Spools are 1-5/8" wide by 3" Dia. using number #25 AWG thinking
75-80 feet per strand at 12 strands should fit must calculate mil spec.
for ohms per thousand.
BTW that C core is tact welded back together from MOT material. Before
you cut the original apart you briefly weld in places with the same soft
1/16" rods that the factory uses or you could drill and rivet but squeeze
in a vice first or clamp the leaflets together right by the hole you are drilling
to eliminate separation.
Then quick epoxy your spool to it. This is not the only core material you
should be using, maybe later after my son Jordan gets an idea what iron
of electrical steel is like, we can move on.
http://flyer.thenetteam.net/3batterygen/jorbuild1.jpg
http://flyer.thenetteam.net/3batterygen/jorbuild2.jpg
http://flyer.thenetteam.net/3batterygen/jorbuild3.jpg
http://flyer.thenetteam.net/3batterygen/jorbuild4.jpg
http://flyer.thenetteam.net/3batterygen/jorbuild5.jpg
http://flyer.thenetteam.net/3batterygen/jorbuild6.jpg
http://flyer.thenetteam.net/3batterygen/jorbuild7.jpg
