Sagnac Effect
  • Sagnac Effect
    The Sagnac Effect - YouTube
    https://www.youtube.com/watch?v=Fk0RvzaHq_Q
    [VIDEO]https://www.youtube.com/watch?v=Fk0RvzaHq_Q[/VIDEO]
    Code:
    Proof of the Aether
    VIDBID
    Raising questions has also got some to think.
    If there is no Ether how can we talk about light being a wave?
    https://www.physicsforums.com/thread...-a-wave.15764/
    Should the Copenhagen interpretation of quantum mechanics be questioned ?
    https://www.youtube.com/watch?v=WIyTZDHuarQ
    Earlier Tesla suggested that William Crookes "Radiant Matter" showed
    that Crookes came closest to understanding. After Given credit for fundimentals of
    atomic theory what happened ? Did chemist carry on by shelving equipment necessary
    for understanding. There are so many different waves that interact with Aether.
    Sagnac addresses none of the waves that are really relevant.
    Many cannot understand importance of preserving our past accurately.
    They have been running ahead without a basic skill set.
    The Turn Of The Century Electrotherapy Museum Tesla Library
      for your consideration --
      Charles (Joe) Flynn -- Parallel Path Technology
        The true implication is the earth is flat (and it's also square.)
        https://www.youtube.com/user/freeanergy
        VIDBID
          I stopped clinging too tightly to views, when the universe stopped having the decency to conform to them.
          I like it when people challenge the common views. Earth is flat, Earth is a ball, the earth revolves around the sun, the cosmos revolves around the earth, but now not only is it flat, it is square ? Some people might say you've reached too far this time, but I think we've only just scratched the surface.
          How about we backtrack a bit. Does the earth rotate fast enough to act like a centrifuge? A quote from stack.
          "The force that acts on an object in a centrifuge is called the centripetal force, and more specifically it is the centripetal force for uniform circular motion. It's usually more convenient to work with the force per unit mass, which we call the centripetal acceleration, and as the Wikipedia article explains, this is given by:
          a=ω2r (1)
          where r
          is the distance to the centre and ω
          is the rotation speed, or more precisely the angular velocity of the rotation.
          In your question you specify that the rotation speed is constant, i.e. ω
          is constant. In that case equation (1) tells you how
          the centripetal acceleration a changes with the radial distance from the centre r. The force on an object of mass m is then simply F=ma."
          Here the enquirer attempts to paraphrase to see if he has the jist of things and isnt corrected.
          "I took it that the heavier the object is and the bigger the radius, then at the same number of revolutions it is pressed harder against the outer wall of the centrafuge. "
          Without knowing the right unit of measurement to plug into the contstants its hard to do the actual math. Althought the revs are very slow at one per day, the radius is very big. Gee I wish Feynman was still around, he made stuff sound so believable.
          Feynman "Not how clever we were to have found it out, but how clever she was to pay attention to it."
            Michelson-Morley & Sagnac
            GEOCENTRISM-Sagnac's experiment - an animated explanation - YouTube
            https://www.youtube.com/watch?v=SWmlimH7laY
            [VIDEO]https://www.youtube.com/watch?v=SWmlimH7laY[/VIDEO]
            Code:
            Michelson-Morley proves the earth is stationary.
            Sagnac proves Aether exists.
            It's that simple.
            VIDBID
              The earth is flat - a simple proof - YouTube
              https://www.youtube.com/watch?v=MQRp9KAOBHA
              [VIDEO]https://www.youtube.com/watch?v=MQRp9KAOBHA[/VIDEO]
              Code:
              The earth is not a globe.
              VIDBID
                Cyclical Linear Space
                We live in a Pacman-type of reality: Cyclical linear space.
                https://www.youtube.com/watch?v=cw6uiKDE48A
                VIDBID
                  UTM map
                  Original image link: http://www.rambler-info.org.uk/gps/utm_zones.jpg
                  Hidden in plain sight.
                  VIDBID
                    Barrow to Longyearbyen
                    Interesting.
                    So, exactly how far is Barrow from Longyearbyen?
                    VIDBID
