Splitting The Positive
  • Thx Yaro
    Many people look at the bifilar coil as if it can only be in the form of a
    pancake coil. I know because that is the way I thought too. A bifilar coil
    can be arranged in a cylindrical fashion as I am sure you know.
    The pancake coil is for high voltage but how one differs from a piston
    or solenoid coil. I am unsure.
    • Lenz free magnetic diode.
      Ottawa Skeptics
      [VIDEO]https://www.youtube.com/watch?v=GOGpE6AXDUI[/VIDEO]
      • Speed up under a load type coils
        10yrs ago
        [VIDEO]https://www.youtube.com/watch?v=yhPUlunwhPk[/VIDEO]
        [VIDEO]https://www.youtube.com/watch?v=vaf9v0K-rZw[/VIDEO]
        • Hi mike, thanks for sharing the Alex Manzanero, low or lenz free coil video, I'm going to experiment with that.
          peace love light
            peace love light
            GLAD U LIK'EM.
            [VIDEO]https://www.youtube.com/watch?v=nigD1c3aBUA[/VIDEO]
            • Started work on multifilar coil
              Hi all, Hi bromikey, thanks again for the helpful information, I have started work on the coil and I walked almost half a mile.
              Used 2 - foot long pieces of 1" diameter pvc tubing for the posts driven into the ground, marked off at 40 feet length, then walked 2000 feet for 51 strands of 30awg. magnet wire.
              Worked up a little sweat doing that.
              Have to unwind one of the coils off one of my adjustable wood/bailing wire core mounts, so I can wind this monster 51 strand on there.
              peace love light
                you are going be excited by what you learn.
                • Hi mike, I think you are correct, will be fun experimenting.
                  Oddly enough, all the wire fit exactly on this coil/core former.
                  peace love light
                  • Hi all, Hi mike, coil progress is coming along.
                    Using a lighter to melt off enamel on end of wires, then fine sandpaper to remove any soot, it works well.
                    Was wondering though, what did you use to terminate the wires.
                    I have a few of those wire connector strips, though most of them are only 8 position strips. Wondering if you had a cheap and easy method to be able to connect and remove the wire connections for testing.
                    peace love light
                    • Magnet Sizes and Effects
                      THINKING about shielding and overlapping fields that cause fiction
                      and heat generation also structural pounding.
                      • Hello sir, so shielding also can enhance super pole configurations if it is used in circuit that way?
                        • Hello Skywatcher, my question to you, why is your gap from rotor to coil so wide?
                          If I may, my gaps on my large generator are the thickness of a paint stir stick.
                          It ran my house’s power.
                          The neos are n52 and mounted on previously set weaker ceramic 8 on pine wood glued and heat shrink tubing three times to keep magnets in place.
                          • Originally posted by Pot head View Post
                            I am stressing the need for shielding in the scenario
                            Magnet to magnet and Magnet to Core balancing act.
                            The side with 2 magnets and especially unshielded has 2X-3X more
                            reach than a magnet to core interaction, thus complete balancing
                            never takes place.
                            This imbalance with cause heat and stress.
                            • I noticed the transistors on my setup ran very cold when I switched to stronger magnets. The increase in performance was unmistakable from weaker C8 magnets. The battery bank charged quicker.
                              • Originally posted by Turion
                                If you are going to do it correctly, you will need rotors several inches thick so that the shielding can be effective.
                                https://www.amuneal.com/magnetic-shi...ding-materials
                                interesting article Dave thank you for considering my entry.
                                Here is what I found out on the bench. A 1" long magnet 1/2" thick
                                without a shield will result in a longer reach than the magnet to core
                                side. With the shield installed that is 1/16" iron the pounding due to
                                imbalance is greatly reduced.
                                All I have to go on is what I am trying. The diagram explains how a
                                shielded (Or semi shielded magnet say 90%) field is pinched off on the
                                outside and pushed out front.
                                During experiments I was able to create a much better balance than
                                without shields. In fact i was completely unable to get even close to
                                a balance without shields, that is what got me thinking, so I tried it.
                                If you have a shield on a magnet all or 90+ % on the field interaction
                                is out front of it. My core would not be in contact with the magnet at
                                all while the opposite side where both north pole are were very reactive.
                                Very little balance without shields, it helps but not as much.
                                Jordan and i will show you our demo coming up.
                                We are not trying to shield to the ""N"th Degree" which is virtually
                                impossible. Unless you try it with a long magnet you wouldn't know.
                                The diagram is incomplete, all magnets must have a shield. Remember
                                that my rotor is plastic and magnets just sit on top of it?
                                Using only a single shielded magnet (No shields on the rotor) for
                                counterbalancing improved the system tremendously. Less pounding.
