Splitting The Positive
  • My experience.
    With good quality wheelchair motors and a carefully matched load
    I reckon about the best I can get is 70%.
    Some people have the idea that designers are idiots, in bistander's
    generator info they're claiming 98%, I think that's a fantastic
    achievement.
    I'd like to see someone beat 98%,that's the challenge.
    John.
    • He can only distract and confuse
      Originally posted by Turion
      Ismnuts,
      When they talk about 98%, they are talking about the motor’s ability to convert the electrical input into mechanical energy. Whoop tee do! If a motor is only 80% efficient but you can recover 60% of the power used to run it in the first place, what is the “efficiency” of the motor? It is STULL only 80%, but there is a gain in the “system.” That is what we are talking about here. You can’t look at just one part. You have to look at the system as a whole.
      Like this?
      Just want to point out that my generator puts out between 1800-2000 watts while running on a STOCK electric motor that requires 240 watts input. ...
        Bro Mikey
        Apparently bi has permanent magnet motors that have no wires on the stators. No coils at all. Since he says if you have coils, or wires on the stator you have no cogging. And cogging is the magnets on the rotor reacting to the iron in the stator, which, according to him, can’t have wire on them or because that would make them coils and when you have coils it is something different and not cogging. I guess
        What are you talking about?
        You can't even learn what generator cogging is. Cogging would and does occur without the wires because it only depends on the core and magnets. Coils and wires are irrelevant to cogging. What's so difficult to understand about that?
        • Coils & cores
          What I am talking about is that in the kinds of motors YOU are talking about, the iron you mention is the iron of the stator that interacts with the rotating magnets on the rotor. Those stators have coils wound around them. Coils. Do you get that? coils.
          Now in the generator WE are talking about (or use it as a motor) the stator metal is the iron core of the coils. Without it, there is no generating or motoring action. So the cores of these coils are JUST as important as the iron of the stators YOU are talking about. Remove the "coils" from our machines and you remove the iron.
          So when you say the coils have NOTHING to do with it, you are about as far from correct as you can get. The iron in the core of those coils is EVERYTHING. and it is what causes the cogging. Got it? So you cannot evenDISCUSS the generator without the coils. Neither could you discuss it if it were being used as a motor.
          The coil is the copper wire. The core is the iron in the center of the coil. Those are two separate pieces or components of the generator. The coil core in your device is the same as a tooth on the stator of a more typical commercial armature (which happens to be the stator in a PM brushless generator). If you took your coils off of the cores, leaving the iron cores on your stator and turned the rotor with the magnets attached, you will getting cogging.
          Put the coils back on the cores and you still have cogging. The cogging doesn't change due to the copper coils.
          Do you ever read up on this? There is a lot of literature out there. The parts and terminology of generators are well established. Many of the home wind turbine builders use homemade generators similar to what you build.
          • Originally posted by Turion
            Bro Mikey
            the stators. No coils at all. ......... I guess
              THIS was my definition of cogging, which YOU have stated is incorrect, yet you just described it exactly the same way. You say eliminating cogging is unimportant because it goes away at high speed. I say THE AMP DRAW of the motor IS AFFECTED as long as the iron is present, there is a MAGNETIC DRAG on the motor (which is cogging sped up) therefore ELIMINATING cogging is beneficial. You don't think it is necessary because at high speeds there is no PHYSICAL affect that is VISIBLE, but there is still an amp draw from rotating the magnet past the iron core. MEASURE IT WITH AND WITHOUT an iron core present, or in the case of MY generator, with and without 12 iron cores present, and then tell me there is NO benefit to eliminating that increased amp draw. NOWHERE in any of your dictionary definitions of cogging do they discuss the increased AMP DRAW that would NOT BE THERE if the metal was not there, and which I am able to eliminate through magnetic neutralization. You continue to put down something you don't know a single thing about and insist that WE need to do our homework.
              You're wrong. In most of the "dictionary definitions" you'll find it stated that cogging torque does not show in the net torque of the machine, or in other words, cogging has no affect on the net current. It's just a ripple.
              Magnetic drag is not cogging. Show me a reputable source which says it is.
              And I do know a great deal about electric machines, motors and generators. But you refuse to learn. But all this cogging and clogging is a waste of time. Show me the 1800 watt output with 300 watt input generator.
                You're wrong. Show me the 1800
                No, No motor mouth, show me anything. You keep repeating, table
                turning riddles. Show something and stop boasting about nothing.
                Everybody has motor experience. Show us.
                Turion Man is da man and he don't just flap his jaw, he shows his stuff
                around. He is one of the few men who actual had an idea and has shown
                his working unit. Today it works, not someday.
                Where is yours? Did you go over the instructional data? No? Still repeating?
                Repeating old slogans? Hummm..?
                  You can't back up your statement so you change the subject to me,
                  or to coils, neither of which are relevant to cogging.
                  What is relevant is that you don't understand how motors operate
                  today and for the past 100 plus years. That is what you have shown
                  the group.
                  The important data of the repealing forces is very important and you
                  have ignored the standard definitions while quoting the dictionary
                  riddles. You and the classical thinker are wrong or confused.
                  The reason you can't think for yourself is that you went to govt run
                  schools and tho some did also go to those were able to read between
                  the lines. Not you.
                  The govt controlled schools of the past 100 years and the same control
                  freaks who silence Tesla. Your responses have uncovered your ability
                  to grasp the experiment and you can't see it. I got what I wanted from
                  you.
                  But you don't seem to know that. Turion is a teacher and saw this so
                  is having pity for you and those who think just like you. Go back and
                  read and review the information offered to you.
                  Repeating will get you nowhere on this thread. All it does is gets you
                  a sort of shame that brings about pity. However someone out there
                  will learn from this.
                  • Magnetic drag is not cogging. Show me a reputable source which says it is.
                    Could someone please explain the difference ?
                    • Oh what a bind!
                      https://en.m.wikipedia.org/wiki/Eddy_current_brake
                      • Coil free.
                        https://en.m.wikipedia.org/wiki/Cogging_torque
                        • There ya go.
                          http://www.koshindenki.com/img/file/...vr_R3a_Std.pdf
                          • Problems in the real world.
                            As Coreless Dc Motors usually can reach very high rpms and has a compact structure, these motors can heat quickly. Especially when running at full load for a short time. So it is usually advised to use a cooling system with these motors. Overheating can be an important problem specially for Coreless Micro Dc Motors. So a disadvantage of a coreless motor is, it cannot handle overloads when compared to a cored motor. The bonding adhesive that holds the windings can lose its bonding character and the motor will be broken.
                            What use is a broken motor?
                            • Cogging vs drag
                              Hi Sawt2,
                              Cogging is strictly due to magnets and iron (core). Magnetic drag can be caused by both magnets/iron and magnets/iron/electromagnets.
                              Cogging is due to the tendency of the rotor magnet to align with the core projection (as the iron in the center of the coil). That tendency acts in the direction of rotation on one side of TDC and against rotation direction on the opposite side of TDC. So the equal magnitude but opposite tendencies (or torque) cancel when looking at average torque (or current) input or output. However cogging will be present and represent torque ripple which is most noticeable at low RPM.
                              Magnetic drag, on the other hand, always opposes rotation and becomes greater as RPM increases. It is due to core loss, ie. Eddy currents and hysteresis. For motors and generators, magnetic drag is a loss mechanism. Magnetic drag is purposely used in applications like commercial magnetic brakes and clutches. Cogging is not.
                              There is much literature on the subjects. I encourage you, or anyone to look at it.
                              https://www.designworldonline.com/th...agnetic-brake/
                              • Claims
                                You're wrong. Show me the 1800 watt output with 300 watt input generator.
                                He made the claim. He has never shown a working unit of the 1800 watt output/300 watt input machine.
                                I made no claim. What am I supposed to show? Something that doesn't work?
                                You claimed that the magnet repelled the steel. Show us that. That's what started this episode.
