Excellent Wistiti - your set up looks a lot cleaner than most of my quickie builds for testing, I tend to make quite a mess. Yes, I'm using a 12v battery in C1 position.
I'm not concerned with brightness, it's more about the radiant energy being emitted - at least for the output I'm looking for. So far I'm pretty impressed with the halogen bulbs - heat wise. Haven't had much time to work with them but I think they perform equal to or maybe a little better than the nichrome coils I've been testing... the bulbs were inspired by SkyWatchers "spot light" test.
getting late, another long day tomorrow...
Edit: It just dawned on me that you could take the toroid transformer and wind another coil on it with less turns than the 12 volt side. Connect the new windings between caps and resistive load and use the 12 volt side as the output. This might help in matching the load and increase current into the battery being charged. You might need to experiment with turns to find the most efficient output... just a passing thought...
Patent number 3,963,976 for a simple pulsed battery charger - almost like you have but instead of a diode going to your battery use a mosfet ( or another relay ) to pulse the output. If you have a cap in the range of the patent that you can charge to 20-30 volts you'll be able to push 20 amps into the battery pulsing it.
