Aether dispels the fundamental myths
Dr. James DeMeo's new book is something that is a must read for anyone interested in energy science: https://emediapress.com/2019/10/23/t...es-demeo-ph-d/
There are so many experiments that show very conclusively there is an aether and this isn't just successful interferometer experiments.
The importance of understanding the reality of the aether is that with an aether, there is no point to conservation of energy, ridiculous ideas of storing potential, etc.
Since the potential is infinitely available anywhere and is tapped with a dipole anywhere, conservation of energy and storing potential are the real crackpot ideas. Work accomplished automatically diminishes the potential difference of organized potential with reference to a lower potential. That process of energy being created and destroyed is simply work being done, nothing magical. And the dissipation of potential is disorganizing the aether right back to the symmetrical, homogenous state in the active environment.
And when another dipole is created, fresh, organized aether comes into the system to do more work while being dissipated back to the symmetrical background state. That is all that ever happens.
That potential in a gravitational/mechanical system like lifting a ball, chemically like the separation of "charges" or an electrical system like charging a magnetic coil - the source potential is the exact same stuff, it never changes form, it just gets polarized and depolarized and that is about it.
The work that manifests as heat or otherwise doesn't change form because it is an activity and isn't something that can change form. It is the potential that is undergoing a transformation from polarized to depolarized. But even that doesn't change the aether, it is the same stuff. If you have 10 books scattered on your floor and then pile them up in alphabetical order, you never changed the form of those books - they're still the same, they're just ordered or disordered.
The exact same gravitational potential available to an object to push it to the ground is 100% identical to the Heaviside flow flowing over a wire so there is no mystery to unifying gravity and electricity.
Mass displaces the aether and aether rebounds back from where it was displaced pushing back on mass in the downward direction. A battery polarizes the aether around the terminals when the chemistry is polarized, that is the exact same aether that pushes objects to the ground.
Where is there any changing form of potential? It doesn't exist. The potential remained the same stuff - just polarized or depolarized.
Where is there any energy changing form from one form to another? It doesn't exist. Work is changing forms from one kind of work to another? lol
Bearden is right when he says a generator at a power station doesn't contribute 1 watt to the grid - that is because turning a generator is creating a dipole that breaks the symmetry of the aether and polarizes it to move over the wires. So whether you're "burning" calories to crank a dynamo with your hand, burning fuel in an engine to turn that generator shaft, etc. not a single calorie burned to mechanically turn it with your hand transformed into the light bulb lighting up on the output of the generator. Same with the gasoline.
You dissipated potential right there chemically/electrically/mechanically. You only setup another potential difference in a different system where that system broke the symmetry of the aether in its own vicinity. Nothing flowed from your arm/hand through the crank of the generator and into the generator to magically transform into work being done when the light bulb lights up.
If you have a Rube Goldberg Machine that has 50 steps from the time your hand pulls a lever until a toasted piece of bread pops out of the toaster, not one iota of potential used for the work done for your hand to pull that level wound up at the toaster. Every single step along the way was nothing more than another dipole setup that allowed it's own locally sourced potential to come in to do work, which allows the next thing to source it's own potential to do work and so on and on and on until the toast pops up.
It is because of the nature of the aether that allows us to dispense with the myths of conservation of energy, the idea that energy can't be created or destroyed it just changes from one form to another, the idea of storing potential, etc. Those fictions are only needed to explain in the most ludicrous way possible how the nature of energy works without an aether. If there is no aether, then we lift an object and store magical potential in it (after we already dissipated it) and then we talk about the myth that when we let the object go, we get out what we put into it. This ridiculousness is only there to make sense (nonsense) of things without an aether. No, what we get out of lifting the object is the lift of the object in and of itself.
