free wheeling runs at 1.1 amp.
                Matt
                FRC,
                I haven't tried it yet, but Matt certainly has, and I talked to him on the phone
                clueless,
                I would give Matt's circuit a try. If you can't figure it out, we'll help you. If you get the spec sheet on the MJL21194 it shows the base, collector and emitter.
                The base goes to the 100 ohm 1/2 watt resistor. The emitter goes to the 1 ohm 100 watt resistor, and the collector goes to the plus on batt 3 and then over to the other end of the 100 ohm 1/2 watt resistor. On the Transistor the three prongs are B C E. Hope that helps, and that I haven't screwed those directions up.
                Matt has had his setup running for FIVE days without losses
                Matt is going to make a couple more modifications and then film it for us.
                Matt is using or possibly Mosfetts if we want to put big loads on the motor or battery three
                Sorry I can't be of more help. Maybe Matt has an idea.
                ...in Matt's original schematic he connects the two bad batteries between equal potentials (12 volts on each side) and with five batteries you have more on one side than the other.
                Matt, I can't tell you how MUCH I appreciate the time you have put into this.
                By the way, according to my calculations, 10 watts on a 12 volt system requires 1 amp per hour. If you ran 10 watts for 12 hours, that's 12 amp hours of usage. Is that correct? PLUS you ran the motor the whole time, you produced power to charge the small battery, and where did the primaries end up? And how many amp hours are they?
                You ROCK Mr. Jones!
                Can't wait to do a run tomorrow. I have it all set up and ready to go. Just have to throw the switch and cross my fingers. All three of my dead batteries are resting at less than one volt.
                I'll take down my video camera and set it up on the tripod and let it run until the tape runs out.
                Heck for that matter a switch alone might work. You might not need any motor at all just pulse. Try a small system with a transistor driven off of the stamp chip.
                Matt
                All,
                When Matt posts his video you are all going to want to replicate, and you WILL NOT get the results from 18 amp hour or less batteries.
                I know from experience.
                deep cycle marine batteries for $99.00 I am investing in a bunch of those
                I have got all my batteries tied up at the moment. 42 of them all running something.
                I gotta let this other thing run its coarse I just can't stop it right now, on top of all the other stuff I got going.
                I promise I'll take a film soon.
                I am going to set it up on an IC and with a Fet. I just gotta get the other stuff out of the way first.
                Matt
                Hey Matt,
                I've been on pins and needles waiting for you to post the video of your shorting experiment with the big resistor.
                • New test ALUM CHARGE BATTERIES
                  This next run (Running now) is showing a promising improvement.
                  I am running 2 amps at 13.7v into the booster that feeds the inverter
                  and the booster charging the run batteries is pulling off 5 amps away
                  for the charge battery.
                  What is well known as shown by John Bedini is that internal
                  resistances in these cells drop significantly. This means less waste when
                  recharging or discharging.
                  Since these systems pump a lot of energy around in a loop charging
                  and discharging watt hour losses should be greatly reduced.
                  I have not converted the other 8 run batteries YET.
                  It would appear that the point count drop has slowed down but let us
                  see if that is true in these coming runs. We already have some baselines
                  and run figures using the splits with 2 boosters and all the same lights
                  will be used.
                  • New test with Alum battery baseline = .03 point drop per hour
                    straight off the battery. 27 watt load
                    The splits gave a .04 point drop per hour showing booster losses of
                    25% approx. Same load of course.
                    Alum battery point count is stronger going from a 10 point 10% battery
                    life of acid 42wh and Alum is 55wh.
                    Second test underway to verify within the margin of error.
                    PS i am back 1 hour later with the splits showing .03 point drop same
                    as baseline so we can deduct that with improvements gains are possible.
                    Originally posted by ehsanco1062 View Post
                    Hi mbrownn
                    here is the video for the test I did I hope it will help see the test not just read it.
                    2 BGS with caps part 1 - YouTube
                    2 BGS with caps part 2 - YouTube
                    Ehsan
                    First thing I gotta say is I can prove what I am about to say.
                    The spikes are not traditional. Tall and slim if you will. When you look at a spike on the scope your are not seeing the time in it. Time is an indicator that something is flowing, so if you have flow in time, you have current.
                    The current a spike, like monopole produce, are 90 degrees out of time. So this is the hard part for people to see.
                    You have 3 dimensions in space, XYZ, then come weight. Electricity is viewed in Vectors so it is only 2 dimensions. Y being the amplitude (Up and Down) X being the time its on. Thats all you see on a scope.
                    But with 3 dimensions you miss most of it in the case of spike because you are looking at the Z coordinate and this is going away from your view.
                    Now if you look AC, both voltage and current, running through an inductor you'll see the quarter wave effect of the inductor on the current. The current will be 90 degrees behind the voltage. Just look up "AC Quarter waves" for an example.
                    Same thing happens to spike when the voltage of the spike travels through Iron. The current follows it by 90 degrees. So the spike, on the scope has now turned into the X coordinate and we can see its depth, or time. Remember equals the presents of a flow.
                    With this behavior we can keep a constant and level flow of current coming out of a transformer with a 50/50 duty cycle or less. You make a pulse, turn off the source power, the spike shows up, turns in time and fills in the time you are off. This almost doubles your output.
                    Now in the past I have heard alot of nonsense about the fact that if you use too much current the spikes won't show up. The "senior people" in this community like to tell you that. This is why we can only get free energy out of a small rotory based motor generator. Nothing could be further from the truth.
                    This energy is always present from inductive collapse whether you can see it on a scope or not.
                    Here is a small scenerio, You can test it for yourself if you have the parts.
                    You will take 2 transformers to plug into the wall.
                    1 of them will take 110 vac 1 amp and turn it into 220 vac 1/2 amp.
                    1 of them will take 110 vac 1 amp and turn it into 5 vac 22 amp.
                    Now we take the output of both of those and run it into a bridge rectifier in parallel.
                    The rules of parallel say we should average the voltage and add up the amperage. So by this rule we should now have 112.5 volt at 22.5 amps.
                    Unfortunately this does not happen.
                    What we end up with when put a load on it is 5 volt at 22.5 amp.
                    This higher current side draws down the higher voltage side.
                    This same thing happens with the energy released from inductive collapse. If the spike is present it is drawn down to the level of the higher current on the wire, But it is still there. If you can see them it has the higher current.
                    So are seeing what I am trying to tell you? We get the to use the current from these spike immediately.
                    I have another project that has been measured very carefully with good equipment. I pass 19.7 watts through an EI core transformer. 43% of that power is caught in a good battery. we pulse on 50% percent duty cycle.
                    The pulse of 19.7 joules creates a transient situation that produces 24.5 joules of energy and comes out at 94% percent duty cycle.
                    You see the possibility. We have more than doubled our output.
                    Now transients only get so big. The size of the is directly related to the input voltage of the pulse that goes through the inductor. So as your voltage goes up your current can come down and you can still get the energy out of the transient that is trapped. Or you can take the current up and the gain will be slightly less than what you put in. But with any potential based system you can catch this gain. It can out way all your losses.
                    I hope you guys follow what I am saying. I have known this for some time and kept it to myself or within small group of people. I am not telling you this so that I have to continue to support you in your search for this effect. I am telling you so you can know whats possible when you go to look for it.
                    I have done the leg work this is real effect that produces real usable energy. So there is no reason to doubt it. You just need to find it and start looking for the best way to make it happen.
                    And don't bother me too much
                    Good luck
                    Matt
                    The video is up. Enjoy.
                    The transformer is hand wound. I used one I burnt up on another experiment. I describe it in the video.
                    I think before its all done with, I will use caps instead of a dead battery. I can control the available voltage on the caps by the rate of switching.
                    I have got a few more tricks also to put the power back and if I get real digital about it I can do it in a way that makes sure you get the full brunt of the power before you lose it. Run it all around circles until entropy hits home.
                    I'll think about it this week a little more.
                    @Mbrownn, regarding your PM.
                    A motor by default is not capable of a transformer action, period.
                    You have to modify it to do anything close. Current and magnetic fields are not the same thing. Also motors are incapable of an AC current to voltage 90 deg offset which in itself will allow transients to do work immediately by allowing the current in them to be turned into forward time.
                    When I tell you motor is not capable of this action is not because I do not have the basic understanding of the motor versus transformer issues, Its because I know what I am talking about. I have very in depth experience with both.
                    Your PM should have been a HOW question and not a statement arguing a position to inform me not to misinform other people. If you have argument and proof other wise make it available. Proofs in the pudding.
                    Matt
                    No. This is not like a motor as motor cannot inductively pass current to second set of winding.
                    Look here's what happens.
                    I pull 24v+- from the primary in pulse for given time.
                    It goes through the transformer, induces current on the secondaries, then deposits into A2. Then it is abruptly shut off.
                    Now the secondary windings takes the initial pulse and sends it to the multiplier, and back into the transformers primaries to replicate and deposit in A2. 2x for 1 pulse.
                    But we also have that spike that showed up when we first turned the thing off. So now we are up to 3x.
                    So now start looking at it running say a 30 percent duty cycle. Kinda like spinning a flywheel.
                    Then you got the induced current on the wing batteries. And what ever type of back EMF shows up and gets replicated accross the transformer.
                    You follow me?
                    Matt
                    I don't think its created, its just there. You have a full environment of electrically charged and magnetically charged particles. They are in constant process of attracting to what you have on the wire or in the component. Every time they make contact they short out a given amount and you loose.
                    This is why DC is so vulnerable to loss and AC isn't. No modulation, nothing to confuse the particles just straight attraction. So they come in and make heat, make resistance (Magnetically), and generally short out charges.
                    Thats what a Transient spike is also. Charge sucked into the system by the expansion and contraction of a magnetic field. The charge is caused from the mass of particles collected and compressed on the outside of the field. When the amount is high enough it cuts the flux of the wire on the way back in, when the field collapses. More power to create the field, or more induction, bigger spikes.
                    Nature doesn't do anything, the balance is set. Energy cannot be created, only changed. The amount is set.
                    Matt
                    Originally posted by Marduk View Post
                    Hi, this is my first post.
                    My knowledge of electronics is really, really basic but I will describe what I have done to the best of my knowledge.
                    I have not used a dead battery, I am using a 24 Volt 3 Farrad car audio cap in place of the dead battery. A small dc motor (both have copper brushes instead of carbon brushes) is connected via it's shaft to another small dc motor. I have noticed sparks in the motors and I am sure that this "excites" the enviroment and that's where the "additional" energy is coming from.
                    I am not on-line often but will post further results when possible.
                    Keep on trying,like Thomas Edison!
                    My 4th battery was a good one that would take a charge.
                    I would use my old wires, and have drug out the # 6 wires I had in a box from back then. I'm sure that BIG wires make a difference, but wouldn't be surprised if LENGTH of wires make a difference too. Too many variables here.
                    I ran different combinations of things, but the original WORKING system ran with loads (and sometimes the fourth battery) connected directly to battery 3 in parallel.
                    I had a pulley and turnbuckle connected to motor (as in the PESwiki picture) and tightened the turnbuckle to put more of a load on the motor to get battery 3 to produce more power. But that original motor ran THROUGH a gearbox, so there was always SOME load on the motor.
                    I would watch the voltage on the primaries, and you could see them begin to drain, so I would tighten the turnbuckle and they would go back up.
                    It wasn't until I began to experiment more recently that I began to use a generator as the load on the motor because it gave the added advantage of ALSO producing power, but the load on the motor still has to be synched with the load on battery three.
                    Hope that helps.
                    • Hello Everyone
                      Did some rewinding tonight another 3 tries and each time the
                      last 30 turns would puncture the enamel on the wire and short out.
                      I could not see anything razor sharp but it was there. It took
                      me some time, but I finally got it up again. It really runs cool.
                      The motor is a modified scooter one rated at 36v. I put it on the
                      new system for the first time and fired it up after the charge batteries
                      has been sitting at 12.44v all day long. Now it is an hour later and
                      the resting voltage after 10 minutes is 12.42v.
                      All of this pumping action and I only lost .01v so this is better
                      than running the inverter. The motor was adjusted around again
                      from 2.2amps for a few minutes (about 10 min) then to 1.5amps,
                      then I turned it down to 1.12amps at 16v this is where I ran it for
                      an hour. The other booster going to the run batt's ran at 3.5amps
                      Of course I am going to need a lenz free generator to go over the
                      top to get usable power. With the boosters being able to run up
                      the RPM's the regenerative Tesla coils with all of the strands, tuning
                      is now possible for me.
                      I know it has always been there now but I am only just waking up
                      to the concept. I may make a smaller rotor and give this one to
                      my son, not sure yet.
                      But back to the pumping action before I go, the booster powering
                      the motor can be adjusted on the back plate so you don't need
                      the booster if it is done just right. It happens when you need torque
                      so you crank the back plate to get the extra. Next thing you know
                      the boost can be turned off but still letting power go thru it and it
                      runs faster and better. But as soon as you bypass the boosters
                      red legs going from the motor to the battery the magic stops
                      due to the elimination of the internal resistance like diodes offer.
                      Instead I have adjusted the back plate so the motor is at it's lowest
                      amp draw so when I go up in voltage the amp draw does not go way
                      up past 2 amps. With this adjustment the booster is a great tool to
                      vary RPM's. This is important when you use the motor in conjunction
                      with a lenz free tesla coils so tuning adjustments can be made to
                      get the exact frequency for rotor acceleration.
                      It is taking me forever to get anything done on this because I
                      work 12 hrs a day.
                      • Good windings
                        It is amazing to watch this little modified motor
                        (Energizer at high speeds) run between positives with the
                        2 boosters so swapping the batteries is not needed.
                        Using the same 1.3amp load on the inverter the results show
                        conclusively is every run that per hour the point count drop
                        is .05.
                        Using that smae exact amount of power or amp draw between the
                        same positive poles my little energizer (Two north poles) consistently
                        takes only .02 points off the battery voltage.
                        The drive booster lets me dial in the desired amp draw and or
                        speed for the motor. This will be very effective for tuning it to
                        a lenz free genhead.
                        I hooked 2 stepper motors to the shaft one at a time and in
                        each case the amp draw went way up while the stepper motors
                        offered almost no power in return. These tiny motor have huge
                        cogging losses before any current is produced.
                        This step to verify beyond any reasonable doubt that the
                        Matt Modified Motor is returning power back to the source is
                        complete.
                        I used 20awg magwire 50 turns, 40 turns, 40 turns. It runs cool.
                        As far as I can tell it uses 2.5 times less energy as my inverter
                        at the same draw. Or it has a cop of 2.5
                        • Video of Scooter Motor Energizer
                          This is a video board talk as well as an actual view of my split
                          positive, 2 booster and modified scooter motor that returns some
                          of it's own run energy back to the run battery.
                          Have a great time of the year and say GOD BLESS YOU. This is the
                          reason for the season. Try it, you will never be the same. It is like
                          saying "I LOVE YOU" which many people can not say and mean it but
                          go ahead anyway, you might be surprised.
                          https://youtu.be/iAc_oH2gBvs
                          • Inverter VS Mod Mtr
                            More Data In (Still in Progress)
                            Test 1
                            Inverter using a 1.25 amp at 12.33v on the run and dropped to 12.15v
                            under load for a differential of 14. 35v. This means the power consumption
                            14.35v X 1.25amps = 18watts for 1 hour or 18watt/hrs or
                            18w X 3600 seconds = 64,800 Joules.
                            So using this as a standard in our test sequence the inverter using 18watts
                            took 64,800 joules in a 10 point drop on the voltage starting at 12.33v
                            So using these watt burning figures we can divide by 10 and say that
                            for each point (approx.) drop on the meters the joule count is 6,480 joules
                            burned up. Or
                            Point Count
                            1 = 6,480 J
                            2 = 6,480 J
                            3 = 6,480 J
                            4 = 6,480 J
                            5 = 6,480 J
                            6 = 6,480 J
                            7 = 6,480 J
                            8 = 6,480 J
                            9 = 6,480 J
                            10= 6,480 J
                            For a total Joule count per point.
                            Test 2
                            Modified Motor
                            8:25pm the test began with the voltage at 12.23v where we left off.
                            the loaded voltage was 12.05 at the start and the loaded voltage dropped
                            to 12.02v ending the 1 hour run. The motor pulled the 1.25 amps and
                            a slightly elevated differential voltage of 26.5v (run pack Volts) minus
                            the charge battery voltage now at (average) 12.03v or 14.47v.
                            After resting for 1 hr from 9:25pm to 10:25pm
                            the meter showing a resting voltage of 12.21v
                            So resting voltage dropped .02 points and loaded voltage dropped .03
                            points. Using our joule count above for a .03 point drop we get
                            6,480 J X 3 = 19,440 Joules used up not the 64,800 J the inverter took.
                            Test 3
                            Modified Motor
                            10:30pm startup resting voltage picked up where we left off at 12.21v
                            the watts were approx the same at 18 watts. the loaded voltage at the
                            beginning of the test was 12.02 and went down to 11.98v one hour later.
                            So this test ended at 11:30pm and after resting another measurement
                            was taken for the resting volts of 12.16v
                            So a 4 point drop or a .04 drop or 6,480J X 4 = 25,920 J not the 64,800J
                            the inverter took.
                            I have to go unhook.
                            PS gonna run one more inverter test BRB
                            Last Test underway with the inverter.
                            TEST 4
                            Modified Motor
                            At 12:30am the standing voltages was 12.16v and the loaded voltage
                            had gone down from 11.98v to 11.93v then I stopped at 1:30am
                            At 2:30am which is 1 hr later my resting voltage was 12.11v so anyway
                            you cut it this is a .05v drop for a joule count of 6,480 J X 5 = 32,400 J
                            At 3:30am central I will unhook the inverter and show figures.
                            • Okay here is the crazy deal.
                              My motor has been climbing up in voltage on the boost meter from 16.5v
                              up to 17.2v during the dang test over an hour I find the amp draw going
                              up with it to near 20 watts. Crazy.
                              Then if that is not enough the inverter test shows me an ever diminishing
                              amp draw in a declining curve. When i got back at the end the watts had
                              dropped to 15.5w crazy so not a very controlled test right? Right!!
                              The start up volts 12.11v the ending and after nearly an hour the voltage
                              stabilized and the first 30 minutes it was done climbing coming in at 12.02v
                              i consider it a dead battery. The loaded volts went from (actually gained
                              2 points doing motor runs)11.95v down to 11.86v.
                              This is approx the same as the start for test #1 using this inverter.
                              I have a long way to go learning to get an accurate joule count but even
                              in the face of divergence of motor and inverter the motor still blows the
                              inverter away.
                              • Fresh Charge Resting 12:90v All day
                                Keep an eye on this page this morning as I am updating right now.
                                NEW CONTROL TEST with inverter. Time Out 11:45pm
                                12.90v resting 6 hours after last night and this mornings bulk charging
                                at the C/20 rate on ALUM batteries. Second stage of charging was done
                                at half the C/20 rate for 5hrs then the amps were raised to top off
                                well under the C/20 rate holding at 16v for 10minutes and then 16.4v
                                for another 5 minutes. This was all done using a transformer (toroid) to
                                bridge rectifier and smoothing caps. RAW DC or RAW DIRECT CURRENT.
                                The inverter was loaded and the drive energy is as follows.
                                Feeding the the drive booster at 1600ma and a differential of13.64v at
                                the beginning portion of the 1 hour run and the ending differential 13.72v
                                which averaged is 13.68v.
                                Drive energy was 13.68v X 1600ma = 21.888w
                                Over the 1 hr run the battery went from 12.90v then stop to rest 1 hr
                                the battery was 12.77v. This is a 13 point drop. The run loaded volts
                                were 12.65v down to 12.55v at the end of 1 hr running. This is a 10
                                point drop.
                                The Control test was stopped at 12:45am central and at 1:45am the
                                final reading was took. Using the smaller of the two point drops we see
                                the 10 points was lost of battery voltage.
                                Joules are watt/seconds and for each hour we have 3600 seconds this is
                                21.888watts X 3600 seconds = 78,796 joules that were used up over
                                a 10 point drop. So we may find the amount of joules used up for each
                                .01v drop on the meter. This is
                                78,796J / 10 = 7,879.6J per point drop. or 7,880J rounded off.
                                Each .01v drop
                                .01v = 7,880J
                                .02v = 7,880J
                                .03v = 7,880J
                                .04v = 7,880J
                                .05v = 7,880J
                                .06v = 7,880J
                                .07v = 7,880J
                                .08v = 7,880J
                                .09v = 7,880J
                                .010v = 7,880J
                                The inverter drive booster was set at 14.5v while the run batt recharge
                                booster stayed as always at the 26.5v setting. The recharging booster
                                ran at 3.60amps during the entire control test.
                                This is only relevant when you consider efficiency losses. 2 Boosters
                                passing a calculable amount of power at an average of 90%. This is
                                another subject completely.
                                This is our control test standard for conventional watt burning.
