  • #46
    "A" vector test.
    I got some apparent lift this morning from the diametric magnet attached to the end of a wash tub pump motor. I initially was holding the magnet on the perpendicular to an overhead plastic dinner plate. I realized I was on the wrong plane , and when I re-tried it side ways, Lo and behold, it began to lift the plate as I pushed upwards towards it!
    I need to try it again with a barrier to make sure it's not air lift, but it's an exciting result nevertheless.
    • #47
      "A' vector wind hood test.
      I covered the wash tub pump motor and neo tube magnet with a ceramic pot, and got the same lift effect on the plastic dinner plate suspended overhead; So it's definitely the magnetic vortex supplying the lift not he air draft.
      The thumbnail sketch below illustrates the direction of diametric tube magnet spin and the plane of the spiraling "A" vector that projects outward away from the magnet. This spiraling field forms a "Magnetic Cushion":
      The plastic plate is non-magnetic, but there's a "Lenz Effect" from the magnetic vortex that generates an electrical field. This is causing a powerful static repulsion.
      • #48
        Originally posted by Allen Burgess View Post
        Take a look at this patent. Vortexing magnetic field on the horizontal plane:
        Link to "Rotating Electrostatic Propulsion System":
        https://www.google.com/patents/US200...wcAKQQ6AEIWDAH
        BRIEF SUMMARY OF THE INVENTION
        [0001]
        The invention, which is the object of my present application, is a spacecraft propulsion system which develops a spacetime curvature tension utilizing a combination of a rotating radial electrostatic field and a fixed vertical electrostatic field. The two fields create a stress-energy Tzr gradient in the radially direction which is equal to force. The radial field is created on the side of a charged rotating cylinder on the underside of the hull. The vertical field is created by an annular charged ring concentric with the cylinder. Three rotating cylinders are located in a triangle on the bottom of the hull in order to produce a force in any direction in the horizontal plane.
        I saw a TR3B in 2009/2010 leaving the Scientology Center in Hollywood, California.. it was only 10:30pm or so at night... It slowly hovered above the Scientology Complex and then like a streaking light in Star Wars/Trek, etc... it took a 90* angle and was off into space-time/transdimensional travel. It had an orange *PLASMA* glow from the bottom center.
        I swear under penalty of perjury for forgoing facts are true.
        "Rebellion to tyrants is obedience to God." - Benjamin Franklin + Thomas Jefferson
        • #49
          Originally posted by Gambeir View Post
          I have to say this is kind of shocking...actually...
          I say this because it occurred to me that what I've posted could be mistaken for plagiarism, low level plagiarism, but plagiarism nevertheless.
          Well I had no knowledge of this patent, and I doubt that I would have understood it had I not done the work that I have in trying to make sense
          of the ARV.
          This is interesting; the patent says -"7. Electric polarity switching of the fields in order to reverse the spacetime curvature and therefore change the direction of thrust."This ties in with the ferroeletics and crystals; which is making more sense now because of the amount of money being put in to R&D in those fields
          "8. The use of a magnetic vortex generator located above each thruster in order to permeate the cylinders and rings with low density hyperspace energy which would substitute for the embedded magnets in each cylinder."
          You're the man Gambier and onto it!!!!
          Keep at it man!
          • #50
            Keep at it man!
            Actually I think it's Allen that's the man but thanks.
            As for your sighting, well I've seen one myself quite clearly for about 2 or 3 seconds, basically hovering over the house a few thousand feet up and it also took off at a several thousands of miles per hour. I'm guessing mach 6 or higher. Really it was so blindingly fast that no human eye could track it. At 32 frames per second you're going to get 2 or 3 frames in that one second with which to decide if you've actually seen something, so unless you see it sitting still you're just not going see the thing because it's moving that fast.
            Totally believe you ET. There was a good video captured recently of a triangular craft like the one I saw. That one was captured over Mt. Baldy in California. It was a ways off, but clear and the best one I'd seen so far, but then the poster removed the video after only a couple days and there are no copies on Scrub Tube. I asked the poster if he was visited by men in black (gov-corp stooges) and he just said to forget about the video. That it must have been swamp gas, a balloon, his imagination.
            We got er figured goons...so just give it up: We is hip to the trip now.
            I feel it's coming together now. That we have a solid idea how it works and what the primary parts to the machine are. It's just a matter of time now.
            People have the information now. They cannot stop the outcome any longer.
            • #51
              I don't know what to say Allen....Amazing! Just fricking Amazing. You're the man....very inspirational work Allen.
              This is because of the Gadgetmall Coanda ya know. So that is now a virtual success story really.
              http://www.energeticforum.com/renewa...da-ou-ufo.html
              Starting to come together for me mentally now. Took time to study the first patent and now see clearly, I think, the links to the ARV's system.
              I am now studying the second patent.
              • #52
                Here we see an ant riding on a magnetically levitated piece of pyrolytic graphite. The TR-3B hull is made from the same material and hovers over the spiraling "A' vector magnetic vortex field underneath:
                I know you're right about this: It's the magnetic vortex and Pyrolytic Graphite.
                About 20 or so years ago, I was flying model planes and was a member of this club which was almost completely made up of Navy Fighter Jocks and retired aerospace engineers.
                So I bulit a model of the F-117 and took it to our little meeting where I was naturally required to blab about it. Well so I'm giving one my typical dangerous armchair ideas about the materials used in stealth, at that time largely unknown, and I said that I thought the fuselage was carbon fiber.
                Fortunately, in a rare moments of lucidity I thought to ask a brilliant engineer named Dan Simenson what he thought.
                Simenson, then in his 60's was a retired engineer whom primarily worked on spy satellites. This was a brilliant individual. Well long story short is that inside of 60 seconds we were all lost in the complexities of nuclear spin states and how this then meant that the material wasn't carbon fiber at all, rather it was a Graphite Composite, and that the Radar Waves inter-react's with the nuclear spin states of the graphite to deflect the electromagnetic waves. That is, there is a vector resulting from the incoming radar which because of the angles of the panels that make up the body of the aircraft, it's fuselage, there then is formed a reflected electromagnetic wave to another vector away from the aircraft, as opposed to being reflected directly back to the radar as with typical materials.
                Well needless to say, no one other than Simenson had any idea what in hell he was talking about. Not at that time, and certainly not me, but today I can at least now gather what Dan was trying to tell all us chimps...LOL!
                I suppose that most of what Dan left behind for the rest of us is still locked up vaults, but this here I post in his memory.
                Links from the great people at The Outer Zone. A free model airplane website. Outerzone : Free plans : Collection of free vintage model aircraft plans to download
                https://outerzone.co.uk/plan_details.asp?ID=2274
                • #53
                  I recommend trying this.
                  Take a pencil (graphite) and cover the pie plate by drawing on it and then repeat the test.
                  Depending on results there may be other possible arrangements. Mere outline of shapes and forms; pyramids, tetrahedrons, ect, or by formed shapes made with glued paper and again possibly covered once more in graphite from a pencil, or possibly without: Unknown which will serve best right now.
                  *NOTE: It is known that the mere drawing of an electronic circuits can effect an result.
                  Mind Machines You Can Build by G. Harry Stine
                  • #54
                    I did a quick scan for information on St. Clair as a pseudonym and came up with this. ZPi | St. Clair: Hyperinventor
                    http://appft1.uspto.gov/netacgi/nph-...S1=20060071122
                    Full body teleportation.
                    and image here
                    Patent Images
                    Don't laugh....I am pretty confident this real, or something like it is. This isn't half as far fetched as some may imagine. Now then, the results of your first experiments makes sense based on the St.Clair patent below. I am studying this one now. I've posted a list of some of the St.Clair Patents. Undoubtedly there are more. Appears to be a pseudonym of some kind. So now about the results of a magnetic vortex are explained in the St. Clair Magnetic Vortex Generator.
                    "[0023]
                    4. In another patent application of mine entitled Magnetic Vortex Generator, it was shown that a rotating cylinder containing embedded and stacked bar magnets produces a negative mass and negative spacetime spring constant.
                    It can be shown that this combination produces a small wormhole or interdimensional connection between our space and hyperspace along the centerline of the rotating cylinder.
                    Co-dimensions of hyperspace have different physics constants. A low pressure region of hyperspace has a very low mass density and a very low speed of light.
                    The wormhole allows this low density hyperspace energy to enter into our space and permeate the cylinder and annular ring. The permittivity is proportional to the inverse of the speed of light squared.
                    The hyperspace speed of light, obtained from my tetrahedron physics diagram, is 8971 meters per second. The speed of light in our dimension is 299792458 meters per second.
                    As shown by the enclosed reference calculation, the hyperspace permittivity is about a trillion times larger. Because the force is equal to this new permittivity times the electric fields squared times the area around cylinder, the force is greatly amplified by this increase in the permittivity of space."
                    https://www.google.com/patents/US20030197093
                    https://docs.google.com/viewer?url=p...0030197093.pdf
                    Bobbin electromagnetic field propulsion vehicle
                    https://docs.google.com/viewer?url=p...0030209636.pdf
                    https://www.google.com/patents/US200...kc4ChDoAQgoMAE
                    Electric dipole moment propulsion system
                    https://docs.google.com/viewer?url=p...0060070371.pdf
                    https://www.google.com/patents/US200...UODlAQ6AEIQjAE
                    Electric dipole spacecraft
                    https://docs.google.com/viewer?url=p...0060038081.pdf
                    https://www.google.com/patents/US200...xg4ChDoAQg9MAQ
                    Photon spacecraft
                    https://docs.google.com/viewer?url=p...0060144035.pdf
                    https://www.google.com/patents/US200...Qk4FBDoAQgvMAI
                    Rotor inductance propulsion system
                    https://www.google.com/patents/US200...UODlAQ6AEINDAC
                    Hyperspace torque generator
                    https://www.google.com/patents/US200...UODlAQ6AEISTAF
                    Remote viewing amplifier
                    https://www.google.com/patents/US200...w04ChDoAQhZMAg
                    Permanent magnet propulsion system (*Battery NeoMagentic Wound Copper Wire Train as seen on Youtube) Know this one works for sure.
                    https://www.google.com/patents/US200...UODlAQ6AEIXjAI
                    • #55
                      Magneticd vortex generator
                      Quote from "Magnetic Vortex Generator " patent:
                      "Two separate, but electrically connected, toroidal coils of differing radii, carry magnetic flux in opposite directions about their common centerline".
                      Quadra project:
                      The coils visibly move upward against gravity when excited:
                      • #56
                        Quadra project:
                        Nail ejected from same arrangement.
                        I know this will seem like a joke but it's not. Remember* Never apply full power first! I don't need you teleported off world. Later might be Ok, when we have idea what's going on, but not right this second. Understand? Now along those lines, Spacecase0 turned me on to this interesting site, which involves a real case of teleportation among other possible uses: Worth looking at for a couple reasons. One reason is the antenna system mentioned in the ARV, and in the St. Clair Patents, and the other is of course the potential for teleportation. Meaning what to watch for if you want to stay here with the rest of the pathetic left overs....snort! Humor, mind you.
                        spacewarp
                        spacewarp
                        Teleportation: The Science Behind Bruce Gernon’s Flight
                        spacewarp
                        Here's a video on the experience. You will want to note what Gernon says about the tunnel he flys through at about the 1:45 mark in the video.
                        [VIDEO]https://www.youtube.com/watch?v=_Phx6Z1kSDg[/VIDEO]
                        I only have some cheap flat magnets which have the poles on either side of the flats so that's a hold up for me right now. I'd like to make a cylinder with bar magnets arranged along spirals. One which is capable of having a secondary tube inserted inside. Bar magnets simplify the test arrangements. It would seem that the St. Clair Patent was formed around experimentation with that arrangement. Which is beginning to explain why the core tube in the ARV is likely to contain an electrically conductive gas because it will be complex enough just using magnets. Otherwise, maintaining electrical contacts by some means, while having to deal with high speed rotating charged tubes will be an involved process. An electrically conductive gas would then be the best and most reliable form of charge carrier.
                        As a suggestion; For a test purposes an old blender motor has relatively high speeds. I found one at a 2nd hand store so now I just need some good bar magnets.
                        Also I might mention here that the sources to consult for laying out spiral lines on tubes are to be found from gun barrel rifiling
                        *Note: The purpose of the image shown is to illustrate how to lay out a spiral twist on a tube, and how to lay out the twist rate, such as 1 twist (*rotation) in 48 inches. See that in the drawing in the left corner of the image where it shows a vertical line drawn from the centerline of the tube and going down 4 inches, and from there going once more back up to the centerline of the rear of the tube. Along that vector layout a chalk line and roll the tube over the chalk.
                        http://img.photobucket.com/albums/v4...ngmachine1.jpg
                        The PDF link shows how to make an antique barrel rifling machine, and therefore it shows how to layout and cut groves in turned wooden tube, which is information necessary for any accurate layouts of spirals on or inside of tubes, for it may be that laying out electrical lines or magnets inside a tube is better due to the rotational speeds and centrifugal forces involved.
                        http://www.survivorlibrary.com/libra...ng_machine.pdf
                        • #57
                          Here's how it works:
                          Magnetic vortex wormhole generator
                          ABSTRACT
                          This invention relates to a magnetic vortex generator which has the ability to generate negative mass and a negative spring constant which, according to Einstein's General Theory of Relativity, is required in order to create a stable wormhole between our space and hyperspace. Two separate, but electrically connected, toroidal coils of differing radii, carry magnetic flux in opposite directions about their common centerline. According to Maxwell's equation, this produces bucking electric fields along said centerline. Because the two solenoids have different radii, the parallel spring constant of both coils is negative. The negative mass together with the negative spring constant produce a real resonant frequency which can distort the spacetime curvature due to the creation of powerful spikes of negative mass. This phenomenon, similar to the common electrical thunderstorm, opens up a wormhole into hyperspace through which low-density hyperspace energy can enter into our dimension. This energy finds many application in new types of power supplies, inertia-less and mass-less spacecraft, vehicles that can travel light-years by moving out of dimension through hyperspace, surgery-less medical tables, cranes for lifting heavy objects, cold-welded crystals for crystal rotors, folding space waveguides, and electromagnetic field propulsion vehicles using highly relativistic fields.
                          Now if you look at the images from the folks over at Spacewarp on their science of Bruce Gernon's interupted journey, or accelerated one if you prefer, then there appears to be some support to this idea.
                          [url=http://www.spacewarpdynamicsllc.com/[/url]
                          https://static.wixstatic.com/media/0...3e3e9dd9c5.png
                          And another thing> Ya know how they are always saying these UFO's have strange hieroglyphics or writing on them. Well just look at what the spacewarp people have created. Now if that's working as
                          an antenna, and applied to the exterior of machines then I suppose most people would try to explain it as writing or some kind.
                          Bucking Gap Image located at:
                          https://www.overunityresearch.com/in...?topic=3107.75
                          • #58
                            This is interesting to scan over. It's a study on how to possibly simply the visualization of vortex's in 3 dimension by using multiple micro-magnets. Thee are some interesting effects noted in the study on the properties of multiple spinning magnets.
                            Three-Dimensional Dynamic Self-Assembly of Spinning Magnetic Disks: Vortex Crystals https://gmwgroup.harvard.edu/pubs/pdf/766.pdf
                            Extract-
                            Conclusions and Outlook
                            - The theoretical description and controlled experimental realization of vortex-vortex interactions in three dimensions are often prohibitively complicated: the experimental simplicity of our system might offer a remedy to these problems. (ii) In self-assembly and materials science, the systems of spinning objects can serve as precursors for open lattices to be used in photonic band gap materials -
                            A discussion here on optical vers photonic band gap.
                            https://www.researchgate.net/post/Wh...tonic_band_gap
                            Photonic band structure for a superconductor-dielectric superlattice
                            https://ir.nctu.edu.tw/bitstream/115...4163400004.pdf
                            • #59
                              I apologize to all of you because, ya know, I'm a pretty simple guy. Not educated in this stuff at all, so it's hard for me to link up the technology to construct a case. As a result, I've been slow to comprehend the totality of the Alien Reproduction Vehicle. This shouldn't be all that surprising since this is essentially a very early machine, and like many early machines the arrangement of the components isn't likely to be advanced. A comparative history of the evolution of machines shows how as the understanding develops then so too do the machines themselves. In other words, to use an analogy here, it's actually easier to understand how an airplane like a piper cub flys than it would be to try to understand how the wright brothers first plane flew.
                              Gravity Waves and the ARV's Antenna System.
                              What I had previously thought was a kind of atmospheric vacuum, and collecting ions for a fuel source, now appears to be incorrect. Mark McCandlish said that he thought the ARV had an antenna; which was this ring which forms the base of the platform where the crew door appears, and evidently this idea is well founded. A reading of the St. Clair patents shows that this ring like structure is a type of antenna. It's evidently a component of a gravity wave drive system. The authority on Gravity Waves, aside from Einstein , and whom we can't talk to so far as we know, appears to be Dr. Robert Baker.
                              Patent
                              Gravitational wave propulsion
                              https://www.google.com/patents/US20070001541
                              This AAG (*American Antigravity) page has links to video's on Youtube by Dr. Baker. Robert Baker, Jr on High-Frequency Gravitational Waves
                              Robert Baker on HFGW Fusion Energy
                              Robert Baker’s Open-Cavity HFGW Gravitational Wave Detector
                              Robert Baker on HFGW Remote Imaging & Surveillance
                              Robert Baker, Jr. on Chinese HFGW Research
                              Gravitational Communications for Telecommunications
                              How To Generate High-Frequency Gravitational Waves
                              And other additional video links there as well.
                              Gary Stephenson on High Frequency Gravitational Waves
                              Now there are a plethora of issues going on here as a result of this latent epiphany and which should actually concern everyone everywhere. Too many to be brought forward here in total, but these include; Sub-space communications, almost certain to be in use right now, contrary to what the Jason Report by the Federation of American Scientists would have you believe.
                              Dr. Baker releases this volume as a primer that presents the most basic elements of gravitational waves.
                              Renowned Expert, Dr. Robert Baker, Publishes Primer on Gravitational Waves
                              Gravitational Waves -- The World of Tomorrow, A Primer
                              https://books.google.com/books/about...vgAACAAJ&hl=en
                              https://www.amazon.com/Gravitational.../dp/B01MF6CJJW
                              Now this ...this is an interesting paper for someone like myself because you may recall how I mentioned that the first people to take note of antigravity effects were those scientists whom designed and witnessed the first atomic bomb tests, and what this suggests, as was hinted at in Dr Steven Greer's movie; "Disclosure" is that these nut cases have disturbed or even damaged civilizations far and wide across the galaxy by sending a gravitational shock wave across the proverbial universe: One can only imagine what other advanced societies may think about humans if this is the reality, and it does seem to look like that is the real motivation for alien visitations: Insane people with too much money and not enough brains and whose wealth and power is all based on creating fear, war, and death isn't likely to be a successful pathway to advancement or even survival. If not by our own hands than by others if necessary.
                              Generation of Gravitational Waves with Nuclear Reactions
                              http://www.drrobertbaker.com/docs/Am...hys.%20160.pdf
                              So now the reason I've posted all this really has to do with a tiny bit of obscure info, now mostly scrubbed off the net by enemies of humanity, and that happens to be the Chris Hardeman Experiment.
                              http://jnaudin.free.fr/html/gravshld.htm
                              • #60
                                As this information seems to grow legs on a regular basis I'm gonna post these images so that some may choose to safeguard them as they see fit. This is the crop circle Chris based his experiments on. Barbury Castle Crop Circle 1991.
                                *Note.
                                Generally speaking, it seems as though every lunatic has taken the image of the Barbury Castle Crop Circle and somehow or other self-constructed the second coming of Jesus Christ. Don't be deceived because even to someone like myself, a completely ignorant person electronically speaking, this is an obvious depiction of a microwave cyclotron, and we all know that microwaves have of course long been associated with UFO's and cropcircles.
                                Now the problem with the Haldeman experiment is that it too is missing parts, just like so many others, and here I think one has to refer back to the St. Clair patents. Specifically this one. What's that in the middle of that cropcircle? A magnetic vortex generator?
                                As an footnote; note how the information in this rather small image shows how some of these cropcircles have a great resemblance to Telsa's work.
                                http://www.cropcirclesecrets.org/cci...rcles_6003.gif
                                Note that there are three sphere's set in a triangle and each one is showing the primary components which drive the sphere's. There's the cyclotron producing microwaves, there's the depiction of the separations of charges, there's the sphere with what appears to be a stick inside it, but which is, in reality, an dipole antenna.(*Well either it's an antenna or it's a representation of the microwave's cathode. Right now I'm thinking that's what it is.)
                                The Physics of Microwave Ovens
                                DREAMS OF THE GREAT EARTH CHANGES
                                Satellite Power Station
                                https://www.slideshare.net/Biswajit_...-power-station
                                The Production of Microwaves in a Magnetron
                                http://askphysics.com/wp-content/upl...agnetronop.gif
                                GBPPR Homebrew Radar Experiment Magnetron Pulse Transforme. Site probably contains useful information. One image link I've included.
                                http://gbppr.dyndns.org/~gbpprorg/mi...dar/pulse.html
                                http://gbppr.dyndns.org/~gbpprorg/mi...ar/pulse-1.png
                                This link involves an extreme effort. It's worth examining in detail. I may comment on this further later, but posting it for reference and so that I don't forget all about it. The field drawing showing a steel ball is nearly a replication of plasmoid, another antigravitational plasma which has been invading our skys for quite a while, but much more commonly as of recent and is often mistaken for a UFO.
                                The Institute of Paranormal Science - The Antigravity Theories of Fran De Aquino
