If that's a correct suppostion then in considering this what you should be able to do is even simpler. You should be able to take an slab of aluminum, apply an charge, and then using some simple arrangement place a rotating plate with magnets on it beneath the plate, and at some point the plate should then levitate to some degree just so long as it's in range of the influence of the magnets.
We should be able to test the hypothesis with very little effort. Might take some screwing around to find the sweet spot as they say but theory say's this is what's going on and so we should be able to replicate the effect with miniminal effort.
I wouldn't be surprised if there's a motive force of vibrational frequency involved that's making the Alexey seem mysterious. Could be coming from the motors themselves along with everything else he's got involved, but ya know, everything we know says that this needs an applied vibrational frequency. After thought: Heck shove an old microwave antenna beneath it as both the charge apparatus and the HF carrier.
See if this is what's taking place then everything else is just a matter of finding the right means to make it happen on demand. *Notice that by motive force I just mean that a high frequency vibration connects to the surrounding incoherent dielectric field, which is probably critical as that is what would be feeding a vacuum being compressed at the core....if you're following> Are you?
Not that different from the re-computed Flying Tetrahedron Patent in a way.
