Hello to All,
I just finished the Secondary...prior, I did two Primaries.
[IMG]
[IMG]
[IMG]
Primaries are wound with 16 awg, around 65 T per layer totaling Four(4) layers...Total Resistance 0.5 Ohms.
Secondaries are wound with 14 awg, around 55 T per layer at a Total of Eleven Layers (11)...Yeap...lot more than Primaries...did not have more room otherwise I would have kept going...
I used a special tape that cost me a lot of work to finally locate and order...:
POLYESTER 2MIL 425º F TAPE
These people are awesome, lot of goodies and good prices as different sizes and colors...
I used first a layer of Fiberglass Mylar Fiber Sheet used for High Temp Electrical App (I use it for Motor and Generators Hedges)...secure it with tape and start winding...this way I can slide off whole coil out for testing...plus by using tape at every layer, have no chance to mess up layers by forcing one wire from another one etc,etc...plus gives a fully strong coil after is finished, even out of core.
Now, while I was winding Secondary...and after exchanging some mails with MM...about secondaries Output...
And I came up with this idea, which I did not applied on the secondary winding shown on picture above...but I definitively will in the next!!
If we wind Secondary, and every layer we extend wires out, just in a loop...then later we cut it and mark it (Layer 1) and so on...then we could read our output per layer in order to be able to calculate later how many layers we need for System Supply...
Also, and very seriously...that way we do not go overboard...You know what I mean right?...Yeah, I meant going too far in Kilowatts at output which could be really dangerous by being close to Megawatts...
Tomorrow Land...I will be running some tests...Oh!, and forgot...My weak PSU will feed each Primary at 6V and 10 Amps...and so far magnetic field looks good...have to test with this Secondary what is the Output.
I believe the right Input (whenever I get the ordered 900 W Linear PSU)...should be in the range of 40V and like 5 Amps...I don't think it would need but maybe -/+ 10V and -/+ 1 Amp more.
See you all tomorrow...and maybe we will have some nice Christmas Presents then...
