  • If that's a correct suppostion then in considering this what you should be able to do is even simpler. You should be able to take an slab of aluminum, apply an charge, and then using some simple arrangement place a rotating plate with magnets on it beneath the plate, and at some point the plate should then levitate to some degree just so long as it's in range of the influence of the magnets.
    We should be able to test the hypothesis with very little effort. Might take some screwing around to find the sweet spot as they say but theory say's this is what's going on and so we should be able to replicate the effect with miniminal effort.
    I wouldn't be surprised if there's a motive force of vibrational frequency involved that's making the Alexey seem mysterious. Could be coming from the motors themselves along with everything else he's got involved, but ya know, everything we know says that this needs an applied vibrational frequency. After thought: Heck shove an old microwave antenna beneath it as both the charge apparatus and the HF carrier.
    See if this is what's taking place then everything else is just a matter of finding the right means to make it happen on demand. *Notice that by motive force I just mean that a high frequency vibration connects to the surrounding incoherent dielectric field, which is probably critical as that is what would be feeding a vacuum being compressed at the core....if you're following> Are you?
    Not that different from the re-computed Flying Tetrahedron Patent in a way.
    • Originally posted by Gambeir View Post
      Good for Alexey, this gives me a lot of joy quite frankly. Glad to see Alexey basically tell his critics to piss off.
      https://www.youtube.com/watch?v=URQgtvtYrx0
      Всё-таки железяка подвешена на леске сверху! Поначалу не понимал, как он прокручивается всем телом. Но, как точно подметил пользователь IVS (комментарий закреплен), лески две! На 0:44 четко видно как он просовывает руку между лесками, а когда снимает аппарат на 0:56 - вынимает руки. И создается иллюзия, как будто он водит руками над аппаратом, но на самом деле внутри между двумя лесками. Все очень просто. За кадром стоит некая мачта-журавль, на ней висит горизонтальная планка длиной равной ширине диска, за оба ее конца и подвешен аппарат на двух лесках для большей устойчивости. Вначале ролика также видно по характеру движения, что он ее именно поднимает. А леску не видно так как был хорошо выбран ракурс съёмки и достаточное удаление от места действия. Сколько я не увеличивал видео в редакторе, так и не смог разглядеть леску, т.к. разрешение и детализация оригинала не позволяет ее зафиксировать в принципе. Наивным зрителям он объясняет это якобы глюками камеры на близком расстоянии, и даже шлем космический придумал для пущей убедительности. Итог - развод на донаты наивных хомяков. Удивляюсь только, как люди ведутся, ведь уже и леску саму видели на прошлых видео, и все равно проглатывают ложь полными ложками, ещё и повторять ринутся угрохав кучу времени и средств. Ну и козел же этот Леша. Не знаешь как и назвать таких людей..
      Show less
      • Originally posted by aljhoa View Post
        Yea, well It's a critic with nothing to support his own allegations, totally expected, we are all gullible fools don't ya know, all being taken in by a crafty old trickster, or stinking bastard depending on how you see it. I'm gonna stand by my bent beer can tetrahedrons on this and say it's real; only it's not understood. Hell I didn't understand it. Not till the other day when I destroyed the patent explanation of the dubious theory of accessing a vacuum, as opposed to creating a vacuum, and I was only able to do that thanks to Kens' explanations of how it works.
        Anyways whatever, it's not like anything else that I know of, and yet it's doing what I would expect it to do. Maybe it's Putin putting his vote riggers on another task trying to make me look like a fool. I mean that's so logical right? Just goes to show that you can show someone, even explain the physics, and still they are unconvinced. I don't know what's more complex, the explanation given for how fishing lines created an illusion, or the explanation I gave which might be simpler given the complexity necessary to devise a means to invoke magical fishing lines
        I don't see any fishing lines and never have. Besides which claims of fishing line are first and the oldest claim made by debunkers, but where is their supposed evidence, and silence because there isn't any. These are the same claims that every debunker has used over and over without any supporting evidence. The fact that they say they can see fishing lines is not evidence of fishing lines. It's a video and if there are fishing lines then I'm quite sure that any truly serious debunkers should have a field day finding frames in the video's which support that claim and so far there are zero.
        All I can say is that I can explain it and it looks real enough to me the way it behaves. I further think it would be very hard to make it behave as it does which seems to be balloon like. If there's fishing lines then find them and the only way that thing could mimic a balloon is if there is an overhead balloon with fishing lines. So yes it could still be a fraud but there's no evidence being given by anyone that supports the allegation such as frame grabs from the video's. Alternative explanations are not physical trace evidence in lieu of the observable video which doesn't display any evidence of fishing lines nor of a large overhead balloon. The machines behavior almost seems to require a balloon to explain it as a fraud. It act's like a balloon.
        Alternatively it is "now" explainable and logically so in my view. We should be able to replicate this now given what the theory tells us. The theory is not complex at all nor are the tools which should enable the theory to be put in to practice. On top of all that if we now look back upon the ARV there's a lot of things which are becoming more sensible.
        Ya scared me with that because I thought after the translation that it was Alexeys' confession, but no it's just another denier, one whom probably teaches physics at the University. Lol~
        Now on the plus side RexResearch is back so there must have been some server malfunction, and also the website Space Warp Dynamics is now kaput. You may recall I cited that website in the thread. They recently solicited suggestions due to the apparent failure to explain the antigravity phenomena but it now appears they have called it a warped wrap, which is to be expected, after all it was all based on Einsteinian Physics to begin with.
        .https://web.archive.org/web/20160329...namicsllc.com/
        • Now you would think that a pastime like fishing would make for a peaceful and thoughtful person, but evidently this is a dangerous hobby, one which is, apparently, akin to smoking crack since apparently the outcome seems to be a mental incapacitation to rational thought. We need to make fishing illegal is the only truly rational and logical answer to this problem. Maybe that will resolve the drug problem.
          Now look here, the late Boyd Bushman shoved a pair of magnets with opposed fields together and then put that combination inside a rock which he then tossed off a building. By his own account he specially selected unwitting subjects to observe, and at the same time he tossed that rock with the magnets off the roof an nine story building he also tossed another rock without magnets. It's unknown whether he specifically selected people known to be fishing enthusiasts but I'd imagine those would be the first choice as irrational thinkers seem to be the ideal test subjects for observing phenomena.
          http://www.rexresearch.com/bushman/bushman.htm
          So now the outcome is that rocks do not fall at the same rate of speed like
          Galileo imagined, at least not the ones with magnets inside them, or at least not the ones which have opposed fields and which fall slower. Now what do we call this? Magneto~resistance is what we call it, but why is he stuffing magnets inside of rocks; won't this work with just the magnets themselves?
          CARET Drones love power lines and humm tunes.
          https://en.wikipedia.org/wiki/Giant_magnetoresistance
          See people need to stop it with this imaginary fishing line bull****, which tells me that there's a whole lot of people that need to do a lot less fishing and a hell of a lot more experimenting but I digress. Ok, well so anyways enough with the fishing line bull****, but ya know no one seems to have really thought too much about this and tried the experiment with just freaking magnets not stuffed inside of rocks. So why rocks then; right?
          Because dammit....are you listening now or what, and because I'm only gonna say this one time, and it is that the opposed fields of the magnets are pushing outwards creating a so-called bucking gap, and then we must realize that despite this the dielectric fields in opposition are still coherent field....and so how then are you going to repel an incoherent field with a conventional magnetic field which is coherent if you don't somehow make it less coherent? Hence the damn rocks. Now are you listening out there or what? For Christ sakes pay attention please because I'm only gonna say this once, and that is Boyd was showing us they aren't using quantum physics; they are using Aether physics. OK, it's obvious that's the case.
          Now I imagine that if you did that same thing only doing it in such a way that it was producing as spinning high velocity bucking gap that there might be even greater results, and maybe if you shoved it out through a bunch of quartz or something else it would really prevent magneto~electric induction, and then maybe the damn thing might just float like a balloon, but that's just an off the cuff dangerous armchair hypothesis and there's probably better ways to go about this anyways.
          Don't you guys remember Wheeler screwing around dropping magnets down a copper pipe and talking about skinny chicks complaining they were gaining weight whenever Ken was around? This is all about preventing induction.
          So you see it looks like there's more than one way to go about this and it's sort of hard to say which way the Alexey is going, but I think it's going the opposite way which I previously already explained. Now please get rid of the fishing poles in the garage if you haven't already and then unfriend any social contacts with known fishing enthusiasts. Honestly it is really the only sensible choice given the evidence. After all, fishing appears to be a gateway hobby.
          • Sir
            here is Similar topic on an Open source forum ,comments from member "nix85"
            ..https://overunity.com/17933/russian-...topicseen/#new
            respectfully
            Chet K
            edit
            also you should read this ..https://overunity.com/18476/rules-fo...msg545261/#new
            if you propose an Open source build in "your" 2020 builders section there ?
            Could be very interesting indeed.and also have topics on your other interests "managed" in separate threads.
            you have been at this long enuff to have _street Cred_ with open source community
            and would get support there...[IMO
            also seems I can no longer remove unwanted posts here ?[mine at request of OP]
            will diminish or remove any unwanted content as always.
            BE that change !!
            • Originally posted by RAMSET View Post
              Sir
              respectfully
              Chet K
              edit
              Thanks Chet, as Aljhoa should know I was only joking. There is only one thing which resembles the Alexey that I can think of and we have been there before.
              http://blazelabs.com/e-exp10.asp
              • Here I did an auto`translate of the critic's opinion.
                Still, the piece of iron is suspended on the fishing line from above! At first, I did not understand how he scrolled with his whole body. But, as the IVS user accurately noted (the comment is fixed), there are two fishing lines! At 0:44 it is clearly visible how he pokes his hand between the fishing lines, and when he removes the device at 0:56, he takes out his hands. And an illusion is created, as if he was moving his hands over the device, but actually inside between two fishing lines.
                Everything is very simple. Behind the frame is a crane mast, on it hangs a horizontal bar with a length equal to the width of the disk, both ends of the mast and the device is suspended on two fishing lines for greater stability. At the beginning of the video, you can also see by the nature of the movement that it raises it. But the fishing line is not visible since the shooting angle and a sufficient distance from the scene were well chosen. How much I did not increase the video in the editior, I could notmake out the fishing line, because the resolution and details of the original does not allow it to be fixed in principle. He explains this tonaive viewers by citing glitches of the camera at close range, and he came up with a space helment for greater convincingness.
                The result - a divorce on donations of naive hamsters. I’m only surprised how people are being led, because they’ve already seen the fishing line themselves in the previous videos, and still swallow the lies with full spoons, they will also rush again, having threatened a ton of time and money. Well, this goat is Lesha. You do not know what to call such people ..
                So there, this is the pigeon english language google translate version of the russian critic's review of the Alexey video.
                • The issue before us is how to create a vacuum. Recall the previously cited patent claimed to access a quantum field, which is then further claimed to be a vacuum, and is further said to be accomplished by inducing a high frequency RF/Microwave vibration.
                  Pressing forward we note that the primary propulsion system is based on the simple concept of a vacuum. What we can rationally deduce is that any vacuum is itself the product of creative innovation manipulating a dielectric medium. In which case a vacuum would arise out of a turbulence that produces vortex's, and these vortex are intentionally created in man made machines, and in nature as the normal natural outcome of crystalline lattices.
                  A rational person would conclude that since the production of vortex's are an important and critical area of study in aviation that there might then be a logical connection which can be traced and which, if followed, lead from the past to the present, and so there is such a path to trace.
                  Note of the construction of the vortex clouds in this extremely enlightening photograph.
                  Applied Area Rule Convair F-106 Delta Dart Interceptor
                  Flow-visualisation-of-jet-screech-One-observes-the-stationary-shock-waves-due-to-steady.png
                  "Flow visualisation of jet screech. One observes the stationary shock waves due to steady expansion-compression oscillation of the jet. Cylindrical acoustic waves are emerging from the intersection of the shock with the shear layers. The waves on either sides of the jet are in opposite phase." (Source)
                  https://www.researchgate.net/figure/...fig2_324844571
                  The discovery and prediction of vortex flow aerodynamics
                  https://www.cambridge.org/core/journ...90/core-reader
                  https://hushkit.net/2019/03/29/the-l...nical-liaison/
                  http://www.nurflugel.com/Nurflugel/L...body_p-13.html
                  https://en.wikipedia.org/wiki/Lippisch_P.13a
                  https://en.wikipedia.org/wiki/Area_rule
                  *Note here that the area rule is the applied solution to a problem: The problem of vortex lift, which the F-102 demonstrated as incapacitating induced drag, with the design itself arising out the Lippish P-13 design with it's 60 degree delta wing configuration. One Lippish P-13 was inventoried as recovered Nazi Aircraft. It's whereabouts are unknown. Especially interesting due to the projected use of an innovative coal dust powered ram jet motor.
                  https://en.wikipedia.org/wiki/Convair_F-106_Delta_Dart
                  https://en.wikipedia.org/wiki/Soliton
                  FALACO SOLITONS Cosmic strings in a swimming pool
                  https://arxiv.org/abs/gr-qc/0101098
                  • Since the issue is now a question, one of how to create a vacuum, what next follows is determine what the vacuum is? Now, me being me, my first thought about the sort of vacuum we are interested in creating is not the same as say a vacuum from a vacuum cleaner, even if it has some of the same qualities, which is to say my idea of what we are after isn't a defined by a lack of supposed atoms or particles. Naturally my thinking is about a vacuum in terms of magnetism or the dielectric field and really in my mind the issue of so called particles bears no part in the issue at hand. However this is hardly the case for other definitions of what constitutes a vacuum.
                    Richard Feyman and John Wheeler were trying to explain the materium using flawed hand me downs and lacking real tools. I'm not sure how far I can blame them for what exists as quantum physics. The reason is there are parallel's to this in American History during the age of spiritual revialism. Every time I consider quantum theory I'm reminded of the life of Rev. Jonathan Edwards, whom remains most famous for his hell fire sermons, such as; "Sinners in the hands of an angry God.
                    When your own introspective thoughts are your only tools, and when that tool is the only thing which can provide answers, then the only answers that can come out are those inside the mind and which is to say; you cannot expect that the outcome is necessarily reflective of reality. Maybe if Richard Feyman and John Wheeler had a ferrocell lens we wouldn't be locked in another age of spiritualism disguised as a science and where the preachers of this age are no less prone to delusional constructs as were those of another age, but regardless of the flaws the real problem is a for profit educational system, and that is to blame more than any single individual, because a complex explanation is an exploitable avenue for the educational business model, and simplicity does not lend itself to student loan debts.
                    The system could take and adapt and rework Ken Wheelers material in to quantum physics, and it could rework Feyman, but it won't because there is no profit in simplification, and let's face it, truth went out the window the moment dollars got involved.
                    https://en.wikipedia.org/wiki/Sinner...f_an_Angry_God
                    https://www.physicsforums.com/thread...vacuum.441867/
                    https://physics.weber.edu/schroeder/mrr/MRRtalk.html
                    https://physics.stackexchange.com/qu...perfect-vacuum
                      Sir
                      respectfully
                      Chet K
                      edit
                      Ok, well I haven't forgotten the thread. I've been considering how to go about doing some simplified experiments. The idea here is we have to crawl first, walk later, so that sort of logic is necessary if you want to formulate reasonable experiments to conduct. We have to simplify and reduce so that basic ideas become solidified before we can progress to others.
                      From the very beginning of this thread the idea's surrounding anti~gravity have been extremely complex and involved lots of energy, and yet look at a rubber band powered balsa airplane; can it really be all that much more complex than aerodynamics? If we can make a rubber powered wooden model defy gravity using the air around us then why should this be any different? It's not logical that it should be any more complex; not really.
                      Therefore let's review what we know and with the hope that this will allow some simple ideas to be formulated, and which can be put to experimental tests, and which will then either validate or invalidate those ideas; hopefully there's others out there whom are thinking on this topic and doing some of their own experiments.
                      We know the ether is essentially unknown, but we do know a couple things about it, one, it is hyper~spatial and as such cannot be interacted with under normal conditions, but we can see it, whatever it is, using a magnet and a ferrocell lens. Second, we know It's not a physical particle, nor is it something visible except in it's condensed form, but it is out there all around us as far as we know because magnets must work everywhere, even in space evidently.
                      A magnet creates a pressure field and a vacuum field. It has an accretion disk vacuuming in surrounding ether and then ejecting it outwards only to be taken back up and recycled once again. We also understand that accelerating the magnet will aid in spinning up the accretion disk. Now consider the Ranque-Hilsch vortex tube in this matter as a kind of analogous tool to understand the operation.
                      We have to think about the way this is working in a magnet. The Hilsch tube is an analoguous tool to use. In the tube we have pressure being injected as opposed to a magnet where the ether is being vacuumed in. The Hilsch tube isn't recycling anything either. It's maybe a bit more like a galactic jet, but we have two vortex's being ejected, one out either end and with a kind of polarity in that one is hot and one is cold. Also, do I really need to draw your attention to the form of the control valve and it's relationship to a pyramid, tetrahedron, cone, or prism.
                      ?u=https%3A%2F%2Fwww.researchgate.net%2Fprofile%2FRaoul_Liew%2Fpublication%2F255995699%2Ffigure%2Fdownload%2Ffig1%2FAS%3A634605560414208%401528313164196%2FThe-Ranque-Hilsch-vortex-tube.png&f=1&nofb=1.png
                      https://www.researchgate.net/figure/...fig1_255995699
                        Al
                        • Ok, well maybe...https://www.amazon.co.uk/Daniel-Eagl...rwt_scns_share
                          Or ..."Ever get the feeling the staff want to kill you?"
                          Umm...well they have tried a couple times in the past: I thought maybe they had given up.
                          That's the problem with this new format; the outside links don't show up for non-members nor photos.
                          Now seriously
                          https://www.youtube.com/user/getonthisplanet/featured
                          More seriously
                          https://www.liquidgravity.nz/index.html
                          http://www.liquidgravity.nz/assets/i...400x658-48.jpg
                          We are being watched and I'm pretty sure it's not aliens watching either.
                          My question is what are they watching for?
                          • "All matter comes from a primary substance, the luminiferous ether." Nickola Tesa.
                            The ether passing through matter, and in tracing ionic bonds exits matter as vortices, and these vortices further complete a self assembly process which then produces a coherent rotational inertial force with the result that counter rotational inertial ether vortex's are formed: Out of chaos comes order. I would submit that what has previously been understood as atomic forces are, in reality, the result of vortex formations.
                            As demonstrated in the Ranque-Hilsch vortex tube, these vortices can be produced forwards and backwards by the form (Geometric Form) which the ether encounters. The primary tool to the production of effect is by speeding up the inducted dielectric (ether) field. As a result of this understanding it's no wonder that so-called antigravity devices have sought to use so~called radioactive substances in their design.
                            https://upload.wikimedia.org/wikiped...elter_sign.jpg
                            http://www.civildefensemuseum.com/signs/
                            Radiation
                            https://image.flaticon.com/icons/svg/44/44060.svg
                            From my previous, previous life, just saying....
                            https://images.fineartamerica.com/im...collection.jpg
                              Sweet Oil of Vitriol is diethyl ether. I see the logic given the video's of water maintaining it's coherency in the weightlessness of space and those of Astronauts swallowing water balls floating around and such. Then there's Ufo's predilection for water and the curious case's of abductions and murders where the bodies are redeposited in or near water and which appear to be Ufo involved. Finally the stories of Ufonauts begging for water.
                              Also I notice that beside the fact that water and diethyl ether do not mix;
                              "Ether does not form hydrogen bonds, and only has Van Der Waals forces between the molecules (London dispersion forces/instantaneous induced dipole forces and dipole-dipole forces)"
                              "It was synthesized in 1540 by Valerius Cordus, who called it "sweet oil of vitriol" (oleum dulce vitrioli)—the name reflects the fact that it is obtained by distilling a mixture of ethanol and sulfuric acid (then known as oil of vitriol)"
                              "The element ether, called “akasha” in Sanskrit is the first of the five great elements (pancha mahabhutus). It comes first because it is the most subtle of the elements. Often referred to as “space,” it is the essence of emptiness. It is the space the other elements fill."
                              "According to ancient and medieval science, aether also spelled æther or ether and also called quintessence, is the material that fills the region of the universe above the terrestrial sphere."
                              • https://en.wikipedia.org/wiki/Dilithium_(Star_Trek
                                Al
