I realize some think that there is some detriment to charge and discharge simultaneously but I've never seen any problems caused by this. It would, however, become a problem if you were using HV spikes to charge a battery while connected to sensitive low voltage loads. It's not the case here. Also the series batteries are temporarily disconnected when the charge battery is in operation.
In reality we do it all the time - solar to battery to load - running accessories in the car while charging and maintaining the battery etc.
Quite often, with some systems, you wouldn't see a gain if the two were combined because the output of the charging portion is considerably less than the required input - in order to demonstrate the battery charging it has to be into a separate battery.
