Michael J Nunnerly's STEAP TPU ideas
  • Michael J Nunnerly's STEAP TPU ideas
    Michael is open sourcing some very interesting work.
    a result of years long investigations .
    snip
    Some ideas that I will now open source which have dated
    back to my “STEAP” work a long time ago.
    Here are two schematics, the first is the original but with what I call an internal feed back via D2, I
    have never shown this before due to lack of interest by others. The start voltage is 12vdc, but the
    feed back voltage at the point between D1 and D2 can be around 100v, so some form of voltage
    control is needed in case of runaway. C4 charges and maintains the run voltage, when tuned to the
    correct frequency no current should be seen across the CSR.
    end snip
    please keep comments on Topic
    respectfully
    Chet K
    BE that change !!
    Stupid thread
    @ramset,
    What's the point of this stupid thread?
      Nerderly.
      @ramset,
      You're supposed to know about this? What's it all about?
        New thread
        @ramset,
        Maybe you should start a new thread up?
          testing
          @ramset,
          Where's your testing? We need to see something!
            Sidetracking dialouge?
            @ramset,
            I will remove this post in 5 minutes if I'm side tracking any dialogue!
            Respectfully,
            Allen
              Thamsanqua Jantijie
              @ramset,
              Take a look at yourself:
                Looks interesting!
                snip
                end snip
                respectfully
                Chet K
                Hi Ramset,
                I am going to build one of these. Looks very useful. What does CSR mean in the pdf?
                Sounds like there are some other gems from Mr Nunnerly? Pity about the other comments. that's forums for you!
                Edit: have found the resistor CSR! Printed off the pdf and ink was low so not all type clear.
                Dwane
                  Hi Dwane,
                  Csr stands for current sensing resistor. It is there so you can measure the voltage drop across the resistor with a scope or meter to calculate the current going through the circuit.
                  Carroll
                    Hi Dwane,
                    Carroll
                    Hi,
                    Thanks for the reply, I worked that out. Having printed the pdf file, the image was badly reproduced, and with my bad eyesight, I missed it on the circuit diagram. All good. This useful looking circuit is about number 4 on the cab rank!
                    Dwane
                      Dwane
                      thanks for the interest, I will be catching up With Mike in the next few days
                      I believe there will be more to discuss then.
                      also I will start a new topic [these posts above are from a ruff time here
                      which has been resolved.
                      Respectfully
                      Chet
                      BE that change !!
                        HI Chet,
                        Am also wanting to hear about this as parametric circuits are of interest to me too. Thanks for posting such info , will be waiting to hear more about this .
                        Jeff
