Originally posted by SkyWatcher
In the sensory start there is no short circuit, it needs to be done through a resistor, I just did not specify in the circuit. The structure is static and the beginning of the magnetization cycle is required. Weigh the circuit, in combination with the coil inducer 1,2,3.
4 coil, the trigger circuit is low-current. A couple of turns around 1 winding with a wire of a small cross section are sufficient.
The main thing in this scheme is the construction of an inductor. When the current is excited in the circuit, the total field is accumulated by only 1 winding. After excitation is turned off, the field is discharged through two coils (1 and 2), the total resistance (Ohm) of two coils is less than three when excited. The motion of the magnetic flux, there is no interference, so the discharge in the energy potential should be higher
