Recharging batteries is the sole useful purpose of a spontaneously combustible, ...
... free energy LMD, because this circuit does not self-run at anything less than Mega or Giga Amps. So, it must always be pulsed between alternate phases of drawing voltage from its DC source versus self-running disconnected from that source in such a manner as to regulate its ability to fry itself with too much amperage. Amperage is what this device freely manifests at any fixed voltage. And amperage is what will toast every component connected to this circuit.
CORRECTION...
Actually, the battery pack on my 2002, first generation, RAV4 EV recharges at a rate of one tenth the amperage to which it spends during driving. So, I cannot focus my efforts on merely charging the batteries as I drive. I have to focus on powering the motor's needs instead.
Perpetual Motion? Nope. Close to Perpetual Overunity. Slow Spontaneous Combustion.
One of my simulations of free energy in the confines of a simulator. Not very realistic since it fries itself within fifty minutes. But a lot better than some of my other versions of Eric Dollard's LMD module which fried themselves in a fraction of a second.
LMD = Longitudinal Magneto-Dielectric; acronym for an analog computer of an AC transmission line; in contradistinction to TEM = Transverse Electro-Magnetic or standard transmission line.
The technical term appropriate for this situation, instead of using the word: 'fry' is to use the term: 'spontaneous combustion' resulting from a parasitic oscillation. These latter phenomena plagued DC transmission lines of the Edison Power Company in New York city a century ago before they called in a specialist by the name of Steinmetz to fix the problem. Well, I'm trying to harness it!
Rock-Steady Filtration of Undulating Oscillations is Simple Analysis: Barbosa & Leal
Barbosa and Leal effectively create oscillations within the Earth between two sets of grounding rods, and then transfers this contribution upwards, above ground, to the circuitry of the Captor Loop's two transformers whose job is to clean up the undulating values of the Earth's oscillations into rock-steady power for our appliances (which we've come to expect of our power source). So, we could have used Eric Dollard's LMD module to bypass any need for utilizing the Earth by just powering up at least one LMD module. But not without passing that energy through the circuitry of B&L to clean it up and stabilize it for a load.
Maintaining ammeters above 200 Amps, averaged, combining TEM with LMD.
I got better results doubling my EV motors and taking the arithmetic average between them to guide my manually toggling, back and forth, between self-runner mode as distinguished from being powered by the DC battery source of 250 volts. And I think the TEM stack of LMD modules may be helping to equalize the two ammeter readouts?
Although the four central capacitors are under strain, and they're amperage and voltage are 180 degrees out of phase, ...
... the inductors representing the two motors only have their voltage waves undulating wide and narrow and completely in phase with each other while their amperage waves are a flat line of very gradual deescalation.
And of course, the voltage across the motors are exceedingly high at around several Mega volts.
Here's a way to blow up a power supply for an electric motor: use this circuit and toggle the switch twice to produce amperage overload...
As with many of my simulations, first download this small binary text file and save it onto your device: https://is.gd/kaboom, then load it into this simulator: https://is.gd/blankcanvas.
Rock-Steady Filtration of Undulating Oscillations in Barbosa & Leal
Maintaining two ammeters >200 A, averaged, using Eric Dollard's analog computer, LMD.
By positioning the load adjacent to its source, an overunity circuit can be relieved of some its burden. In other words, the sociologically programmed idea that the source must be on the other side of a circuit dividing the two from each other: load/consumer versus source/producer, encourages conformity to the convention of limited resources and underunity of performance. Every appliance should have its own power source built in so that no network of power grid should have to exist. Hence, no institutionalization of power production should exist in any "enlightened" society (which you would think is us?).
