One of the earliest electromagnetic machines by Joseph Henry 1831.
It has been described as a rocking motion. A logical modification
to repulsive mode might use more electric magnets.
To get angular momentum shown vidbid repulsion by re-arranging the solenoids
into a different configuration. With a slow pulse like every two seconds it could be found with
intuitive feel. The reason for backing up is there is another angular momentum design.
It might share some properties. It looks like stacked saturn rings. possibly the ratio of
12 negative electrons to 1 positron forma a structure where they spin faster with
a small amount of repulsion and when they (are kicked) they detach forming current.
Both repulsion and attraction give good results but if you use attraction, provided you create a return path, it keeps the flux within the core of the coil and can be more efficient. I have used the attraction method in the past.
However, in terms of repulsion, I think repulsion works best.
