Originally posted by bistander
Miller Colson Magnetic Motor
Originally posted by mike_kilroy View PostThanks for the reply Luc.
And of course the 20#ft torque is not continuous throughout the whole 360 degree rotation: I do not believe anyone ever said it was. That is why ICE engines have fly wheels, just like Sonny's machine had a flywheel...
Originally posted by mike_kilroy View PostIt is a shame you could not put your 4 channel scope on his machine when the timing was correct...
Sonny knowing we were coming form a distance, should he not have warned us the device was not in ideal working condition, before we did the trip to measure it?
Originally posted by mike_kilroy View PostShame so many folks are working against each other to be the "first" to come up with the greater than unity machine.... but that is a politically incorrect comment...
Originally posted by mike_kilroy View PostI have looked at the stuff you and floor have done - very good. Ya'all understand that the greater than unity - excuse me, torque multiplying stuff, is done by exploiting the fact that the magnetic attraction can be larger than the un-attraction of the same equal but opposite motion by devious means. Ie., by exploiting using attraction (or revulsion - it does not matter which you do) and making a SMALLER force on reverse stroke by either TURNING magnets 90 degrees from each other, AND/OR (no one has yet to try to use BOTH to get reduction in 1/2 again!!!!), as you saw Sonny do, SLIDE them sideways off each other. In either method, the magnet strength of the "return" stroke can be made LESS than the "forward" stroke and thus torque multiplication. Pretty basic stuff, but it requires the wizardry and out of box thinking such as Mr. Sonny Miller has shown so many of you.
Also, just so you know, floor never heard of the Sonny Miller device till someone brought it to his attention several months after he had started his topic.
Originally posted by mike_kilroy View PostYou really should give Sonny his due: he has shown that this is possible, and then you guys are now expanded on what he taught you.
Sonny Miller's device failed to demonstrate OU. In fact, as soon as the prony brake (20 ft/lb load) was engaged the power input to the device would go up by around 110 Watts.
The only credit I would give Sonny is, when I came back from the failed trip, I decided to build floor's device to see if it was a better solution since I had been following floor's topic months before knowing of Sonny's device.
Originally posted by mike_kilroy View PostIt is my opinion too that Sonny may not understand the electronic excitation side of this enough to have taken his design AT THIS TIME to the next final step, but he certainly led you guys in the direction you need to go to finish it.
Originally posted by mike_kilroy View PostI have high hopes that Mr. Miller will hire a LOCAL electronic wizard (God knows I have tried to make it so!) to take him through his timing issues; to date that has happened. If he had LOCAL DAILY electrical servo guidance I believe he would in 2 months have the finished product that is a true torque multiplier. But of course that is just my opinion, having supplied the servo and controls to date.
My device then Sonny's device. Anyone see any resemblance?
Originally posted by mike_kilroy View PostGood luck to you sir, and floor, in furthering the use of this magnetic force no one knows the source of. Perhaps if the three of you wizards were to work together...
Never got a reply.
So we need to ask our self's, why the fuss now?
Sincerely
LucLast edited by gotoluc; 03-05-2017, 12:08 AM.
additional clarity and an error mentioned
from here TD replications
Luc
quote
I now see a terrible error!... the 16.125 inches was for each section of disengage then engage. So the 16.125 inches would have to be multiply by 2 = 32.25 inches of outer rotor traveled for 180 degrees, making the rotor 20.53 inches in diameter and the device under unity from the calculated math.
So the input rotor traveled 6.45 times the distance of the output. So input average is 1.1Kg x 6.45 = 7.1Kg input to 6.25Kg of output so under unity by about 12%
I'm so sorry for your trouble and expenses.
Please accept my apology.
At everyone, please accept my apology for the trouble my over site may of caused
Kind regards
Luc
end quote
so for Clarity
this experiment is considered underunity
however
*also to note
Butch Lafonte has been researching these interactions for many many years
someone playing with his work below ,as well as his you tube Channel
for consideration ?
https://www.youtube.com/watch?v=XG3sVLw_WDw
and Butch's channel
https://www.youtube.com/user/LaFonteResearch/videosIf you want to Change the world
BE that change !!
