Real Free energy Transport machine
  • Real Free energy Transport machine
    The presented concept is a completely perpetual machine.
    In this design there will be two inclined track systems .There will be also two seesaw system which will work to put the train on these inclined tracks and train will move with the help of gravity power.
    These seesaw will get energy with a motor and this motor will work to press these seesaw systems.
    HOW THIS DESIGN WILL WORK?
    When the vehicle will be moved from right to left direction on the inclined surface then it will be started to move due to gravity.when this will arrived at the bottom track of seesaw then this seesaw will be balanced as the other arm of seesaw will have a counter weight equal to the train or vehicle.
    Now this seesaw will work this vehicle on the second track which is inclined in opposite direction with the help of a motor as this motor will work to press the counter weight arm of seesaw and this seesaw will work as a lift up system to put the vehicle on the track.
    In this way this mechanism will work turn by turn .When this vehicle will arrived at the bottom of left to right direction the same mechanism will work to put the train on the track again.
    There will be some generators which will be attached with the wheel of Train coach(VEHICLE) and these generators will work to generate electricity .There will also a permanent magnetic linear generator system which will work to generate electricity.These generators will work on the equal polarity of magnets. In this generator only one magnet will be attached with vehicle and several with track in this way when vehicle will move on the track then these magnets will work to repel each other due to equal polarity to move a spring based generator.
    Potential energy=mgh
    If mass is 1000 kilogram of the vehicle and height is 1 meter then
    P.E.= 1000*10*1
    P.E.=10000 joule but to lift up this vehicle on the inclined track the seesaw will consumed only 50 to 100 joule energy.
    The out put will be 20 times more than input.
    The salient feature :
    (1) this is completely a perpetual machine as we all know that there will be need of very very less energy to put the vehicle on the track due to balanced seesaw but the vehicle will generate more and more energy depending on the length of track system.
    (2) the kinetic energy will be more than the input or out put will be more than input.
    (3) A complete over unity tech .In this design there is no problem of inertia or friction.
    I HAVE DONE MANY EXPERIMENTS ON THIS TECH AND ITS WORKS REALLY.
