"How much energy is there in a permanent magnet"?
  • #31
    Originally posted by Allen Burgess View Post
    • N / L = number of turns per length of the core/shaft, expressed in turns per meter
    This is why the pancake coils work so well, make this really high and the shaft length low.
    • #32
      High Level engineering math studies.
      Uo
      https://www.youtube.com/watch?v=hRyxCilntDg
      _________________________________________________
      • #33
        People get far to dependent on calculators so they forget the roots
        of what they are talking about.
        https://www.youtube.com/watch?v=9m4Mwvwk7nQ
        • #34
          idol worship useless integrals
          see
          • #35
            GAP motor
            Time to take another look at KEhYo's GAP motor: The magnetic field in the power coil has to equal the force of the permanent magnets to mask the field:
            https://www.youtube.com/watch?v=sxrJoGZy1to
            • #36
              Allen you must understand something. Most of us look at so many of these
              motors of every type wondering what the parallels or significance as
              compared to who knows what. After years of study I have come to know
              that certain people have a gift of insight for what normally just goes
              right over my head.
              So let me know what I am looking for on this motor with 2 coils.
              I looked at it as you suggested, like a calf staring at another fence
              the farmer put behind. It takes time for reality to set in.
              What am I looking at here?
              So far I see a energy consuming pmm, runs on 12vdc.
              • #37
                GAP motor
                @BroMikey,
                The permanent magnets power the rotor. The induction coil neutralizes the force of the permanent magnets.
                There's a ferrite core inside the coil that magnetizes and demagnetizes as the coil's energized. The combined magnet strength of the wire coil and the ferrite core exactly matches the strength of the permanent magnet stack that's attached to the back of the coil. When the power is curtailed to the coil, the permanent magnets reverse the magnetic polarity of the ferrite core and propel the rotor magnets with the attraction force from the permanent backing magnets alone.
                The power coil generates a "Masking Field" of opposite polarity in itself and the ferrite core to allow the rotor magnet to slip by at TDC.
                The inductance of the coil and ferrite core as measured in Henries powered by a pulse measured in watts would exactly equal the power in Gauss of the permanent backing magnets to neutralize the magnetic attraction to the rotor magnets.
                When the power to the coil is interrupted, the permanent magnets reverse the polarity of the ferrite core they're attached to on the back, and the full attraction force of the core and permanent magnets together, pulls the rotor magnet forward until the coil once again energizes to block the magnet force. This releases the attraction grip at TDC and allows the rotor magnet to slip by.
                I just received a message from the builder and he agreed to try and fit output coils around the magnet stack. This would generate "Lenz Free" output through induction, and perhaps achieve an Overunity COP!
                In addition, the power coil's bifilar and generates output from the ferrite core polarity reversal flux.
                • #38
                  Wow this sounds great. I would have missed it all without your
                  explanation. Now I get it. Thanks Allen and keep me up to date
                  on things you run across. I like that there gitup.
                  This setup seems like you could collect all of the BEMF upon
                  disengaging the masking field? What a kool idea.
                  Now I have something to digest.
                  • #39
                    @BroMikey,
                    The permanent magnets should "Demagnetize" somewhat from the saturation of the ferrite core. JLN measured his da-mag COP at 16 times. The magnets have to work to restructure their domains on the quantum level. The magnets consume heat and generate electric power when they re gauge. The bonus of this build is that the power coil generates exactly the amount of heat the magnets consume to re-strengthen themselves.
                    Winding output coils on the magnet stacks should collect all the electric power the magnets generate, and the power coil should generate all the heat the magnets consume to power themselves back to full strength!.
                    The builder's trying this right now for the first time at my suggestion. We may be in for a major break through soon!
                    • #40
                      @BroMikey,
                      Nice going Allen
                      Power coils and output coils both matched for the task. Sounds like
                      a bifilar arrangement or a double coil winding? No? Keep me up to speed.
                      It looks like the calves went from staring at a new fence to potentially
                      kicking down the stall.
                      Wouldn't that be something if a matched coil set was found to leverage
                      a high COP.
                      • #41
                        a high COP.
                        The pdf from the open source harvesting with coil capacitor thread is working along similar lines.
                        • #42
                          BS
                          ... da-mag COP at 16 times. ...
                          What is "da-mag"? And define input and output for COP of 16.
                          ... The magnets consume heat and generate electric power when they re gauge. ...
                          So you're telling us that we can heat a magnet (like in an oven) and it will generate electrical power? Got any proof or reference showing this?
                          Looks to me like you just make this stuff up as you go.
                          • #43
                            @bistander,
                            You're the one making stuff up.
                            • #44
                              wtf?
                              @bistander,
                              I ask a couple of simple questions about your statements. Of course I made up the questions. Where else would the questions originate? But they are legitimate. Give me answers. Otherwise you confirm your statements are made-up and have no proof or supporting references, literature, science or logic.
                              • #45
                                @bistander,
                                You just made it back onto my ignore list. I'm tired of flunking your quiz!
