Figuera Device, Part G Continuum.( Serious Builders Only)
  • Hi guys,
    I started to make an offset conch shell type design, based on a theoretical homopolar motor designed by Walter Russell. there are some similarities to his design and the previously unknown Figueras design: other than Tesla's comment about the weather in Las Palmas. I attach this design for observation. That is, the moderated drive.
    Also, I am mindful of Tesla's comment regarding Figueras design. This makes me think that, while the trend has been to provide a constant DC bias throughout the process, it is possible that the "Radient Spike" was a known phenomena in 1902. Or if not explicitly acknowlegded, noted for its energy output. This would imply that the notion of the NyN, SyS, NyS, SyN only have to achieve a Bedini type output. Or, in other words an early "Solid state" device.
    The alternative, as the implication is one of motionless simplicity, is SyN or NyS, using the total exciter coil array as a Resonant modulus. That way, the exaggerated output that Firgueras perceives to occur, could provide the answer being sought.
    Coming back to the Russell Design, I have been toying with a magnetically driven commutator, and, in one test, it is as Russell suggests linearly in its increase in speed. A bit like a series wound DC motor with no control, it can be quite frightening. Is it possible that this scenario is possible with Figueras Generator? Is Figueras right angle connection is as Russell summarises it in the attached drawing
    Just some thoughts of my two possible directions. A case of suck it and see.
    Dwane
    • Originally posted by hermesatar View Post
      Hi all,
      I have made a more effective version of Figuera generator patent. I my version the input coil is in the middle and is energising the output coils to left and right. While the Figuera patent the input coils are at the end and is energising the central coil, but half of the magnetic energy are lost to air, because the outer ends of the generator coils faces air.
      Hermes Free Energy Transformer
      Best Wishes, Hermes
      Hi there winged messenger of the gods!
      I too have experimented with the single configuration such as you posted. I too came to the same realisation! A solution that I am working on is using two U shaped cores and two single cores to join together excitor coils and output coils. So each U shape has one large coil but, there are two output "y" coils. I am wondering too, whether this configuration may enhance output and or low frequency resonance.
      I experiment with low carbon steel rod/bar, which I anneal above 730 degrees and below 1000 degrees, the phase change at this temperature "leaches" the carbon from the rod. However, any mechanical or machining of the rod can precipitate surface magnetisation. So, one would have to heat the whole thing up again!
      Dwane
      • Spain Electric supply
        Hi guys,
        One cannot but wonder at the mastery of Clemente Figueras and his knowledge of induction and in particular electric circuitry! I have also wondered why so many patents were issued for the same item. The answer to that one possible resides in the development of a knowledge base. Having conceived the idea of transforming the operation of the generator from motion to motionless, it would have become clear to Clemente that the method of pulsing was crucial to the success of his invention. As clever as he might have been, living and working the forests of Las Palma, as was his profession, would not have provided the background essential for development of an electricity plant! He would have had to educate himself for the task he became committed to. I have attached a Historical perspective of Electric Supply in Spain from Then until now! At the time of the possble formation of Clemente's idea, street lighting was only beginning to be introduced into Madrid and Barcelona. As the document reads, the early commencement was from imported Gramme Ring Generators in the 1880's.
        Therefore, Figueras patent is quite an achievement. Albeit slightly understated in its technological understanding. I think the initial pulsing of the N and S electromagnets might have been squarish. As can be shown, the availability of AC, although known, did not hit the major cities until some time after the initial Figueras patent. While it was likely that there was a response from the coils, the output might have been disappointing, given the response from pulsing iron cored electromagnet. How he would have arrived at the variable drive to the electromagnets is anyone's guess. But, a logical conclusion from understanding the operation of the generator. Thus the Buforn patent would have been the result of some years of commitment to wishing to see a final product that worked. Still, quite an achievement, and especially if there were limited tools at his disposal to analyse the output. Today, we pop down to the electronics shop and are able to buy all sorts of, components, specialised meters and tracing equipment. The fact that we struggle with his concept becomes evidence of Figueras' tenacity and strength of character wishing to see his project working.
        All in all, a great inventor!!
        Dwane
        • New Build Started
          Hi guys,
          Have started a new build for the Figuera Device. Have had the mild steel core cut to length. 16 at 3" and 8 at 6". The larger y cores are longer to assist with transfer of complete flux during operation. As been suggested.
          Attached photos show my small kiln during the heat up and cool down of the decarbonising process. Will give soft iron around 99.3%ish if the steel specifications are correct. One photo at around 900C the other, showing classic scaling for successful result after cooling.
          Next making the Bobbins. Bit of head scratching required for this next stage!
          Dwane
          • JohnStone is back :-)
            Hi friends! As expected I am now retracted and dare to chime in in order to meet you all again.
            I consider to start with Figuera replication within some month. But I do not feel comfortable with all those forums related being idle now. I tried to read through posts of last year and cannot find any clue or viable progress. How is the current state
            Rgds John
            • http://www.aboveunity.com/thread/cle...5-a88f0122b9ec
              • Thanks for the hint :-)
                • Hint 2
                  https://photos.app.goo.gl/mw8DsWQT7kF1UKxP9
