The Known Generators...BS
Hello SidL,
My pleasure friend to welcome you here and also encourage to proceed in your work, you are definitively going in the right direction and right reasoning!
I have a perfectly working and pretty new electric motorcycle...and the Controller is programmable through my Laptop, I have redesigned its BMS (Battery Management System and the Motor Controller) so I can switch the Regenerative braking up to 20% as Max (Mine does not activate when braking, but whenever I stop accelerating...Normally Open/Normally Closed SPDT (Single Pole Double Trow Micro Switch) at accelerator) ...and when I do so (20%), this "enhanced option" will work like putting the bike on first gear...when going 65 MPH on fourth. Meaning, it just brakes/stops the movement to almost a full stop. The best working percentage is around 12%...but then again, when I have an 80Amps, 5000 Watts consuming Hub Motor...it is just a big joke to think that the batteries would ever be "regenerated".
The point above is just to explain that the actual (Only Known) type of Electrical EMF Induction Generators (in General, talking about ALL Generators in the market as of today) that we all know is also a Big Fraud.
And no matter how much we all try to get them installed or connected (wired)...We will still be fighting the Reversed Forces (Lenz Law) in a "face to face" arrangement...so no matter how much we try to generate electricity...Lenz will literally "take it all away" from Us...plus leave us in negative values...why?...just because it is a perfectly conceived Mirror Geometry...a Symmetrical Induction, The biggest Scam ever done to Mankind...
So why we have not developed a better way to generate electricity from magnetic fields for over 200 years?
Is the Human Race so stupid?
Nope, we are not stupid...we are all just trained by the Academia (I love that name you call them, thanks!) in the wrong way, the wrong model... about How Magnetic Fields really are and how they really work, plus the way they are structured...that is absolutely the whole "secret" behind all this fraud that have lasted over 200 years.
The only known Induction, since Faraday discovery in August 1831...is a Mirror Symmetrical one, Linear, at 180º...and the best demo is the typical cylindrical magnet going into an empty Coil (air core) as the perfect example...we go In, meter marks positive generation...we "try" to take it out and Lenz opposes linearly from us to pull it away...meter marks negative induction in exactly same magnitude!...And so we try to push it in again, then, like "magic" Lenz prevents from Us going inwards...Repeat.
That is plain BS...We can go 90º and still Induce...while Lenz miss our movement by 90º...but in specific ways...not like above.
The only known "Suitable Magnetic Field" to generate EMF Induction comes from the stupid, "Imaginary Lines of Force" Only conceived from what is known as a "Uniform Field"...meaning, from North to South...another plain BS.
We can generate an EMF from Repulsion Fields (North to North or South to South) where the "Imaginary Lines of force" from pole to pole, according to the "Iron Filings BS Method" (another complimentary "proof" Scam, Fraud that comes in the same package) does not "reveal" such lines...more BS...Repeat.
And the most, the top knowledge we are all missing here...:
Magnetic Fields can go through the Mass of any material in this Universe...just the Magnetic Field, not the "material field carrier" meaning whether a Magnet or an Electromagnet...and an EMF Induction WILL BE Generated.
So...a "Dancing Spiritual Field" going through a previously wired steel core sequence, just like water runs in a river...or clouds move in the sky by the wind forces...effortlessly...we can also obtain electricity...and the effort to do so?...almost no force required to move such a massless, weightless field through any material mass.
But absolutely no one would believe me when I write this things...all over this Forum...why?
Just because it does not "fit" with the "Academia Model" we all were trained to know about Magnetic Fields...
And yes...I am building this Machines...
And I will "Welcome You All to the Machine" very soon...
Hello SidL,
