Transistor Identification?
  • Transistor Identification?
    Does anyone know what this transistor is? It's on a little SG type oscillator so I'm guessing it is a NPN but do not know what company that symbol goes to. Nobody as Mouser or Digikey can identify it.
    RPX & MWO http://vril.io
    best guess is Thomson TO-92
    logo
    1 x BUW52 NPN Power Transistor 250V 150W 250V 20A Thomson TOP-3L 1pcs | eBay
      Its a bit of a minefield trying to identify transistors from the billions Aaron. I wonder might I suggest you invest in a simple tester something like this one
      https://www.banggood.com/Transistor-...l?rmmds=search
      It quickly goes through a few tests identifies the component and it orientation and then all the operating parameters so you've got a fighting chance to closely match it to the transistor tables and specs. or simply try a few in the instrument until you find a pretty good match. Its a bit frustrating that you'll have to lift a couple of legs or cut the PC to apply the test still its the best suggestion I can offer. works for me even doing pretty good matching of push pull circuits
      kind regards Duncan
        Hi Aaron,
        Possibly 2N5249, which is NPN, 50V 0.1A
        V
        General D.Eisenhower
        http://www.nvtronics.org
          Hi blackchisel - might be some trouble from my end but it seems your link isn't playing the game right now - regards D
            Thanks Duncan, fixed now.
            V
              2n2222
              Thanks for all your input - Duncan, I like that Transistor tester, will have to get one of those.
              I heard from someone that worked on this particular circuit that it is equivalent to a 2N2222 so that makes it easy. Mystery solved!
