Mechanical Magnetic Torque Amplifier
  • Originally posted by Pot head View Post
    Show your build!!! Prove it!!!
    Im calling you out!!!
    Take a look at yourself:
    • Little boy
      Folks, there is no filter for insane people.
      All you can do is tell the moderator about it.
        I currently have 153 vidoes of builds posted on my youtube channel; The functioning "H" bridge oscillator is the latest:
        https://www.youtube.com/user/zebok3/...able_polymer=1
        • Adams throw Henries.
          This 10 pound skein of 22 gauge magnet wire would carry nearly 5 Henries of inductance. This would deliver around 1 meter of Adam's resonance throw. Joe Newman ties 9 volt batteries together in series to reach voltages sufficient to overcome the large resistance.
          • Originally posted by Allen Burgess View Post
            I looked and it doesn’t exist.
            What videos? Nothing! It just is not your eon.
            • Hallucination
              Try clicking on the link.
              • Useless as you
                No one cares. You are a bowl of nothing.
                  You're headed for trouble.
                  • Adams kickback
                    Look at the spacing of these two Adam's rotor N facing magnets. They're attracted to the steel core of the relay coil, the reed switch masks the attraction with a coil pulse, then the Lenz reverse kicks the second magnet with a repulsive force:
                    The coil inductance would determine the distance between these two magnets. The same ratio applies to the MMM Adam's throw:
                    • The space between the 10 O'clock magnet and the center of the secondary U core is a function of the primary coil inductance and would equal the Adam's resonance throw if the coil were part of Luc's MMM.
                      A ratio of that segment of the arc factored by the coil inductance can calculate the travel of a 10 pound coil.
                      • 4 Kg levitating rotor
                        The 4 Kilogram coil is levitating:
                        Here's a video of lateral Mendocino Adam's resonance
                        https://www.youtube.com/watch?v=2VhQq_utlQg
                        • Not your build
                          Do not threaten me. That is crossing my line.
                          Your posts do not reflect ANYTHING you have built.
                          All the photos are NOT yours.
                          Mental Midgets often claim others work for fake glory
                          and to enhance their pitiful lives.
                          • Ok Allen go ahead and do your thing.
                            In the end, if you are above board and truthful about this information and you build it here with your photos then, just then, maybe, I might change my mind.
                              https://www.youtube.com/watch?v=EkXSvNzoCbs
                              • Core saturation
                                The levitator magnets at the ends of the ferrite core would saturate it and the weightless coil and core would have the same inductance as they would if the coil were traveling on a fixed core.
                                Look how Kundel generares rotary motion with a small linear oscillation:
                                https://www.youtube.com/watch?v=eNgd1ZVZtsY
                                An Adam's resonance Mostly Magnet Mendacino linear oscillator with Kundel rotary motor would be Ideal to replace a Diesel motor and ballast in a sail boat. Silent and vibrationless. 750% approximate efficiency after conversion losses.
                                The throw is in Adam's resonance range for the kickback; The width of a ring magnet on the rail:
