Hi all, I decided i wanted to make a more thorough experiment.
Specifically, to radiant pulse charge a flooded lead acid battery (tractor battery), to create the conditioning effect upon the lead plates within the battery, that Bedini spoke of and others.
I will be using the Meissner oscillator to condition the battery.
This battery is in good condition and only after one cycle, is already showing some effects, like higher standing voltage after 4 hours resting off radiant charge, 12.90 volts.
I plan to cycle it at least 20 times and am staying within the C/20 charge and discharge rate.
It passed the 1 ohm test off the collector diodes, shows .89 vdc across 1 ohm resistor, directly connected to flyback diode output.
Here is oscillator circuit that is being used.
Oh, the battery was tested first and when drained at C/20, down to 12 volts, it contains 159.4 watt hours, so that data can be used to know if things are changing.
Comments or questions welcome.
peace love light
peace love light
